Pressure Washers
Problem for Pressure Washers
Generic problem for all Pressure Washers
Briggs & stratton bpw 2700
By gcombs on Oct 29, 2008
just been given a briggs & stratton bpw 2700 pressure washer and it does not work, i have cleaned and checked the spark plug and it sparks really well, when i pull the pull cord it turns well not ceasing at all but will not fire up
Best Solution
posted on Dec 18, 2008
Very Helpful)
fulltech
Rank: Guru
Rating: 95%, 79 votes
Dear gcombs,
One small problem, which might sound silly, is to check that the tap of the fuel is open. There are other reasons why fuel does not come. I think that fuel is not coming, or on the contrary, it could be that too much fuel is entering the engine. So you must check for a choke correction(if it has one). I am blaming the fuel system, because you said that the spark plug, sparks really well. A wrong grade or type of fuel could also be the cause. Also I suggest as you are trying to start the engine and adjusting and checking the fuel system...this must be done with no load at all. So remove the gun(or open it without nozzle...but better to remove the gun, so you have both hands on machine)....and you can supply water if you want. But work and test with NO LOAD!!
fulltech.
Was this helpful?
Yes
No
Popular Solutions for Pressure Washers
Questions and Unsolved Problems for Pressure Washers
Answer
do all troy bilt pressure washers have brass pumps?
Answer
Motor stops, washer was working , full level in oil and good oil. Don't starts again, apparently... (More)
Answer
aqua pure filter has no pressure when backwashing just trickles on the backwash cycle.
Answer
i have excell 3700 pressure washer...the pump cover vibrated loose lost oil and cam melted.how do i... (More)
Answer
Where can I get seal rings and o rings for my pressure washer pump without buying an entire seal... (More)
Describe your Pressure Washers problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Pressure Washer Experts
Top Garden & Power Tool Repairmen
in Augusta, ME
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
