Question about Honeywell HZ-930 Oil Filled Compact Heater
Heating element Worked fine, then one day just stopped heating. Oscillating feature works fine. How do I test the heating element? And is there a fuse to the heating element? Thank you in advance for your help. Barbara Anne
    Sergeant:
    Champion:
  • 426 Answers
With a amp meter
Posted on Jan 12, 2010
Our 4 month old coffee maker stopped working this morning. The heating element is not operating
I suppose the warranty was 90 days too. The heating element has a thermal fuse in series with one of the element wires. It looks like s snub nosed bullet, silver in color. You can test it for continuity. If it's open, there's the cause. If it tests good the element is next to test.
May 29, 2016 | Mr. Coffee 12-Cup Programmable Coffeemaker
I have a rudd UHLA-3617JA high achiever air handeler, works fine except the electric heater will not come fan starts normally, is this a fuse/breaker or failed electric element problem, how can i tell
It is either the element, sequencer (or contactor/relay), or power to the switching element. 5KW Elements normally Ohm out @ around 10 Ohms when they are good. Everything you need to check requires a multimeter.
Jan 21, 2015 | Heating & Cooling
Hi i have a Wagner HT1000 heat gun and suddenly it stop working. The day before it worked perfectly, but the next day it just won't work. What could be the problem? i don't think that is the my...
it has a tiny themo circuit in with the winding of heating element most heater made in china cheap so be looking for a contact piece like points on your old distributor on your car ...check if Ni-chrome element did not break somewhere can be fixed ...if you are check in the states harbor freight has some as well bout $ 29.00
Oct 14, 2017 | Wagner Power Products 503008 Ht 1000 1200w...
I checked the element and it tested good. i replaced the thermal safety swith thats located above the element. the dryer worked for a while then it stopped heating again. could the thermostat on the...
See if the thermal fuse blew again as they are a single use device. If it has, you have a clogged vent line. The thermal fuse is detecting too much heat which causes it to blow (safety feature).
Dec 20, 2010 | Kenmore Dryers
I have a triple task Kenmore stove with the self cleaning feature, my oven worked fine till I cleaned it one day and now it wont heat up. I have taken the elements out and had the tested and they are fine...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Apr 11, 2010 | Ovens
Dryer will not heat
check heating element,,,and thermister
Jul 06, 2009 | GE DPSR610GGWT Dryer
Sharp Carousel Microwave Model R520-LK timer will run but carousel doesn't turn and food doesn't heat.
I also have the Sharp Carosoul oven, symptoms - fan runs, controls are fine but the turntable stopped turning and it did not heat. It was not the switches, fuse, but in fact a sagging door that misaligned with the door switches. The true cause was a warn top hinge. As a temporary fix, I adjusted the bottom hinge (3 screws underneath), straightened the door, and now it works again.
Dec 16, 2008 | Sharp Microwave Ovens
Indesit is70c dryer is not heating?
Take off the back plate of the drier to expose heating elements. There you will find two thermo switches, one with a hole in the middle of it. Push something like a pin into this hole until you hear a click. Re assemble back plate and it should work now
Feb 28, 2008 | Dryers
Honeywell HZ-930 Oil Filled Compact Heater Logo
186 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
