Question about Orange SPV M2000 Pocket PC
Help me please
Thanks for the hard reset combination, but it still says serial at top and v2.07 at bottom, and it still doesn't get picked up by computer! Have a broken it??? Is there anything else i can do?
    Problem Solver:
  • 17 Answers
HI
Download mmty.exe from http://www.4shared.com/file/44565543/32026ae8/mtty.html.
Now do the following:
1. Stop ActiveSync, by Task Manager (press Ctrl + Alt + Delete)
kill two processes rapimgr.exe and wcescomm.exe
2. put your device into the cradle
3. Run mtty and Choose WCEUSBSH001 in 'PORT' (if it doesn't show then you didn't stop all active sync processes above!)
4. type "set 16 0" without the quotes to tell bootloader to boot the OS after reset. (for some devices it can also be "set 14 0")
5. type "task 8" to get your device formatted
6. type "task 0" to ask your device reboot
7. take the device out of the cradle, and manually reset it if it does not do that already.
Good luck
Posted on Oct 30, 2008
5 Suggested Answers
Maanita
  • 1142 Answers
SOURCE: Can't reset
Do a hard reset take the battery out leave it for sometimes may be 15 20 minutes and then put the battery in and turn on it should work fine
Posted on May 23, 2008
mstr2kx
  • 102 Answers
SOURCE: screen
Open the Back Cover.. remove the Battery, Simcard, Memory Card and then leave it open for 1 minute.
Put the battery back, start your device then if you get the same message you need to update the firmware...
In the worst scenarios, your Siemens SX66 has a corrupt ROM and need to be fixed as in "Hardware"... which can be done by a Siemes expert.
Good Luck
Posted on May 24, 2008
SOURCE: can't hard reset
Take the battery off. hold the power for 10 sec. Then put the battery back on. Push the reset button 1st then hold the power for 6sec. let off the power button 1st and it should do A hard restart. Take out any memory cards before you do this.
Posted on Sep 08, 2008
  • 13 Answers
SOURCE: screen
I would recommend using Pocket PC 2003 version normally. WM 5 or 6 may have significant issues with phone compatibility. If you can go back to 2003 and the phone still doesn't work there may be a hardware issue, then you need to replace or repair. Replace is usually the better option. Search ebay.com if that is what you need.
Below, instrutctions on getting ROM for PPC 2003:
Try www.xda-developers.com and ebay for ROM upgrades. There are many people who unlock these kinds of devices. I don't believe you can upgrade it to WM 5.0 or beyond, but that may be possible. Search for WM versions that include "unlocked" versions. The best bet is a newer version of PPC 2003.
The process is relatively simple. Once you have your ROM on CD or via download, You run it with your device hooked up to your PC via cable/cradle and connected via ActiveSync (3.7 or later). The warning is an improper ROM load could make your device unusable. It is a risk you have to take if you want it to make calls. Toss up: no phone Pocket PC, pocket PC phone, or shiny brick. If the XDA site has recommendations on a ROM source, they are not likely to steer you wrong. They will state emphatically, that you do not want any interruptions in the ROM upgrade process. If you have a power outage or something shuts off for any reason, you will have the shiny brick and be looking for a new device.
Posted on Sep 19, 2008
How to hard reset
If you provide the phone or tablet make and model, I will try to help you find the hard reset instructions.
Thanks,
Lewis
Nov 09, 2013 | Cell Phones
Singer stylist 477 bobbin case problem
a bit difficult unless you are a machine mechanic or have a detailed workshop manual beside you
I would not waste time DIY and would take it to a reputable sewing machine repair shop
Nov 26, 2017 | Sewing Machines
Need to 'hard reset' my Samsung Galaxy Europa
I attempted the above in order to hard reset my Europa i5500. However, it didn't work, and instead just went back to the "enter address/password" screen. I've attempted to connect to Kies, but to no avail, Kies doesn't register that the product is plugged in. I can get the phone onto download mode and emergency download mode, however neither are helping me much. Any suggestions?
Nov 30, 2011 | Samsung I5500 Galaxy 5 Unlocked Android...
My garmin nuvi 255w keeps freezing up at loading maps screen...i have tried the hard reset but that doesn't work, when i push on the bottom right corner and start the gps, it doesn't even make it...
There is a hard reset button under the sticker at the bottom of the unit. It is located directly under the check mark on the sticker. Once you get it going fully charge the unit then go to the Garmin website and register and update your 255w. I will attach the link to the Garmin Site. Thanks for using FixYa
https://my.garmin.com/mygarmin/registrationGettingStarted.htm?productType=auto&categoryType=AUTO
May 29, 2011 | Garmin nuvi 255W GPS Receiver
I have a garmin nuvi 205 which it just died on me and I cannot locate this hard reset button on lower left hand bottom of the gps under the serial in which there is only 2 screws under the serial sticker...
Hi Kyair06,
You can do a hard reset of your unit by sliding the POWER switch to the ON/OFF position and holding for 10-15 seconds. The manual says 8 seconds, but it won't hurt to do it longer. If everything is ok, it should come back from the dead.
In case you don't have the manual, you can download one here:
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
When you get the unit going again, you may want to do a software or firmware update. The Appendix around page 41 will tell you how.
I hope this helps. Let me know if I can be of further assistance. Thanks.
Regards, Bill
Sep 17, 2010 | Garmin nuvi 205 GPS Receiver
I lost the combination to my sentry safe serial numbers 4895857 had it for 10 year geting kida old can you help
Sentry Safe lost combination. First, find your Sentry Safe's Serial Number. The Serial Number is printed on the small label on the right side of safe, on paper tag near bottom hinge, below the cover plate or you can look behind the handle with a mirror. Just note your model # and the serial #.
Sentry Safes express combination research is fast with a next day Service. The email is sent the next business day with the sentry safe combination and opening instructions. Although there is a service charge it's still cheaper then locksmith drilling a Sentry Fireproof Safe open.
Jan 29, 2010 | Sentry Fireproof Safe
Screen stuck on "Serial (Top)-HP blue logo Invent (Center)-v1.08"
have you tried starting the ROM update over. if it recognizes part of the update it may give you an out back to your previous version. good luck.
Jan 19, 2010 | HP iPAQ H2200 Pocket PC
XDA Orbit Help
you need to hard reset your PDA and need to reinstall the OS..this will help you
all the best
Jan 06, 2008 | O2 Xda Orbit Smartphone
Lost password for my Imate Jasjam
HTC TyTN(Hermes,Qtek9600,JasJam etc)
Always switch off the device before to execute a full reset. The full reset is the Hard Reset of the device an to
execute it push and hold at same time both the SoftKey left and right on the front of the unit while you use the
stylus to press the soft reset button at the bottom of the device.
Sep 24, 2007 | Griffin Technology iMate - Universal ADB...
Orange SPV M2000 Pocket PC Logo
384 people viewed this question
Top Orange Computers & Internet Experts
Computer Repairing
Computer Repairing
Cosma Papouis
Cosma Papouis
Sandy Moore
Sandy Moore
Are you an Orange Computer and Internet Expert? Answer questions, earn points and help others
