Question about Sony Playstation 3 (PS3) Console
No input signal HDMI
When I go to change the video output settings on my ps3 to HDMI it comes up with No Input Signal I have tried it on a different tele but it still didn't work so it must be the console can you solve my problem please.
  • 2 more comments
  • lb39 Nov 01, 2008
    I have also tries a different cable and it still doesn't work
  • lb39 Nov 02, 2008
    Does anyone know where I can send my PS3 in to get it repaired
  • Anonymous Nov 20, 2008
    mine has the same problem. the hdmi cable i have has been tested and works cause my roommate has a ps3 as well and the TV detected his HDMI output. i believe there was a power surge that came through the cable line and found my ps3 through the HDMI port though. The system does work with the AV cables.
  • dedzspira Mar 28, 2009
    when the first time i always use the hdmi cable and work fine but sudendly the hdmi cable won't work, why?, is anyone can't fix my problem
The next step in trouble shooting would be to try a different cable.
You cannot assume it is the console that is broken unless the cable is confirmed to work.
Web Monster
http://www.monstercable.com
Posted on Oct 30, 2008
No signal from HDMI mode when I switch on the TV
HDMI is an input to the TV not an output. You select the appropriate input e.g hdmi 1, hdmi 2 on the remote. There can be a return signal the other way but the cable has to support that. Try a different hdmi cable.
May 14, 2014 | LG 42LE5500 42 in. TV
How to connect to HDMI
newer tvs need to know that HDMI is attached to give you signal also need to turn on device from where HDMI signal comes from.post the model of your tv ,or if universal remote has input try this,1.- connect hdmi ,2.- turn on device(dvd,ps3,blue ray, etc.) 3.- press input on remote ,or go to menu manually on tv and find input.hope it works.
Dec 14, 2013 | Televison & Video
How do I connect my PS3 to my sanyo dp50747 in hdmi? I have everything hooked up correctly, but its not coming up on the TV. What do I do?????
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
Sep 26, 2011 | Sanyo DP50747 50 in. Plasma TV
Why doesnt my tv recieve signal from my ps3
Your tv might not receive a signal for a variety of reason.
a. You have the RCA (yellow,white,red) cables plugged in the wrong way
b. Your ps3 hasn't recognized your video due to using an hdmi cable and switching around with the settings on your ps3.
c. you have changed the video settings on your ps3 and is now set to the wrong video output.
d. the cables have become defective and you need to purchase a new one.
e. the ps3 has malfunctioned and wont take video anymore.
f. the tv input is set wrong. make sure all RCA cables are found in "video output", all hdmi cables are found in "HDMI", and all VGA cables are found under "PC".
Your guess on the problem is as good as mine.
I hope everything goes better for you : )
Dec 30, 2010 | Video Game Consoles & Games
I am trying to connect my new PS3 slim to my Denon AVR 590 and some odd reason I can't get any video signal from my Receiver... Something I am doing wrong?
Double check your inputs on the denon some are assignable, Check cables for looseness hdmi cables are prone to this since they are digital. make sure tv is on the right input and if it is try changing it to a different input "sometimes inputs/outputs go bad"
Feb 18, 2010 | Denon AVR-587
turn on and hold down the on/off button for thirty seconds when it resets it will load up via hdmi lead this works both ways going from sd to hd, failing that have both connections plugged in both scart and hdmi lead then change the settings to hdmi when viewing through scart connector then flick to hdmi input and hey presto its worked.........
Nov 09, 2008 | Sony Playstation 3 (PS3) Console
HDMI ON ILO 32HD
it sounds like there is a problem with either the output on the PS3 or the input on the circuit board of the TV. I would try a reset on the PS3 first. Also make sure that there are no other video or audio cords plugged into the PS3 because this will cause the PS3 not to send the signal via the HDMI.
Mar 14, 2008 | iLO 2600 Television
Yamaha DSPAX761 no s-video to HDMI
S-Video and Composite are analogue and HDMI is digital. Your receiver dose not have the capability to convert from analogue to digital and hence you are not not getting any video.
Feb 28, 2008 | Televison & Video
Hdmi
I can't be exactly sure without more information, but it sounds like you ps3 is outputting from another port. My ps3 originally was outputting from the component/composite cable port so in order to use the hdmi output I had to do a soft reset. That makes the ps3 sense what cable is plugged into it and automatically output through that port instead of using whatever is the saved setting.
With your ps3 turned on hold down the power button for a few second until it beeps and flashes 3 times (should be about 5 seconds). You might have to try it a few times to get it to work, but you should get picture and be able to adjust the settings on the ps3.
Dec 08, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
98 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
