Question about Kenmore 44042 Front Load Washer
Off balance, loose drum?
We have had some loads that "finish" with the load still wet. Now I consistently hear the clanging of an off-balance load. Every load. It also seems like the whole drum seems looser when I load and unload it just swings forward to back and I don't remember that.
  • amiizette Nov 04, 2008
    You were right on. Both shocks. Frustrating that they're made of plastic!!! $34 at Sears for the pair.
If your machine produces a lot of banging noises when in a permanent press final spin you may be experiencing a broken spider. It is a part which is not made from stainless steel metal, but attached to a stainless still drum (tub spin). So, when it is soaked in water all the time during a normal operation of a washer it creates a galvanic element between a stainless still drum and itself. This results in severe corrosion of the "spider" and then leads to it's breakage. To check if you have a broken "spider" open the door of the washer and try to kick your internal drum back and forward while rotating it slowly.If you will hear clicking noises (metal to metal) in some position of the drum it means that your spider is broken. The replacement of this spider will require complete disassemble of the drum. Most likely you will end up replacing this whole part
Drum assembly, spin basket Part # 131618500Another way is get just a spider part, it's doable, but may be tricky.
Posted on Jan 11, 2009
  • 1,028 Answers
Remove lower panel and ck for broken shock..if shocks look ok ck inner basket for excess vertical motion if lots of excess motion possible broken support
Posted on Oct 30, 2008
Washing machine banging noise
It could be the main shaft on the drum or misalignment. There is some flexibility, but not a lot. Check for worn belts, pulley wheels, and other attachments.
Feb 26, 2014 | AEG Washing Machines
Tub is loose
Hello Rob - Try rotating the drum manually when it is turned. If you notice that the drum is not balanced and cannot rotate freely, I would suggest contacting a professional so they can move forward accurately. Washer may possibly have a faulty bearing, unbalance drum or pulley issue.
Oct 06, 2012 | Frigidaire ATF6000ES Front Load Washer
Drum seems to be out of balance. Last two load came out wet. Drum also hit the sides of the washer.
The loads I do with towels always end up with the display UE which is imbalance error, this happens with 1 towel as well as several towels. What can I do to resolve this imbalance?
Sep 24, 2010 | LG WM-2277HW Front Load Washer
The washer always seems to have water trapped someplace...when I turn the drum after a load has finished I can hear the water moving around. Now I've noticed a sour smell. Also sometimes at the end of a...
There is a solution inside the inner tub cover that helps serve as a balancing aid during the spin cycle. It is a normal sound on the washer. There is not a problem.
Jul 21, 2010 | Maytag MLE2000 Front Load Stacked Washer /...
When spinning, Out of balance message occurs, then the machine starts to add water to get the load out of balance. It will put additional time on the wash cycle. It will drain and try to spin again. Then...
it could be weak shocks for the drum or the springs. you can also overload the washer. there should be a gap in filling washer with clothes around 5-to 6 cm's on the drum ring this gives space for movement and balancing. the washer can also become out of balance if the bearing is damaged, if you can lift the drum from the bottom of the ring and it moves up and down by few millimeters and feels lose then its usually a sign the bearing is weak. this can make the display say there is a problem with balance. 6kg or 7kg is the weight of the clothes and water not the clothes. over loading the washer damages the bearings and put more pressure on the shocks and springs.
Jul 03, 2017 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Dripping wet clothes
will be an UNBalanced load, maybe there was not enough clothes in the load so in that case the drum would not be able to distribute the load evenly so gave up on the spin, hence wet stuff!
Jan 27, 2009 | Haier Washing Machines
Clanging noise during spin cycle
Ahaaaa... BALANCE your loads... true for Life too!
Also know some springs "age" and don't provide the "RESISTANCE" needed to keep your drum in place... so they may LOOK PERFECTLY GOOD, but are actually tired from constant stress.
Do your best to use SPRINGS DESIGNED for your washer!
YOU failed to include your model number so I can't be more specific than this.
Dec 09, 2017 | Hoover Nextra 160 HNWF 3137 Front Load...
Kenmore 44042 Front Load Washer Logo
590 people viewed this question
Sal De
 Brian Main
Brian Main
