Question about Minolta Office Equipment & Supplies
Konica 7118 copy machine displays H2 code after printing one sheet and will print no more. How do we clear it?
  • Minolta Master
  • 6,271 Answers
Machine to incorrect paper size METRIC instead of Inch
Posted on Dec 28, 2014
Richie_asg1
  • 1036 Answers
SOURCE: fax problems
Hi!
Does it recognise that it has paper?
Is the printer ribbon/ cartridge empty?
Try replacing the ink cartridge that you have.
If it does not use ink/roll and is a thermal printer, it may be the thermal print head is broken and needs replacement.
Hope this helps.
Posted on Jun 18, 2008
leroyal
  • 2120 Answers
SOURCE: How can I get the fax and copy to print clearly?
Still sounds like a bad ink cartridge, try cleaning the bottom of the cartridge with a Kleenex and soapy water. Dry it off real good.
Look where the cartridge sits and clean the same way.
Ink jets are dead technology.
Posted on Nov 11, 2008
leroyal
  • 2120 Answers
SOURCE: FIRST PAGE PRINTING AFTER SENDING FAX
Scroll through the menus for REPORT PRINT to set confirmation.
Posted on Jan 28, 2009
  • 215 Answers
SOURCE: Panasonic KX-FL511 fax machine always prints blank page
make sure that "autoreduction" is set to on. should be in your owners manual. also, make sure your paper size is set correctly.
razors
Posted on Apr 13, 2009
carlsbiz
  • 1124 Answers
SOURCE: machine will scan a printed sheet when I press the
The document should be face down when copying..
Hope this helps !!
Please rate me good ;o)
Posted on Jul 10, 2009
What does code DY means and how can I fix it
DY THE DRUM CARTRIDGE PRINT COUNTER (YELLOW) REACHES 60,000 SHEETS OR THE ACCUMULATED NUMBER OF ROTATIONS OF THE DRUM (YELLOW) REACHES 715K
If your machine is displaying one of these codes let your service provider know. The codes indicates that the respective drum cartridge has reached it's maintenance or replacement interval. The machine will continue to print normally but you may experience copy quality problems on your printed pages. When the service has been performed the service provider will reset the counter and the code will stop being displayed. In some cases, the machine may be set to stop printing when this code is displayed.
Oct 16, 2014 | Sharp MX-2700N Color Copier
How can i clear error code cof32 on konica 7118 copier
replace the developer and the drum, ensure that counters are cleared and post procedures are run.
May 23, 2014 | Konica Minolta Copier Tnr,...
No matching paper size set paper on bypass tray
Someone has told the machine to either make a copy or print from a PC to the Bypass feed tray on the copier. If you are not trying to print something by using the bypass tray then just turn the machine off, then on again to clear the request from the copier. If you are trying to print or copy from the bypass tray then simply insert the correct paper size and direction into the bypass tray slot and the machine should automatically begin printing.
Good Luck and Thank You for using Fixya.
Sep 22, 2010 | Konica Minolta DiALTA Di200 Copier
ON SWITCHING ON THE COPIER KONICA 2020 ERROR CODE F35 DISPLAYS PROMPTLY
How to clear fuser abnormality codes (F34, F35, F36), 2020.
Solution:
To reset fuser codes, perform the following steps:
1. Access the 25 mode (power the machine OFF. Hold down the 2 and 5 keys, and power the machine ON).
2. Press P-4-7-P on the key pad. (1, 4, 5, or 6 will be displayed on the copy quantity indicator).
3. Press the 0 key to change the indication to a zero.
4. Press the start/print key to enter the new data.
5. Power the machine OFF then ON to exit the 25 mode.
If the code comes back then your fusing unit will need parts/service.
Dec 14, 2009 | Office Equipment & Supplies
Ricoh copy machine 3025 paper jams every time we try to print
Make sure the paper that is in the drawer matches the orientation and size indicated on thje Op Panel Display, If NOT, MAKE IT MATCH.
Mar 31, 2009 | Ricoh Aficio 3025P Black and White Copier
I have a error code F34 on a Konica Copier can anyone help
Description:
How to clear fuser abnormality codes (F34, F35, F36).
Solution:
Note: If the F code reoccurs after powering the machine ON or following warm-up, contact service immediately.
good lock
Mar 11, 2009 | Konica Minolta DiALTA Di200 Copier
Can't print or copy with my toshiba e studio 161
H2 indicates thermistor open.
U can enter simulation mode and input "14" to clear the message.
If happen again, u need to check following:
Thermistor
Control PWB
Fusing section connector disconnection
The fusing unit is not installed.
Perform the following procedure to enter the simulation mode.
"C" key AUTO/TEXT/PHOTO key
Main code Start key Sub code Start key
(Note:Perform the first four key strokes quickly allowing no more than one
second between key strokes.)
Jan 15, 2009 | Toshiba e-Studio 161 Copier Copier
Konica 7255 diaplays a F56-04 code when IP is installed
That is correct. The IP511A is for the 7255 / 7272, and the IP511 is for the 7155 / 7165.
This is probably due to these machines using different image processing boards.
I am actually surprised it lets you get as far as you did with it.
Feb 08, 2008 | Office Equipment & Supplies
How do I get it to print docs in memory?
Does the fax machine produce a copy? If there is a paper jam/toner error, this needs to be sorted first. What is on the display?
Aug 20, 2007 | Brother IntelliFAX 5750e Laser Fax
65 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
