Question about Concept DVD-168C Car Video Player
No color System works fine except the lack of color, any ideas?
0 characters
1 Points
Pioneer avh p4000dvd w/GMOS-04 wiring harness
This seems the setting change in the player set to factory setting and then see if you face the same problem please use this
moz-screenshot.jpgmoz-screenshot-1.jpg For Service & Support Please Contact Us At: 310397382support-icon_small.jpg 1925 E. Dominguez St.
Long Beach, CA 90810
Call (800) 421-1404
Or contact us by e-mail.
Hours of operation:
24 hours a day for most services. Hours for product service, product operation and parts inquires:
Mon. - Fri. 9:00 a.m. - 7:30 p.m. Eastern (all product inquiries).
Sat. - Sun. 11:00 a.m. - 7:30 p.m. Eastern (plasma, DVD rec
Jun 05, 2008 | Pioneer AVIC-Z2 Car DVD Player
I need help!! i installed my kenwood kvt-617 in my 2000 jeep grand cherokee with the stock infinty sound system and now its all working right except the rear drivers side speaker is cracking and buzzing...
sounds like the speaker is not grounded and to by pass the amp there are two way unhook the speaker wires to the amp and trace what color is what or just run a new speaker wire from stereo to speakers i hope this helps.
Aug 17, 2010 | Kenwood KVT-617DVD Car DVD Player
Everything works except the radio. It appears
If have factory amp you have to find the turn ou wre for the amp and hook it up to the amp turn on wire from the radio(bootleg way sound might cut in & out) or go to local sound shop and get a bypass for the amp
Aug 07, 2009 | Jensen's VM9312 Car DVD Player
I am getting a white screen when I turn on the car sometimes, Everything functions, the screen just goes white, after a while the screen may come back to normal. The system is the XO Vision XOD1741BV
ok, the issue is that the lcd liquid needs time to warm up.  I found this out in my car here in Minnesota that I would see a white screen, which is the backlight.  The liquid that causes the display or colors was cold and thick.  Leave your car warm up to a good temperature and then try it out...should work.  Its a known issue with them, not much you can do about it except give it time to warm up.  If yours has a removeable screen like mine, take it inside with you at night.
Mar 07, 2009 | Car Video Players
Splicing the wiring from a kenwood excelon kdc-x589 unit to a jeep harness
For the Kenwood KDC-X589:
yellow - always on B+12 such as battery + terminal
red - switched B+12 such as ACC of IGN switch
black - body/chassis ground (- battery)
orange/white - dimmer control wire (car light control switch)
gold - to my knowldege no gold
brown - mute control from mobile phone
pink/blk - external amplifier control/trigger wire
blue/white - power control wire similar in function as the orange/white
blue/blk - to my knowldege no blue/blk
blue - motorized/power antenna
For the vehicle, pls postback info on year and make/model.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 13, 2008 | Kenwood Excelon DDX-7015 Car DVD Player
Blank screen - but radio working
I called pioneer an talked to them about mine ,an there sending me a disk that will fix it .Try that an see if they will send you one.
May 10, 2008 | Pioneer AVIC-Z2 Car DVD Player
Clarion vrx755vd no sound
i have the same problem and apparently it is the microprocessor (the brain of the system) is burnt out.
Mar 10, 2008 | Clarion VRX935VD Car DVD Player
Clarion VRX745VD Beeping noise
if the sterio is not originnally from the vehicle and is factory fitted sometimes instead of a code it can make the dreaded beep. The originalvehicle is syncronised with the head unit and the only way to get it to work in another vehicle is to have it syncronised with the new vehicle. Some garages can do this but charge around £20. Its an anti theft system. Hopr this helps :)
Feb 11, 2008 | Clarion VRX745VD Car DVD Player
Pioneer Carrozzeria AVIC-DRV150
check out
I have avic-drv250 and the disk from worked quite fine...except it is in ***.
Dec 07, 2007 | Pioneer AVIC-N2 Car DVD Player
Concept DVD-168C Car Video Player Logo
14 people viewed this question
Top Concept Car Video Players Experts
xxxxxx xxx
Are you a Concept Car Video Player Expert? Answer questions, earn points and help others
