Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
I cannot insert the cruzer miscro USB Flash Drive into othe computer
I try inserting the flash drive, the back side facing me, but it won't insert into the computer. It keeps slipping off.
    President:
  • 2,712 Answers
Can you explain how exactly you are trying to insert it? Some of these drive have a cap that cover the actual USB port. Others, you have to slide the port out with a slider..
Posted on Oct 29, 2008
How to insert sandisk cruzer force usb flash drive into computer?
Usb sockets are all same. Haven't changed. There are other sockets that look similar. HDMI, eSata, display port. I would look very closely to make sure you are attempting to install in the correct port. You might first want to take a look at the flash drive end to make sure that there is no damage. Shouldn't be unless you really tried to force it into wrong port. Other than that, it will fit.
Aug 02, 2014 | SanDisk Cruzer Force 16gb Usb 2.0 Flash...
I HAVE NEVER USED A FLASH DRIVE, SO HOW DO I TRANSFER INFO FROM MY CP TO THE FLASH DRIVE
just insert flash driver into usb of computer and right click on that file which u need to transfer to flash drive and select send to option point to that flash drive another one is save as option and slect location of flash drive
Apr 01, 2014 | SanDisk Cruzer Glide - USB flash drive -...
Bought sandisk cruzer blade usb flash drive 1 day ago but unable to instll it properly.sometimes it is working properly but unable to continue to use it since i formated it.
To make sure that the usb flash drive is working, try inserting it in a different computer. If the problem persists, you may have a defective usb flash drive. Try returning it back to the store where you bought it from to avail of the product warranty. If the store where you buy it is legit, they should replace your item with a working one. To avoid this problem in the future, try using it in the store first before taking it home.
Apr 06, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I am a student in school, and I am not to computer savvy on Flash drive.. It did not come with any instructions on how to use it. It is a Cruzer USB 2.0 Flash Drive (4GB) Can you help me with step-by-step...
  • Boot up your computer and find an open USB port. These are small, rectangular ports typically on the sides or backs of laptop computers, or on the fronts or backs of desktop towers.
  • Plug your flash drive into the USB port. The drive will slide in only if it is turned in the right direction, so if you have trouble inserting it, turn it over.
  • Make sure your computer sees the flash drive. It should launch a menu, letting you know that it has found a new storage device. You can choose an option from the menu or close the menu if you don't need to immediately access the flash drive.
  • Install the flash drive's driver if your computer doesn't recognize the flash drive. The flash drive's packaging should include the manufacturer's website address. Open your Internet browser, go to that address, and download the flash drive's driver from the site. Install the driver on your computer. After that, your computer should be able to recognize your drive.
  • Jan 04, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
    Instructions on how to operate a sandisk cruzer us 2.0 flash drive. what is supposed to happen when i insert the drive, should any on screen instructions inform me what i am transferring to the drive.
    Your system will automatically recognize your sandisk and will automatically install the drivers for it (this will show on the time taskbar located at the lower right side of the screen). After successfully loading the drivers you can now access your usb drive by going to My computer and should have the drive letter after your cd/dvd drive.
    Sep 12, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
    My flash drive is inserted in a USB port. It says
    Try to format the mp3 player.
    Go through: Setting>Control Panel>Administrative Tools>Computer Management>Disk management>
    Try to format it with fat files system.
    hope this help you
    Regards
    uttam
    Jan 13, 2010 | SanDisk 1GB Cruzer Titanium USB Flash...
    Insert cruzer 16gb into usb dell desktop reboots computer
    Visit the website http://support.dell.com and download the file called bios for your computer model and run it .. and then try ...
    Dec 21, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
    I dont know how to start my sandisk cruzer
    Usb are apart of the Play and Plug driver so when you insert it into the computer usb drive it should pop up and if not go to my computer and it will the in the last drive on that window
    Aug 29, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
    1gb cruzer micro
    This is caused by 1 of 2 problems:
    1. Your flash drive is corrupted in some way, forcing the computer to reformat it before you can use it.
    2. The flash drive was formatted for a specific device (like a piano) and was made only for that device.
    3. Your PC incorrectly recognized it
    4. You do not have the correct drivers installed.
    If you have problem #4, you can go onto google and search "1 gb cruzer micro drivers".
    If you have problem #3, try plugging your flash drive into a different USB port.
    If you have problem #2 or #1 (Which it most likely is), then you should try or buy a software application such as PC Inspector, to recover those files. Then you may reformat the flash drive.
    However, I found that sometimes, just restarting the computer, and inserting and re-inserting the flash drive sometimes does work. But that's not guaranteed.
    Feb 05, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
    SanDisk Cruzer Titanium 2.0 GB USB Flash Drive
    It sounds like it is trying to use the E: drive and it is already in use? If so while you have the flash drive installed right click on my computer /click on manage / on the left side click on disk management / on the right side you should see the C: drive with other if you see the flash drive in this list with no drive letter right click on it / click on chang drive letter and give it a G: or other letter not in use. you will get a warning click ok and exit out your drive should appear. (note this is for windows xp)
    Oct 13, 2007 | SanDisk 1GB Cruzer Titanium USB Flash...
    SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
    89 people viewed this question
    Top SanDisk Computers & Internet Experts
    Arora Singh
    Arora Singh
    Sandy Moore
    Sandy Moore
    Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
