Question about NEC MultiSync LCD1550V 15" LCD Monitor
Dead monitor soft touch power switch doesn't work.Manual switch on just makes faint tick tick noise.
0 characters
1 Points
It wont turn on.
If the power light does not come on and it makes a screeching noise, most likely its broken. I would contact the manufacturor, in case some warranty left.
Jan 11, 2014 | Acer AL2216W LCD Monitor
Hi, i have a samsung b1930n monitor. It's menu
My monitor is getting blank within 3 seconds after I start my system what could be the problem
Jul 09, 2011 | Samsung Monitors/LCD LCD Panel
MA203DT monitor dead again
I think it's trying to tell you something!
Time for a funeral. Best get a new monitor.
Oct 03, 2009 | iiyama MA203DT 22" CRT Monitor
Philips CRT Monitor 107 E66 SMPS dead Pls any one
The monitor might be 'dead' because the flyback transformer (specially primary section of it) is not working. You can try replacing it if it doesn't cost you too much.
Jul 22, 2009 | Computer Monitors
Samsung 2253bw lcd monitor makes loud, fast ticking noise > 10hz. Noise occurs even when monitor is powered off with switch.
Turned out ticking noise was harmonic vibration triggered by a nearby airconditioning compressor. Once I guessed the cause, putting a rubber pad under the monitor to dampen the vibrations eliminated the ticking. Removing the pad caused the ticking to reoccur. Ditto with turning the A/C off or on. Weird!
Jun 05, 2009 | Samsung SyncMaster 2253BW LCD Monitor
Dell monitor blank. nothing appears on screen. light is blinking by minitor power button, but nothing at all on screen. I hooked up to my laptop, still nothing. Checked power/ tried new power cable. No...
Make sure you set up your laptop to display to a second screen. Depending on your Operating system, go to your display properties and go to the settings tab. Then click on the second monitor and enable it.
Apr 08, 2009 | Dell E773C 17" CRT Monitor
Dead samsung 172n power light flickers
Have you checked the power output from the power board? Is it constant and steady? Try reflowing all the joints if you haven't already. Especially transformer and coil joints. Maybe a bad logic board? Do you have spares to try? Does it do this with everything disconnected from the pwr board (switch, logic, inverter)?
Jan 03, 2009 | Samsung SyncMaster 172N 17" LCD Monitor
Dead Monitor
the monitor is dead
Jul 26, 2008 | Compaq V700 17" CRT Monitor
Had a power outage, acer monitor will not power up
Normally there is a fuse that can be replaced inside on the power supply board. The are usually "slow blow" fuses and need to be replaced by an equivalent fuse. Many monitors have a soft switch which is controlled by the main board that tells the relays to supply power from the power supply. The CMOS devices on these boards are very suceptible to static so ground your hand to the chassis before touching any boards. If the backlight is out but there is a faint image on the screen when you look at it closely then the inverter board or CFT tubes are suspect. BTW: watch the Power supply and inverter boards as the caps stay charged and could result in electrical shock. Good luck. Hope this helps.
Jan 03, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
NEC MultiSync LCD1550V 15" LCD Monitor Logo
37 people viewed this question
Top NEC Computer Monitors Experts
Brian Sullivan
Brian Sullivan
William Miller
William Miller
Are you a NEC Computer Monitor Expert? Answer questions, earn points and help others
