Question about Toshiba 2060 Copier
When I copy the paper gets out white
I have a old toshiba 2060 when I copy the paper gets out white (empty)
    Problem Solver:
  • 11 Answers
The drum unit may not be in correctly. There is a good chance its not up against the developer station like it should be.
-jen
Posted on Oct 30, 2008
My toshiba 2060 copier easy printing but print paper some line missing please or broken,please solved my prob.
if white lines appear in your toshiba 2060 inaccuracies.
almbres replace the corona charging and transfer, do not forget to check the development unit if turevelador is too old replace
Feb 25, 2015 | Toshiba 2060 Copier
I have a Toshiba 2060. Runs great except for one issue. The cartridge has the paper oriented landscape with the label LTR. When I copy using the eith the ADF or platen glass and the paper is also...
As far as I know the Toshiba 2060 does not have an auto rotate function. This means that whatever drawer you pick to copy from is what the scanner will scan. To change which way you copy your sheets you will have to change the physical size of the drawer to copy the other way.
Aug 31, 2010 | Toshiba 2060 Copier
Says to empty old toner. we have done that and
The copier is most likely saying to empty out the waste toner. It has been awhile, but I believe it is up front and to the inside right of the front door. It is a milky white container. You may have to open the paper trays to open the door that covers the bottle. I would empty it out very, very carfully and return it back to it's place and that should do it for you. There may be a reset code if the copier has a error code. Good Luck....
Jun 03, 2010 | Toshiba 2060 Copier
My toshiba 2060 copier starts knocking when warming up and then show the trays are empty , do you know what it could be?
the lift motor for the paper trays is faulty or if yu pull the trays out and look behind the tray there are som connection there check there aint no paper stuck there.. if you put the trays back in on at a time you should find the one causing the problem.. my money is on the lift motor as this lifts the tray up to the paper sensor to show paper in trays..
Aug 03, 2009 | Toshiba 2060 Copier
Empty old toner
Open front cover of your 2060. Inside the copier, on the left side, there is a blue lever labeled "A". Press lever "A" towards the left while pushing down on the top of copier....this will unlatch the **** shell and allow the upper portion to lift upward. The waste (used) toner container is located in the center of front frame (semi-clear plastic). Lift upward on container until it clears the frame, CAREFULLY pour the contents into a plastic lined trash can. Replacement is reverse of removal.
Jun 05, 2009 | Toshiba 2060 Copier
Paper jam on my toshiba 2060 model
Exactly where in the machine does the paper jam??If it jams when you hit the print button, try cleaning the paper feed tires with WD40.spray it on a clean cloth, clean the feed and pickup tires thoroughly and make sure to get ALL of the WD40 off the tires before using the machine.If you take the paper cassette out and look with a flashight you should be able to identify the paper feed tires.
Mar 24, 2009 | Toshiba 2060 Copier
Leaving a black line at the top of the page
make sure paper guides are secure other then that could b dirty optics (mirrors under the glass) or drum / fusing unit
Feb 26, 2009 | Toshiba 2060 Copier
Toshiba 2060
i would buy new lazor toner 1st cartridge to see if yoru s bad or out
Jan 19, 2008 | Toshiba 2060 Copier
Lcf
THIS IS A LARGE PAPER FEED COMPARTMENT MOUNTED TO SIDE OF COPIER HOLDS ABOUT 2500 SHEETS OF PAPER WHEN IT RUNS LOW OR IS EMPTY A MESSAGE APPEARS ON DISPLAY PROMPTING USER TO RELOAD IT THE REASON COPIER WONT PRINT IS BECAUSE THERE IS NO PAPER LOADED TO COPY TO
Jan 11, 2008 | Toshiba 2060 Copier
99 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
