Question about Zenith DVT412 System
My home theater got stuck in progressive scan mode
I cannot get the picture to come back i tried afew things like unplugging the cord tampering whith the buttons inserting anew cd/dvd whatever i cannot see thepicture it wont go back to thesetup menu in wich i pu the home theater in progressive scan mode anybody know s home to undo this action contact me asap thank you
  • Anonymous Apr 04, 2008
    I did the same thing but the thing is. I dont remember how many times i clicked down to get it in the mode to start with. so i get to set up then dont know which one it is i have to click on next
I had this problem, it's a real pain. You need to turn the system on and goto Setup Mode, then count the number of tiems you would need to scroll down and reset it. You will see no picture, so you ahve to actually cound the number of clicks down and over, you are doing it blind, but it will work.
Posted on Feb 12, 2007
Toshiba SD-V55HT stuck in Progressive scan mode.
Hello
Progressive Scan Video provides the highest resolution
pictures with less flicker and line structure
If you are using the COMPONENT/PROGRESSIVE
SCAN VIDEO OUT jacks, but are connecting the
DVD/VCR Receiver to a standard (analog) television,
set Progressive Scan to Off
If you are using the Component Video jacks for
connection to a TV or monitor that is compatible with a
progressive scan signal, set Progressive Scan to On.
To ON and OFF this function, Press "Setup" to display the setup screen.
Surf through, and hilight "Progressive scan" and press "Ok or Enter"
Here you can set this function ON or OFF. If you wnat to get it OFF, select OFF and press Enter.
OK.
Jun 25, 2011 | Toshiba SD-V55HT DVD/VHS Home Theater...
I am usin the components port to connect my Sony home theatre DAV-DX250 to my TV Sony Wega, and it doesn ot work, I just get static. Any idea what the problem is? thanks in advacne
You need to turn On Progressive Scan mode in home theater system to get video output in component video out ports so tv can show its picture.
Progressive Scan mode can be turned On by going into setup menu of home theater, details are available in user manual.
Thanks.
Nov 29, 2010 | Sony DAV-DX250 System
Insignia Home Entertainment System - DVD settings
You can try unplugging the unit for at least a minute. If that doesn't work, what a CSR told me to do to reset my unit was unplug it and while unplugged, push and hold the power button for at least 30 seconds. I hope this helps.
Feb 28, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
I accidently hit the progressive scan button and now I can't get a picture when I try to watch a dvd.
just talked to LG Customer support and got them to send me a manual.
to turn off the progressive scan insert a disk and once it starts playing press stop, then press stop again and hold for 5 seconds this will turn off the progressive scan mode.
Dec 09, 2008 | Zenith DVT412 System
Dvd and progressive scan
THIS IS COVERED IN THE MANUAL. I DID THE SAME THING A YEAR AGO AND RESET IT BY FOLLOWING THE INSTRUCTIONS IN THE MANUAL. DON'T HAVE IT HANDY AT THE MOMENT BUT YOU CAN FINDI IT ONLINE. KEEP IN MIND THAT THE PROGRESSIVE MODE ONLY WORKS WHEN YOU HAVE IT CONNECTED VIA PROGRESSIVE SCAN.
Jun 10, 2008 | Toshiba SD-V55HT System
Stuck in progress mode help
Try this without disc on the tray press the button stop for 5 seconds.Good luck
May 24, 2008 | Zenith DVT412 System
I'm not getting any color pictures in my home theater system
Well, assuming were talking about a dvd player with dvd's,you dont specify what type of cables you are using to conect it to your tv, it appears that it has something to do with Progressive Scan been turned on. Progressive Scan is a feature built in your dvd player, wich by using it, it would give you a better picture//resolution on your tv, you need to use Component or HDMI cables to hook up the dvd to your tv if you want this settings, but if you are using composite RCA cables (Red,White & Yellow) and the Progressive funtion is turned on by accident, it may give you a split screen, black & white, or no picture problems. Also if you are using Component (Blue, Green & Red) cables, if one of them is unplug, the picture can be out of colors, or no picture. Check this things, if not, write back with more details about your set up.
Thanks...
May 23, 2008 | Audio Players & Recorders
Stuck in progressive scan mode.
Based on your description, it seems that you set the DVD to progressive scan output, but have it hooked up to a TV (CRT) that cannot accept this signal. Because the TV can't accept the signal, you can't view the DVD menu to change the setting back to interlaced.
On the back panel you have "Component Video Out" for output via component cables, but there is also a yellow RCA connection labeled "Video Out". This is a "composite video" connection which does not support progressive scan. Try disconnecting the component cables and connect the composite video to a TV. The DVD will likely (hopefully) send a compatible signal (480i) through this connection, which will give you access to the menu.
May 12, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Stuck in Progressive Mode
Had the same problem; here's what i did. Take DVD out of Receiver, close door to receiver and hold down stop button on receiver itself for five(5) seconds. changes should take effect and progressive scan screen should revert back to sanyo screen.
May 06, 2008 | Dual DWM-3900 System
Zenith DVT412 System Logo
96 people viewed this question
Top Zenith Audio Players & Recorders Experts
Marvin
Marvin
xalint1
xalint1
Gagan Telecom
Gagan Telecom
Level 1 Expert
Are you a Zenith Audio Player and Recorder Expert? Answer questions, earn points and help others
