Question about Cisco VPN 3000 (LL-VPN3000) for PC
Ftp server I am using wireless internet connection, I also set up an ftp server. My ip adress is always changing because I have wireless connection, when I assign an ip for my ftp server, I can not use it for the second time... Any solution or another way to set up an ftp server
  • 55 Answers
There should be an option in your touer for having "Static" IP address assigned. Currently, your couter is set for "Dynamic" IP's. I'm not too familiar with this router, but if you go to their support site, they should have some info on how to do this.
Posted on Sep 09, 2006
Cannot access FTP server from outside.
your server need to connect on Internet with pubilc IP or fixed NAT with public IP
Apr 08, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Can you tell me what an ip addresse is im trying to connect to xbox live and it keeps asking for ip addresse
Every device connected to the public internet is assigned a unique number known as an internet protocol (IP) address. IP addresses consist of four numbers separated by periods(also called a 'dotted-quad') and look something like 127.0.0.1
since these numbers are usually assigned to internet service providers with region based blocks, an IP address can often be used to identify the region or country from which a computer is connecting to the internet. an IP adress can sometimes be used to show the users general location because the numbers may be tedious to deal with, an IP adress may also be assigned to a host name, which is sometimes easier to remember hostnames may be looked up to find IP adresses,and vice-versa. at one time ISPs issued one IP adress to each user. These are called static IP addresses. beacuse there is a limited number of IP adresses and with increased usage of the internet ISPs now issue IP adresses in a dynamic fashion out of a pool of IP addresses (using DHCP). these are referred to as dynamic IP addresses. This also limits the ability of the user to host websites mail servers, ftp servers, etc. in addition to users connecting to the internet with virtual hosting,a single machine can act like multiple machines (with multiple domain names and IP addresses).
Jan 30, 2010 | Microsoft Xbox 360 Elite Console
Wireless shows connection,but will not connect.
This kind of problem occur due to dhcp disable in the wireless router for the security purpose. So try to give the ip adress manually by right clicking on the wireless and give the ip adress of the same range in which your network in working e.g 192.168.1.0 is the range of your ip addresses so please select the ip which is not been used by any other computer and than in default gateway enter the ip address of you wireless router and you will be able to access the internet on your system.
Dec 01, 2008 | Linksys Wireless-G WRT54GS Router...
D-Link DP-311P Wireless print server reseting
Hi Luis,
Sorry, it had been my mistake, did not realise your model does not have ethernet port at the back.
On D-Link printer servers that do not have cable connections it requires a couple more operations, you must do the following to connect safely to the server and open configuration:
  • On the rear panel of the DP-311P you fiind a switch to set server to Config mode. Set the switch to
  • Now go to the computer that is connecting wirelessly to the D-Link, go to wireless adapter properties, for example using control panel, and set the adapter to Ad-Hoc mode.
  • Change manually the wireless adapter IP Address so that it is in the same IP Address range
  • as the DP-311P, set the wireless adapter to a static IP address comprised within 192.168.0.2 and 192.168.0.255 excluding 192.160.0.10.
  • Always in wireless adapter settings >> IP configuration, set subnet mask to 255.255.255.0.
  • Ensure you click OK, or Apply in network settings Window, and restart the computer to apply new network settings.
  • Open Internet Explorer and type the IP Address of your wireless print server in the address bar. The default IP Address is 192.168.0.10.
You also find procedure explained at page 7 of the user manual here : D-Link DP-311P
Then follow instructions at page 15 to reset the server.
After you have finished configuring the DP-311P, to save the changes, you must toggle the mode switch on the rear panel of the print server back to “Normal” mode.
Oct 25, 2008 | Office Equipment & Supplies
Shared internet connection help!!!
are you using window xp for both pc?
Aug 25, 2008 | Computers & Internet
Guidance setting up a shared connection :)
1- set up router trough desktop
2-run program for wireless, after it gives you the IP ( which it already has, set user name and password for protection)
3-set up the laptop as a "Shared folder" along with the printer if there is one.
Aug 24, 2008 | Computers & Internet
PS3 40gb, no DNS available
Have you used the automatic settings for the two different connection types (wired and wireless)? You should only need to enter this information if you want to use DNS servers other than the ones provided by your ISP.
You can read more about internet connections on the PS3 with this link: Playstation.net
Jun 11, 2008 | Sony Playstation 3 (PS3) Console
Signing in
Connect it to your router with an ethernet cable.
Make sure the router is setup correctly to your modem, if you can connect all your devices by ethernet cable to the internet then it's set.
If you are using a wireless connection and if it asks for the WEP or WPA key, make sure that you are entering the correct encryption key. You may want to call your router manufacturer to know the correct key for the wireless connection. FYI, it will say that the wireless network is connected but it will still fail the IP Address.
If you have a wired connection and the IP Address or DNS failed, I suggest you to call your Internet Service Provider to check for the Internet connection and obtain these (static IP address, subnet mask, default gateway, primary DNS server and secondary DNS server). If your Internet is okay, enter the IP settings manually on the console (System > Network Settings > Edit Settings > IP settings).
That should work.
Feb 22, 2008 | Microsoft Xbox 360 Console
Sonicwall Pro 300 DMZ Problem
If you're within a network and try connecting to computers on it with the WAN public IP, it simply won't work - you must use the network IP. On an external Internet connection, it should connect fine to the public IP. If you have access to an external machine (remote desktop), or if you know of an FTP proxy, you can try it that way. I also believe http://www.webftp.co.uk/ a web based FTP client would act as somewhat of a proxy, you could try that with the public IP and see how you go.
Aug 09, 2007 | SonicWALL PRO 300 Firewall
Cisco VPN 3000 (LL-VPN3000) for PC Logo
124 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
