Question about Pioneer VSX-C302 5.1 Channels Receiver
(actually VSX-C300) channels cuts out when playing surround
Playing 2-channel sound works fine. It's when I turn on surround-sound that the problems starts. After a few minutes of playing most of the channels cuts out. It sounds like the fronts still works but the center and surround-channels doesn't put out any sound att all. I've noticed the small fan on the back of the reciever doesn't run even when the reciever feels hot. I've had the fan out and tried running it and it seems to work (jury rigged a couple of 9v-batteries to try it out).
Any ideas would be appreciated.
4 Suggested Answers
SOURCE: Connecting a sub-woofer to Pioneer VSX-453 surround reciever
connect to same terminals as front speakers, this will also cause reduced volume from front speakers. (as per owners manual)
Posted on Nov 19, 2007
lynchms
  • 93 Answers
SOURCE: Center Channel not working on pioneer vsx-d608
Be sure the sound source has a center channel output ie. not a 2 channel source only, try the test tone setup for 5 or 6 channel balance, if no sound from the center channel still then it is looking like maybe the center channel is blown.
Posted on Jan 28, 2009
SOURCE: reciever only allows 2 channels(speakers) at a time.
Two solutions:
1. make sure you are sending a 5.1 signal to the receiver (my DVD player was configured to only send stereo even if I picked the 5.1 soundtrack, i had to fix that). Read the manual to see the indicator lights that would light up if you are sending a DTS signal or Dolby Digital.
2. Use the 'surround modes' to at least get pseudo surround
Posted on Feb 18, 2009
No surround sound
Review the speaker set up instructions to determine whether the correct sizes have been selected. In some speaker configurations, signals are mixed or redirected to compensate for size limitations and other factors.
Mar 19, 2014 | Pioneer VSX-2016 7.1 Channels Receiver
Pioneer VSX-818V-K Receiver
wondering if input levels are too high on some channels causing safety limits to shut it out..check level outputs on eguipment.
Jan 08, 2014 | Pioneer VSX-818V-K Receiver
Dav dz750k
Check your center channel. Most dialogue is routed to the center channel in surround.
Jul 24, 2013 | Audio Players & Recorders
Sound cuts out on one channel while playing LP records VSX-1022
you have a short in the rca cable from phono to reciver. try a new cable. if problem is still there i would say your record player is shorted inside.
Mar 13, 2013 | Pioneer Vsx-1022-K 7.1 Home Theater...
Reciever only allows 2 channels(speakers) at a time.
If the amplifier is not receiving a surround sound signal, you will get nothing from the rear speakers and probably nothing from the front centre. Play a dvd in dolby surround and it will work.
Apr 14, 2017 | Pioneer VSX-918V Receiver
I had this problem too. Finally, after using the MCACC setup and making sure all the speakers worked, I found I had to set the source to FM, TV or whatever from the remote control and set the mode to advanced surround sound using the front panal button on the upper right. Had to fool with them a lot. Good luck.
Jan 03, 2009 | Pioneer VSX-818V-K Receiver
Pioneer VSX-D308 Receiver Problem
go through your mode channels to put it on surround sound
Jun 09, 2008 | Pioneer VSX-D308 Receiver
Surround sound not working properly
this isnt a solution to your problem but i have a suggestion. I see this problem has been posted a couple days now and i think that because your problem looks like it involves more stereo equipment rather than the xbox 360 console. i think you would get a better answer actually a soltuion if you posted this in the stereo section.
Dec 22, 2007 | Microsoft Xbox 360 Console
Pioneer VSX-C302 5.1 Channels Receiver Logo
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
