Question about Sony VAIO VGN-T350P/T Notebook
Need to replace fan
I am hearing what sounds like a fan trying to turn. The laptop was opened, closed and returned by a service center and that's when the sound started. I think that either a wire is hitting the blades, something is not seated correctly or I need to replace the fan (not a problem once I get in). I need help on how access the fan area. If I can get a copy of an shop manual or a disassemble manual I know I can do the repair. Any help will be appreciated.
Thanks,
Mary
  • mkunzler Oct 29, 2008
    what is your laptop model/maker..? Sony VGN-T350
    since when did you have the problem? when i received it back from the service center. before that it was working fine
    may i know is your laptop already been opened..? Yes by Sony service technicians
  • Sony Master
  • 13,433 Answers
Here are a ton of guides for diffrent sony laptops. Generally if you take one laptop apart you can figure out how to take another one apart.
http://repair4laptop.org/disassembly_sony.html
have a look around maybe you can find a similiar one from the lists that helps you, Il look them over and see if I can find your model.
Posted on Oct 29, 2008
  • Ekse Oct 29, 2008
    I think the page I sent you will solve your problem, drop me a comment if you need anything else.
    Thanks alot,
    Ekse
    Brigadier General:
  • 3,614 Answers
What is your laptop model/maker..? since when did you have the problem, and may i know is your laptop already been opened..?
let me know
  • micromaster
    micromaster Oct 29, 2008
    try this & this
    hope this helps.
  • micromaster
    also see here:
    http://www.r3uk.com/index.php/tech-tips/...
Why am I getting a high pitched scream from my HP laptop after start up?
This is your cooling fan probably. You can sometimes just clean it as it traps dust, but you may have to replace it as well. I would take it in to have it replaced so it does not void your warranty. HP Pavilion dv6000 Fan Replacement
Dec 11, 2014 | HP Computers & Internet
Dvd stays open/won't close
If your drive opens directly when you turn on your computer, I mean that you have to bring it back to a repair center (maybe where you bought it).
Nov 27, 2013 | Computers & Internet
Hello, The fan that's used to cool the internal system does not turn on anymore, causing my laptop to overheat and shut off spontaneously. How do I fix this? ~ Jordan Williams
Try to clean the fan. This means you need to open your portable system. But before you do this, make your that your computer is not under warranty anymore. If it is not under warranty anymore you have all the means to experiment. Try to remove the fan and clean it. If it does not work, you need to replace it already.
Jul 01, 2011 | Toshiba Satellite L455D-S5976 Notebook
I hear a sound from my notebook like a switch that some times every 10 second open and close?
The switch sound is because of heating of the motherboard and the internal hardware of the laptop.
You need to clean the laptop properly and another possibility could be that your laptop cpu fan is not working well. Try downloading a Speed fan utility to make it work well.
Apr 13, 2011 | Computers & Internet
When i turn it on, its blue lights come on but nothing on the screen. I am using my sister's laptop to ask. It is an HP Pavillion.
If the computers lights are coming on and the fans are turning then the computer is receiving power. Try turning the sound on to see if you can hear the Windows Startup sounds (or Mac respectively). If you can hear the sounds then it is likely that the screen for the laptop has broken. If the laptop has a Video Card (most do not) this could also be faulty. Since you can't see anything you won't be able to fix it yourself, it will likely need to be returned to HP for laptop repairs.
Mar 14, 2011 | HP Computers & Internet
My laptop turns off randomly, and gets very hot.
this like the problem is from your processor fan, change it with another one
Jan 22, 2011 | Computers & Internet
Gateway W340UA laptop - no display...
Sometimes it di happen , specialy in most laptop which is being used more frequently and longer usage, the advisable use of a laptop is atleast 2 to 4 hours then shut it off and have cool down for 30 minutes to one hour then you can used it again, unless you got a support inclined base for laptop with support ventilating fan to help down minimize the heat accumulated during the usage.
have it check your video card with the proper technician, but first try to cool down your unit and try to open it again, and if still does'nt work then have it check by the service center
Nov 03, 2009 | Gateway Computers & Internet
I am having VGN-CS190.Hearing fan noise since sometime. I bought this in the last year. Around 10 months old. Please let me know why this noise is coming. I am using Windows Vista.
I might be posting this message too late but if you're under warranty I would call Sony and have them replace the fan/heat sink unit. The guy that came out and replaced mine (model VGN-CS190) said that Sony was aware of the fan problems. Either the fans they're selling in these things are bad, or the design of the lap top doesn't allow adequate air flow and the fans are running till they fall off the bearings.
Jun 25, 2009 | Computers & Internet
FREEZER SOUNDS VERY NOISY
that because the internal fan is hiting the ice or has bad bushings you can hear the noise just with the door close because when you open the door there is a switch the one turns off the internal fan so when you close the door it turn on the fan again if you wants to hear that with the door open just open the door and push the botton swich with your fingers and you'll hear the noise
Dec 29, 2007 | Freezers
Sony VAIO VGN-T350P/T Notebook Logo
126 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
