Question about Konica Minolta magicolor 2300DL Laser Printer
Printing Issue When printing one pagw will print and then halt with an error: Put Media Tray 1A4 Plain Paper
I had to define and set a new custom paper size in the printer driver- 2mm shorter than the A4 papar that I'm using. Maybe paper sensor misaligned?
Posted on Sep 14, 2007
Test the driver. Go in the properties for the printer and set the number of copies to 4. Try to print a Windows test and and see if you get the same error message. If you do, then the issue is the paper settings in Printing preferences and probably needs to be changed to LETTER paper. If you don't get an error message, the issue is the application you are printing from. Make sure the application is set to letter under printer setup.
Posted on Jul 25, 2007
Hp color Laserjet printer 5550 printing very slow
Please check your paper tray adjustments and verify that the paper type for the tray is set to any type or plain (assuming you are printing on plain paper). In general, if the machine has reason to believe that there is a custom size or special type of media, it prints at half speed.
Feb 26, 2016 | HP LaserJet 5550 Printer
WHAT IS 007-243 code error
This fault code isn't specific to one location/function on your machine, however, I believe it is directly related to your paper trays. Other fault codes begining with 007-??? state a tray sensor error, misfed media in a tray etc...
If you're trying to print to a specific tray and it won't print giving this error, you may want to try printing using a different tray. It is entirely possible you have some jammed up paper in the paper path and this will stop all trays from printing.
Potential solution:
Ensure you don't have any paper jams related to your paper path and trays, herre is a link that provides you all iinstructions to clear any paper jam on your device http://www.support.xerox.com/support/workcentre-7328-7335-7345-7346/support/enus.html?associatedProduct=workcentre-7328-35-45-46-built-in-controller
NOTE: The above link is a support knowledgebase and you can search on any problem you may have with your product by typing the natural language query in the search field, paper jam, can't print, scan fails transferiing etc...
Once you have determined there isn't a paper jam or if so gently remove any misfed paper.Reboot the device PO/PO power off/power on.
If the print jobs fail again, check your job status and see if there is any info listed for your print job, could be a media mismatch.
Try printing to another paper tray, if your job is calling for paper from tray 3 try using tray 4 or tray 5 etc..
I have provided a generic response to this question and kind of throwing ideas out there, if you could provide additional information I may be able to give a better solution.
Check the details of your job in the job status list?
A lot of times the machine will provide good direction on potential issues with a print job.
Are you trying to print on a custom paper size?
If you tell the print driver to print to tray 3 and you have 8.5X11 loaded in tray 3 and your print job from ypour PC is actually 8.5X14 then the job will not print simply put the media has to match the job.
I hope this helps.
Mar 10, 2015 | Xerox Workcentre 7345 Printer, Copier,...
HOW TO TAKE BROTHER PRINTER OFF OF MANUAL FEED OPTION
Hi there!
The message that ask you to manually feed the paper will appear if you have recently printed on a different type of media.
Does this happen from only one application like Microsoft Word? If it does try printing a test page or a document from other application like Notepad or Wordpad.
If the same issue occurs go to the Printers folder (under control panel) then right click on your Brother printer icon, left click on Properties, click on Printing Preferences and make sure that Tray 1 is selected for the tray, Plain paper for paper type. If changes have been made make sure to click on the apply button to apply the changes.
If it only happens to one application like Microsoft Word. Click on File ( or the orb icon on the upper left hand corner) then Print, then Print again click on Printing Preferences and make sure Tray 1 is selected and Plain Paper.
Hope this helps! Thanks
Jun 09, 2011 | Brother MFC-7820N Laser Printer
My HP photosmart 2710 all-in-one has "spot sensor
The Spot Sensor Out of Calibration error comes due to color paper placed in paper tray.
Follow the steps to resolve this issue.
1. Under printing preferences set the paper type to plain paper instead of automatic. This makes it so that the spot sensor doesn't need to look at the paper.
2. The spot sensor, when calibrating, needs plain white paper. Setting the plain paper instead of automatic helps if you are just printing, but colored paper makes the spot sensor confused during calibration.
If you are still not able to print, there is a utility program that fixes the issue too and which will be helpful for you in future use too. Click on the link to download the utility program : Utility download
Hope this resolves the issue.
Nov 04, 2010 | HP Photosmart 2710 All-In-One InkJet...
Unable to print on HP officejet 9120. Error ; Load A4 in tray 2, Plain paper. Tray is empty or media type/ size in tray is incorrect. Ensure media in tray matches printer driver or control panel setting.
when you give print command go to print properties and choose the paper size as well as the tray to print aslo in printer set the the size or paper in tray.
Nov 20, 2009 | HP OfficeJet 9120 All-In-One InkJet...
Printer picking wrong tray for print
From the start menue to printers and faxes go to your printer right click and select properties label the 4 drawers as to paper type and select continue, or auto continue to off.
-Carl, please let me know if this helps.
Jun 26, 2009 | Xerox Phaser 8560MFP Laser Printer
Minolta Magic Color 2300dl printer won't print legal size documen
Is tray one the bypass tray or a tray. check which one is tray 1
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Nov 24, 2008 | Minolta magicolor 2300W Laser Printer
Printing Photos on Photo Paper
Ensure u are placing the paper in the photo tray..
if u r printing from the memory card which is inserted in the printer..ensure that the PHOTO BUTTON on the printer is on..
You can also try to reset the printer by going to the SETTINGS/TOOLS menu (RENCH SYMBOL) and then look for the Factory Restore (Might be under "Preferences")
Sep 28, 2008 | HP Photosmart C6180 All-In-One InkJet...
Printing envelopes
did you put these envelopes right way (portrait/landscape) also you have to change in printer menu paper source paper type from plain paper to envelope.
Mar 24, 2008 | Konica Minolta magicolor 5430 DL Laser...
Konica Minolta magicolor 2300DL Laser Printer Logo
357 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
George Mclaughlin
Clive
Clive
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
