Question about Vacuums
Beam central vacuum system
Green light on unit was flashing.I removed the dirt receptacle and cleaned it out.Put dirt receptacle back on and plugged vacuum hose into wall mount ,then unit turned on.When unit was on my wife pulled hose out of wall mount as I pulled power cord from outletbox. Now the light is constantly green, but the vacuum does not work on automatic, only on manual. The product is Beam and model
SOURCE: Beam Central Vac Breaker Pops
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=797869
Generic problem for all Vacuums
Posted by tinateggart1 on Jul 17, 2008
The breaker on our beam model 167 central vac popped while in use. Every time I try and restart it, it immediately pops again. What's the problem? Circuit board? Motor? Overheating?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Chances are it is the relay switch on the inside of the Beam Central Vac, if it was a motor, it would not turn on @ all. If it was a circuit board, it may or may not be turned on, but if it will turn on and then pop your circuit breaker than it probably is the relay switch. Please, check with your local Beam vacuum cleaner dealer in your area or contact the Beam website or cust serv @ the phone number listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.beamvac.com/usa/ Owner Support
Customer Service 1-800-369-2326 Phone #
Email: beam.dir-support@beamvac.com
Technical Support: beam.tech-info@beasmvac.com
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 18, 2008
SOURCE: No suction in the walls for our Beam Heavy Duty Vacuum.
Do you have any open valves? Sometimes when vacpans are installed they are left open. Check those and then the other inlets to make sure they are not open.
Also, if this unit is not newly installed, then you need to check for blockages. If the motor in the garage is winding up and running faster/harder than usual, then there is likely a blockage between the main unit and the inlet nearest the unit.
Posted on Dec 08, 2008
  • 1214 Answers
SOURCE: central vacuum power head no work
Looks like a Beam central vacuum www.beamvac.com, and a Kenmore vacuum head.
Reply what problems you are experiencing and I will try to help.
Posted on Jan 23, 2009
CorvetteKing
  • 108 Answers
SOURCE: Central Vac will not turn on.
These problems are nearly exclusively caused by a bad circut board and replacing it is the fix. Bad boards can cause many different effects so its nearly impossible to be sure. The 9v signal wire is not enough to short out an entire unit so it is unlikely the hose. If it is a direct connect system and you are pulling power from the 110 somehow that would cause main unit problems but that is unlikely at best. Sounds like a failed board to me.
Best of Luck
Posted on Jun 05, 2009
ThinkVacuums
  • 144 Answers
SOURCE: I have to reset my Beam Central vac quite often!!!
Check to see if there is a clog in the system. Something is causing stress on your motor causing it to switch off. Or it could be the motor itself failing.
First check for a clog, if you can't find anything wrong, call Beam for assistance
Posted on Aug 26, 2009
My home has a central vacuum system hook-up but no vacuum installed. My friend upgraded his central system and gave me his Eureka Mega Boss central vacuum system and the accessories, including the pow
The power head requires 120 Volts. Some hoses have a receptacle in the handle for the power head plug, and the hose has a cord at the wall inlet end that plugs into a receptacle. Some hoses have a plug at the wall inlet end that plugs into a 120Volt receptacle built into the inlet. The hose plugs into this receptacle when you push the hose into the inlet. The power for this built-in receptacle is wired with line voltage when the system is installed.
Apr 15, 2012 | Eureka 1810 Central System Vacuum
System quit working green light on
depending on the year of your machine, assuming it is the serenity blue, it may be the circuit board on the unit itself. The manual switch "should" start the machine, but if not it will be the circuit board inside the main unit.
however....
if your unit is the green one, it may be the motor inside the unit and/or the circuit board. Hard to say. I do not think that it is the motor as the circuit breaker should have popped out if it was the motor.
Regardless of the colour of the unit, if it is 5-7 years old or less, the unit should still be under warranty. home service calls and labour to install the motor would not be covered.
Good luck.
Nov 19, 2010 | Beam Industries 2775 Serenity Plus Central...
Uh70015 dirt sensor stays on green. Goes on red for about 5 seconds then green. Can clearly see the floor is dirty and it is picking up stuff.
ahh the good ol electronics on vacuums selling the product again...
not to worry, your feature is working properly, your vacuum is working fine too.
Imagine if you will making a circle with your pointer finger and your thumb. Now put a string or thread across in a straight line there. The string would be the size of the beam of light that the sensor uses. Your finger and thumb are about the size of the tube that the dirt and dust is passing by. Unless the dirt passes and cuts through the beam of light, then it will register. otherwise if it passes around the beam of light, the sensor thinks your carpet is clean.
The opposite sometimes will happen too where it will stay constant red. That means that the sensor is completely covered in dirt and will not register anymore.
Hope this helps.
Mark
Nov 11, 2010 | Hoover UH70015 Bagless Upright Cyclonic...
Carbon buildup on plug to hose causing burn
Sounds like there could be a short in the hose. Try another hose and see if that's the problem. It's too soon to have to replace the unit. Try having the hose checked out, it could be the root of your problem
Sep 03, 2009 | Beam Industries 2900 Serenity Plus Central...
The red light on my hayden 3600 vacuum won't go off
I have a 6000 and it does the same thing. I simply unplug the unit and plug it back in after cleaning the filter and dumping the cannister. That seems to reset the warning system.
Jul 06, 2009 | Hayden Industries SuperVac 6000 Central...
I got a new filter for my Beam central vacuum. How do I replace it? Do I take off the top lid of the canister?
You would not normally need to replace the filter unless it is damaged. Access is from inside the tank itself. Remove the bucket and locate the finger loop on the existing filter. Pull toward the inside of the bucket. Replace the filer by setting in it's track and snapping tight to the wall of the vac. Unless damaged you can save and clean the old filter for reuse.
Jun 10, 2009 | Beam Industries 2900 Serenity Plus Central...
The indicator lights are not working
The dirt sensor is just inside where the bag attaches. It shines a beam of invisible light across the bag discharge tube. It will always show dirty if dust gets caked on it. Try wiping the area clean. This fix did not work for me. Remove the 3 screws that hold the hose assembly to the back of the vacuum, check to see if there is a piece of hair snagged on the end of the hose. This was the case for me. When running, the hair would wave back and forth by the sensor and set it off.
Dec 14, 2008 | Kenmore 35912 / 35913 Progressive Upright...
Do you know what a filter bag looks like in a central air vac system?
The unit displayed is a Beam Electrolux central vacuum power unit. It has a 15litre dust bucket which does not need any dust bags.
If you take the bucket off you will notice a white shiny weighted bag hanging down. This is the filter. The good news is, it is a self cleaning filter.
Dec 03, 2008 | Beam Industries 2775 Serenity Plus Central...
BEAM Serenity Plus 2900 has shutdown
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. OK, there is a reset button on the unit but i think it could be that your vacuum could be clogged in the vacuum lines and that you should check all the inlets/outlets in your house with your vacuum hose - or get a vacuum cuff and go to each individual outlets and check the suction by feel - if the outlet is clogged you may have to call someone to unclogg it or by going to each oultlet the system may unclog it self -- or you can use a plumbers snake and be careful because the lines in a central vacuum are thinner than the walls in a plumbing situation or have it professionally unclogged by a priofessional. When you are using another vacuum to unclog the unit make sure the central vac is runing and to try to pull the clog apart from both directions. Below is a link to the factory for Beam and if you need a owners manuel for the Central Vac
Sep 30, 2007 | Beam Industries 2900 Serenity Plus Central...
Vacuums Logo
291 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
