Question about InFocus ScreenPlay 4805 Multimedia Projector
Colors showing red on screen
I have a InFocus ScreenPlay 4805.  It is normally hooked to an eMac desktop computer and works great.  On occasion I have hooked it to a laptop and had a problem where the white/grey projects as red on the screen.  I figured it had something to do with the adaptor I was using as when I hooked it back up to the desktop computer the color display was fine.
Well, this morning when I turned on the InFocus it is projecting the grey/white as red when hooked to the desktop computer.  I have tried adjusting all  the color settings, using the factory reset, and nothing seems make an impact.  Any suggestions?
Stella
  • ssimon Nov 05, 2008
    The M1 to VGA/USB cable was going bad.  I was able to readjust it to see that if in the correct position the display lost it's tint and was back to normal.
    Scholar:
  • 167 Answers
Hi Stella,
There is a button on the projector called "Auto Image"
Most people don't realize it's even there.
Press it while you are seeing this problem and most likely the projector will figure out the image issue and all will be well.
Note: this feature is nowhere in the menu(s)
Good Luck!
SagerTronics
Posted on Nov 29, 2009
  • sagertronics Dec 30, 2009
    Select "MENU" and see if there is red there...
    If there is, do you notice the projector vibrating oddly or making any unusual noises? If so then the color wheel has failed and will need to be replaced.
Infocus Screenplay 4805 No Display, help?
hi friend,
please try to clean the testing diode of color wheeel.
Jack
Nov 22, 2011 | InFocus ScreenPlay 4805 Multimedia...
My Infocus 4805 is just showing the INFOCUS logo and not showing the picture from the TV. all connections are correct but no signal....help
Powering On
  • If your InFocus 4805 projector is having a hard time powering on or doesn't power on at all, it could be one of two things. Due to the extreme temperature of the lamp that causes the temperature of the projector to rise, every InFocus 4805 projector has a cooling system. Check your projector's cooling solution, as it may need to be replaced. Also check the projector's fan---if the fan doesn't spin, the unit will not turn on. If the problem is the fan, you'll have to get it replaced. You can do this at the same place you bought your projector.
  • The Lamp
  • If your InFocus 4805 Projector powers on but does not project any light, the lamp will need to be replaced. All projector lamps must be replaced at some point---how often usually depends on how much use the device gets. Simply order a replacement lamp, unscrew the old one and screw the new one in. The projector will then work like new.
  • Color Wheel
  • If your InFocus 4805 projector powers on and is displaying images but the colors on the images appear warped or are not in the proper places, your "color wheel" will need to be replaced. The color wheel is a small device that essentially acts like a prism. Light is projected through it and it displays the appropriate colors on screen the way they appear in the original video source. Order a replacement color wheel that fits your model and use your instruction manual as a guide as you swap the old one out and put the new one in.
  • Aug 08, 2010 | InFocus ScreenPlay 4805 Multimedia...
    My video yellow plug works fine, showing correct video colors yet, the red blue green connection is only showing picture in a pale green
    Yellow is composite input if RGB is not working it's probably a cable/output problem try with a different device first.
    Aug 28, 2009 | InFocus ScreenPlay 4805 Multimedia...
    I have a InFocus ScreenPlay 4805. the motor that
    it is the colorwheel and the part number is 525-0146-00. call any infocus authorized service center (find one in your area on their website).
    May 01, 2009 | InFocus ScreenPlay 4805 Multimedia...
    Ful size image not transfering 4rm laptop 2 screen thru projector
    image resolution is not syncing up. reset the settings to factory default, then hook up the laptop and press auto image. if it still doesn't work, you may need to change the resolution on your laptop.
    Apr 08, 2009 | InFocus ScreenPlay 4805 Multimedia...
    I have an InFocus ScreenPlay 4805. it only shows part of the picture. the rest of the screen have lines and is fuzzy. thanks herman
    One possibility is that the Mirror behind the lense is dirty but I think that this also may be the light tunnel issue that I explained in a couple of other posts about the SP4805.
    Mar 17, 2009 | InFocus ScreenPlay 4805 Multimedia...
    InFocus Screenplay 4805 to PS3 Playstation 3 - Blank screen
    Try pressing the "auto image" button on the projector itself. This usually will correct the sync problem.
    Feb 28, 2009 | InFocus ScreenPlay 4805 Multimedia...
    Horizontal colored lines screenplay 4805
    First: Check your connections. Some times people can have the cables connected the wrong way in the pj which makes the screen either all red or distored looking, etc.
    If that doesn't work..
    Then any thing that has horizontal or color lines, dots, or zig zags on the pj means something wrong with the mother board. This is something that you can not typically do on your own. The best way is to have an authorized in focus dealer work on it, even if its no longer under warranty you can find out great locations through their website or themselves for the people whom are used to fixing pj's otherwise you might run into other problem if some one is not experienced in pj work.
    I've worked for a competitor to this brand in the past and that was always a huge sign that something internal was going on if it wasn't a connection error. 9 times out of 10 it was an internal error. I did have some one whom hooked up his component cables wrong which created a red/green image. Once he fixed that it was okay after that.
    Let me know how things go. I wish you luck. Some times its hard to trouble shoot all the way through with out being there. Let me know how things work out.
    Sep 09, 2008 | InFocus ScreenPlay 4805 Multimedia...
    ---------->> My Infocus Screen Play 4805 -Popped*
    Hello David,
    The best way to find the best price is to do some hunting/research. Google "infocus 4805 lamp"
    and wade through to find the best price.
    You will find instructions on the lamp replacement procedure in the manual. If you dont have the user manual browse to www.projectorcentral.com and search infocus 4805 and on their spcifications page there is a "user manual" Acrobat PDF icon.
    click on the icon to open the manual in pdf format
    Take Care!
    Jun 17, 2008 | InFocus ScreenPlay 4805 Multimedia...
    No color
    Color wheel disc is broken and not repairable, problem is unless you know someone that can get the part you have to take your projector to an authorised service centre.
    Dec 11, 2007 | InFocus ScreenPlay 4805 Multimedia...
    InFocus ScreenPlay 4805 Multimedia Projector Logo
    175 people viewed this question
    Top InFocus Office Equipment & Supplies Experts
    jasbo
    jasbo
    Electro Med Services...
    Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
