Question about Bosch Axxis WFL 2060 Front Load Washer
Any ideas on cleaning where you put powder and fabric softer?
Hope anyone has ideas on this as it easily gets filthy. Is is a good idea to every so often do a wash without any clothes to clean your machine? Any help would be greatly appreciated.
You can remove the tray by pusing in on the tab right behind the fabric softner compartment(on top). This would make cleaning very easy as you could take it and clean it right at the sink. Just make sure you don't over due it and wear out the tray.
Posted on Jan 04, 2007
SOURCE:
My FP washing machine has starting leaving brown sludgy marks on my clothes. Do I need to descale the machine? Im in New Zealand and the water isnt particularly hard. Thanks for your time, Emma
I'm guessing you use fabric softer....Get some finish dishwashing powder and put a wash on with high water level with no cloths in it. let it do it's normal wash but before it drains any water out, pause the wash let it soak over night. next day unpause it and let it finish. Repeat if needed and do the same thing again with out any dishwashing powder in it to make sure it rinses all the soap out.
The black sludge is cause by using fabric softener. The costic in the finish powder will eat in to the sludge and soften it. If its really baked on it my need to soak for longer, more powder or it may need to be stripper and cleaned.
Mar 22, 2011 | Fisher and Paykel Washing Machines
Hey, in which dispenser number do you put washing powder and fabric softer 1 or 2? Thanks
1 is usually for pre-wash, 2 for washing powder and fabric softner goes into the section with the level indicator should be small square section with removable top.
Feb 28, 2011 | Hotpoint Ariston AW125 Front Load Washer
Its actually the 72630 lavamat. Fabric softener remains in the drawer. Have tried cleaning the drawer but nothing is happening. Any ideas? Many thanks
Sorry- my wife is calling but here is a quick probable fix- the fabric softener drawer normally has some sort of cover, which needs to be removed, and underneath is a pipe/tube down which the softener and water mix siphons. This tube gets blocked by gunge- a mix of powder and softener. Ours does!
It has to be completely clear.
Must go.
Good luck.
John C
Feb 11, 2011 | AEG Lavamat 72640 Front Load Washer
Bleach and Fabric softer will not dispense
I had the same problem. I took a sewing pin and stuck it up into the holes at the top and really dug around in there. There was a bunch of slimy gunk in there but works fine now.
Mar 09, 2009 | GE Energy Star WCVH6260F Front Load Washer
Fabric softener stays in drawre
I had this same problem to
If you take out the drawer of the washing machine and look upwards there are 4 very very small holes get a pipe cleaner and giver them a jolly good clean.
This should then solve the problem
Jul 07, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Smelly clothes
A solution from the internet:
Make a boil wash (with no clothes and detergents) put into the powder drawer a cup of bicarbonate of soda.
It should clean the machine and move out the bad smell.
Another:
I have a front loading machine also and am not willing to have to constantly clean out the machine; the soap and fabric softeners you use are building up between the inner and outer drums (and on the drum itself sometimes). Because the machines door is so tightly sealed (to prevent water leakage) the smell from this buildup is awful. I finally found the solution.
MAGGIE'S SOAP NUTS -- they are all natural (grow on trees) and will remove the grime from your drum and also clean your clothes (you won't even need fabric softener anymore). Stop using commercial detergents and fabric softeners and start using Maggie's Soap Nuts.
They are not very cheap but they work great --
I have found that making a liquid out of the soap nuts and storing it in a bottle works better than putting them in the sack cloth they come with (because front loaders do not agitate constantly like regular machines, the cloth bag sits on the clothes and sometimes leaves a stain -- the liquid will not leave a stain.
YOU WILL SOLVE YOUR PROBLEM AND HAVE SOFTER CLOTHES TO BOOT (without fabric softener so you save some money there). They are also better for septic tanks, the environment and your health!
I believe Whole Foods sells them and they are also on the internet at www.Maggiessoapnuts.com
Note: Also go to www.newstarget.com -- they are going to buy these in bulk to cut the cost in half but don't have them yet. You should be able to buy them there soon.
Note: Forgot to tell you to run some of this thru your machine with hot water before washing your clothing to clean out the buildup that is already in the machine
And dont forget to rate me pl. Merry Xmas to you too.
Dec 22, 2007 | Washing Machines
Washing machine
i had the problem of my brand new washing machine not taking the conditioner and the customer service advisor rightly guessed that i was using concentrated liquid and advised me to dilute it with warm water then put it in the drawer because sometimes the liquid is too thick for the machine to take.try this!!!!! regarding the powder why not put it directly in the machine or buy tablets and do the same with those
Dec 18, 2007 | Hoover PE235 Front Load Washer
Black spots
A solution/suggestion from the internet:
It should clean the machine and move out the bad smell or grease.
Another:
I believe Whole Foods sells them and they are also on the internet at Maggiessoapnuts.com
Note: Also go to www.newstarget.com -- they are going to buy these in bulk to cut the cost in half but don't have them yet. You should be able to buy them there soon. Run some of this thru your machine with hot water before washing your clothing to clean out the buildup that is already in the machine.
Sep 19, 2007 | Splendide 2000S Vented Washer/Dryer
Mile 864 front loader - clothes come out with new grease marks
Problem will be the use of fabric softner or too much detergent. The stain you are seeing is generally to animal fat that is present in fabric softner, Best solution is to cut back on the amount of softner being used, same with powder.
Sep 18, 2006 | Miele W864 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
100 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
