Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Water Filter cartridge needs replacement, but can't remove the old one
I need to replace the water filter cartridge, however I cannot get the old one to turn so I can remove it. I don't want to force it and break it--any suggestions?
  • wheelerll Oct 31, 2008
    Sorry, I wasn't very clear. The cartridge is in the fridge; the exterior part (that looks like the grill at the bottom) is what I can't get to turn. It should turn a quarter turn, allowing me to slide it out and replace the filter, but it seems jammed. Like I said, I don't want to break it, so was hoping for suggestions.
    Genius:
  • 1,122 Answers
Is it in the frig. or outside the frig.?-mike
Posted on Oct 31, 2008
  • MIKE major Oct 31, 2008
    i don't fully understand but try this, if the filter is in the frig. get your hair dryer and heat up around where it screws in,this will dry up the moisture,now get a good leather belt ,make a circle and put it around the middle of filter,turn it so the belt tightens up,it like using a oil wrench but will work on water filters,i have done it before,let me know how you make out-mike
Where is the water filter on frs24wscb?
Good Afternoon Teresa,
I understand you want to know where the water filter is located on your Frigidaire refrigerator, model# FRS24WSCB. The water filter is located in the top back right-hand corner. To change filter follow the instructions below:
It is not necessary to turn the water supply off to change the filter.
1. Set ice maker lever (wire signal arm) to the OFF (up) position.
2. Hold filter cup firmly, and unscrew counter clockwise. (Some water could leak out as you remove cup. This is normal.) Filter cartridge should come down with cup. If cartridge remains in housing, pull down gently, while twisting filter back and forth.
3. Empty cup of any substance.
4. The large o-ring that seals the filter system sets in the o-ring groove down inside the cup. Should the o-ring fall out during filter cartridge replacement, simply place it back in the groove prior to screwing the cup back in place. If the o-ring becomes damaged, you will need to order a new one from the Consumer Assistance Center.
5. Discard old filter cartridge.
6. Remove new filter cartridge from packaging, and install.
7. Place filter cartridge in cup. The end with the small o-ring should be up, out of the cup.
8. Screw cup, with filter, back onto housing. Do Not Use Wrench To Reinstall Cup. Filter cartridge will self-align as cup is tightened. Be sure cup is completely tightened with PureSource Plus Logo facing outward. Do Not Tighten Past Stop.
9. Set ice maker level on the ON (down) position.
10. Check for leaks. Open refrigerator door. Wipe any water drops from the filter cup. Run a glass of water. If there is a leak, unscrew filter cup, and reinsert the filter cartridge. Check placement of large O-ring. Reinstall filter cup, making certain it is tightened completely.
11. To condition filter system and purge air from water line, run several glasses of water through water dispenser. This will also assure that the purest water possible is stored in water tank.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 01, 2014 | Frigidaire Refrigerators
Where is the water filter on a 1997 side by side Roper
Do you have a manual for the refrigerator to check he same
Sep 08, 2008 | Roper RS22AQXKQ Side by Side Refrigerator
I've got a side by side Whirlpool refridgerator. The Water Filter status light is not indicating. What could be the problem and solution?
There are several pages that explain dispenser programming. This is on page 10 of the owners manual.
Water Filter Status Light (on some models)
The water filter status light will help you know when to change
your water filter. When the water filter status display changes from
"GOOD" to "ORDER," this tells you that it is almost time to
change the water filter cartridge. Replace the water filter cartridge
when the water filter status display changes to "REPLACE." If
water flow to your water dispenser or ice maker decreases
noticeably, change the filter sooner. The filter should be replaced
at least every 6 months depending on your water quality and
usage.
After changing the water filter, reset the status light by pressing
and holding the FILTER button for 3 seconds. The status light will
change from "REPLACE" to "GOOD" when the system is reset.
Changing the Water Filter
1. Press the eject button to release the filter from the base grille.
2. Pull the filter straight out.
3. Turn the cap counterclockwise to remove it from the filter.
IMPORTANT: Do not discard the cap. It is part of your
refrigerator. Keep the cap to use with the replacement filter.
4. Align the ridge on the cap with the arrow on the new filter and
turn the cap until it snaps into place.
NOTE: You can run the dispenser without a filter. Your water
will not be filtered. Simply insert the cap all of the way into the
base grille and rotate the cap until it is firmly in place.
5. Remove the covers from the O-rings. Be sure the O-rings are
still in place after the covers are removed.
6. Push the filter into the base grille. The eject button will pop
back out when the filter is fully engaged.
7. Flush the water system. See "Water and Ice Dispensers."
Water Filter Status Light:
The water filter status light will help you know when to change your water filter.
When the dispenser control panel's water filter status display changes to "ORDER," this tells
you that it is almost time to change the water filter cartridge.
Replace the water filter cartridge when the water filter status display changes to "REPLACE."
The filter should be replaced at least every 6 months depending on your water quality and usage.
NOTE: If water flow to your water dispenser or ice maker decreases noticeably, change the
filter sooner. After changing the water filter, reset the status light.
Details:
Pressing and holding RESET FILTER starts the 3 seconds countdown. Using the dispenser
cancels the countdown AND no dispensing is permitted. The number '3' blinks 3 times and the
'invalid' tone sounds 3 times and user has to release both the pad and the button and press
the button again to start it over
After 3 seconds, the BLUE WATER BARS in the Icon flash and an audible tone sounds 3
times. When the system is reset, the "ORDER" and "REPLACE" icons will disappear from the
display screen. See figure 16.
Note: Users can reset the filter status at any stage.
If you should need the complete and exact model number and manual with parts manual you will need to enter the Model Number here=> sea_breeze_132.jpg Manuals, Guides and Instructions Please rate this solution, Thanks, Sea Breeze
User manual click HERE
Apr 02, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water won't flow, water line clear and has water running thru it....
Then you have to replace the water filter of the refrigerator. It is having some blockage that is why water is not flowing in it.
Filters situated in the interior liner of the refrigerator compartment of samsung-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  1. Remove the old filter by grasping it and slowly making a one quarter turn to the left.
  2. Pull down gently on the filter to remove it from the mounting bracket assembly. Be careful to not tip the filter, as water may spill out of it.
  3. Discard used filter.
  4. Remove the new filter from its packaging. Apply the appropriate month sticker to the filter to remind yourself to change it again in six months' time.
  5. Fill the filter with water from the tap, and then line the arrow on the filter up with the arrow on the cartridge holder inside your refrigerator.
  6. The filter automatically pulls itself into position as you turn the filter to the right and lock it in place. Be careful to not over tighten the filter into position.
  7. Run water through your dispenser for about three minutes to clear the system. Keep in mind that a newly installed water filter could initially cause water to spurt from the dispenser.
Water by Culligan filter cartridges need to have a water filter adapter installed. This is a one time installment, and once you have this adapter installed, it stays in the refrigerator for all future filter replacements. If your refrigerator already has this adapter in place, do not remove it to replace the filter.
Smart Water filter cartridges do not require the use of the water filter adapter. If for some reason your refrigerator has an adapter in place already, you will have to remove it before installing a Smart Water filter cartridge. The adapter is removed in the same manner as the filter itself: with a gentle quarter turn to the left.
Note: Replacing this type of filter is a quick process - there is no need to unplug your refrigerator when replacing it. Also, this filter should be replaced every six months.
Hope this was helpful to you. Thank you for using fixya.
Jan 27, 2011 | Samsung 26.1 Cu. Ft. Side-by-Side...
Where is the water filter for the ice maker located on a GE tfx24zr side by side refridgerator located
Filters situated in the interior liner of the refrigerator compartment of GE-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
Jan 26, 2011 | GE Refrigerators
Where is the water filter located and how do i replace it.
The water filter is located in the fresh food or fridge side of the appliance, at the rear - in the upper right hand corner.
To change the filter, open the fridge door, clear the top shelf and grasp the filter. All that is needed is to turn the filter to the left about a 1/4 turn for it to drop down. A few drops of water may spill onto the shelf. To install a replacement, remove the protective cover (shown as a red cap above), and position under opening for filter. Gently push upward while turning the filter to the right. The filter will pop in, and as you turn about 1/4 of the way around, it will be drawn up a small amount until seated. At this point it will no longer turn any further.
More info about the filter is below (taken from the manual).
Please rate this reply - thanks!
The water "Filter Indicator" light
• "Filter Indicator" light lets you know when it is time to change your water filter cartridge. The light
will change from green to orange. This tells you that it is almost time to change the current cartridge.
It is recommended that you replace the cartridge when the light changes to red. (see "Install the water filter" section for more information)
• If you install water filter, throw away the first six glassfulls of water filter, or until water flows clearly to flush impurities in the water supply system.
Using the dispenser without the water filter
• You can not use the water and ice dispenser without a water filter cartridge because the water line
blocks at water supply.
Ordering replacement filters
• To order more water filter cartridges, call 1-800-SAMSUNG and ask for accessory Part # DA29-
00003A or contact your authorized Samsung dealer.
Jan 04, 2011 | Samsung RS265LABP Side by Side...
I CANNOT REMOVE THE WATER FILTER LOCATED IN THE UPPER RIGHT INSIDE THE REFRIGERATOR. I TRIED TO TURN IT COUNTER CLOCKWISE BUT IT WILL NOT COME OUT. THE PART NUMBER ON THE FILTER IS UKF8001. ANY...
  1. 1. Look for the water filter cartridge. On some refrigerators it is located in the back, upper right corner of the refrigerator compartment. Some refrigerators have it in a tubular-like slot under the door and accessible from outside.
    2. Remove the old cartridge. On the cartridges that are located inside the refrigerator, the cartridge should be slowly turned to the left. Don't pull down on the cartridge. A small amount of water may drip. On the type that are under the door, follow the arrow labeling for the direction to unscrew it. Slide it outside.
    3. To replace a filter, fill the replacement cartridge with water from the tap. This will speed up water flow after installation. Run water from the dispenser for three minutes after replacing a filter to clear the line. Refrigerators with a filter warning light require you to reset the light. Press and hold the Reset Water Filter button to do that.
Jan 18, 2010 | Refrigerators
How do I replace the water filter in my Maytag Refrigerator it is a side by side with the ice maker in the freezer door. The light is on and I can't find my boodk
iF THE FILTER IS IN THE UPPER LEFT HAND CORNER OVER THE ICEMAKER. iIF YOU HAVE A REPLACEMENT FILTER ON HAND. YOU NEED TO TURN OFF THE WATER SUPPLY AT THE SOURCE. DISCONNECT THE VINYL TUBING AND LET IT DRAIN INTO A BUCKET OR ANY OTHER VESSEL. THEN YOU CAN TWIST THE WATER FILTER COVER COUNTERCLOCKWISE AND REMOVE THE OLD FILTER CARTRIDGE AND INSTALL THE NEW NEW ONE. THEN JUST REATTACH THE WATER SUPPLY LINE AND TURN ON THE WATER SOURCE. THERE SHOULD BE AIR AT FIRST THEN WATER SHOULD COME OUT OF THE WATER DISPENSER.
Jul 19, 2009 | Maytag MSD2756G Side by Side Refrigerator
Slow water flow from GE Fridge water dispenser
slow water from my ge refrig side by side. less than a momth old
May 04, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Kenmore Fridge - Bad Testing Water
Your refrigerator definitely has a water filter. If you have gone 5 years without replacing the filter, you and your family have probably been drinking contaminated water, for some time. Water filters should be replaced every three to six months. On some refrigerators, and in cases of higher water consumption, the filter must be changed every 60 days. Sears sells replacement filter cartridges for Kenmore refrigerators.
The water filter on your refrigerator is located at the front base of the unit, in the grille, below the freezer door. There, you will see a round cap. Turn the cap counter-clockwise, until the handle is vertical.Then, pull it out of the grille. The filter cartridge is attached to the cap. After removing the cap and filter, slide the cap off from the existing filter cartridge. Slide the cap on to a new cartridge, and re-insert with the cap handle in a vertical position. Push it in, firmly. Then, turn the cap clockwise, until the cap handle is horizontal.
Oct 24, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
200 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
rugby prop
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
