Question about Oster 76076-010 Hair Trimmer
3F blade, took the blade out to clean, can't get back together
I have a 3F blade that was really dirty, so I slid the little blade out to clean underneath. There is a little long plastic piece of tubing that I noticed after I removed the blade. I don't know where it belongs within the blade to slide it back under the clip.
  • 4 Answers
That's probably the blade guide. It goes on the "spring"; the piece that holds the cutting blades together.
The blade won't work without it.
Posted on Nov 06, 2008
Took trimmer apart to clean and now can`t get it together again only the blade top.?
Does the blade and cover plate for your clippers look something like the items shown at the following link:
http://www.amazon.com/dp/B001D51JW4/ref=asc_df_B001D51JW41502580?smid=A38ADCQOZZ1ZLQ&tag=dealtmp5133-20&linkCode=asn&creative=395105&creativeASIN=B001D51JW4
Sometimes you have to fit one side of the blade in first and then then force the two little holding prongs closer together in order to fit the other side of blade down too.
Here is a quick video on YouTube which shows the blade replacement procedure for a few different types of clippers:
http://www.youtube.com/watch?v=dYgN9HZDRrE
Please comment back here to this page if you have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
Thank you very much and good luck.
Joe.
Apr 12, 2011 | Health & Beauty
I took it apart to clean it but, like a dummy cannot put it back together. dog trimmer model 9765
Your style came with a DVD, can you find that??? I just can not find a manual that is in print form to assist you, sorry!!! Guy
Sep 12, 2010 | Wahl 9765-301
Inside of dishwasher was dirty after cycle, baskets had black in between the screen...took out all bottom and found dirty water, a couple of inches and slime in bottom...cleaned it all out and put it back...
Check the food grinder (small blade spins against a screen) in the bottom of the dish washer drain. I found the grinder to be inoperative and clogged which reduced / stopped flow of the wash water. Also, small pieces of clear plastic food wrap can block flow.
Sep 18, 2017 | Whirlpool GU2400XTP Built-in Dishwasher
Filter
If this one is like mine (and it looks just like it except my Lasko doesn't have the wood grain on the front) there is no filter inside. It is just a fan inside a plastic case.
If you want to clean it, you can try blowing it out with compressed air if you have a powerful enough compressor. If you really want to clean it, you will have to take it apart and that isn't as simple as it sounds if your unit is just like mine.
There are a bunch of screws on the back, which isn't too bad except one of them is a triangle headed "security screw" that is probably there to keep you from taking it apart. I looked at several stores and couldn't find a screwdriver to fit the stupid thing. So what I did was that I took out the rest of the screws, pried the case open as far as I could with my hands and cut the support that the last screw was attached to from inside with a strong pair of wire cutters.
I figured that when I put it back together, I wouldn't miss that one screw and I wouldn't want to deal with a triangle head screw every time I took it apart in the future anyway.
Once the case is apart, I found the best way to clean the blades is to remove the whole blade assembly and just wash the thing out in the tub and let it dry thoroughly before putting it back in. There's a metal brace (Held on by two screws) at the top the top spindle goes into and there's a single screw on the shaft of the motor that hold the bottom spindle in. It probably sounds more complicated than it is. It's pretty simple when you see it.
If you put it back together right, you almost can't do anything wrong. You might want to take a damp cloth and wipe down the interior of the case and the shrouds that surround the blades as well. If you've had it a while, they'll be dirty. You'll see/feel the dirt wherever it is. This thing is a pretty simple machine and is easy to clean once you figure it out. I put a few drops of oil on the top spindle when I put mine back together.
May 21, 2010 | Lasko 2554 WIND CURVE Fan
I took it apart to clean, and now I barely cuts
Make sure the blades are even. It sometimes is hard to match when you take them apart. If they are even off a little bit they don't work. good luck
Oct 11, 2009 | Vidal Sassoon VSCL828 Hair Trimmer
I took my Wahl clippers apart to clean ......
Okay I fixed mine. this is I what I did and it works now take the big blade and put it on a table, take the little blade and put on top of the big blade if you look closely at the big blade you can see where the little blade went, make sure you allign the blades. next take the white thing dont know what you call it bit it rotates the blades put that on the little blade, take the gold piece align with holes to the big blade and take the silver piece allign with holes and then put the screws back in. when you put it on the clipper make sure the white piece goes in the hole that rotates the blades and sould go in fine
Jun 08, 2009 | Wahl 8550
I have an Oster Golden A-5 clipper (dog clipper--I could not find the catagory on your list) with # 10 and # 15 blades. It has been quite a while since I have sharpened the blades, and I am not sure how...
I did not solve the problem, but I doubt if you have an answer for me.
I will just use the blades as I have put them back together, and hope they are attached correctly on the comb part of the blade. There is an area on the tension spring that allows it to move forward or backward when the screws are attached to the comb part of the blade. I am not sure exactly how to adjust it when screwing it to the comb. If it is slid back, the cutter part of the blade will be set back. If it is slid forward, the cutter blade teeth will be nearer the edge of the comb part of the blade. The cutter still rides on the rails of the comb okay, but I am sure there is an exact position for proper re-assembly.
Thank you for any help you can provide.
ajkennel
Apr 28, 2008 | Watches
Oster 76076-010 Hair Trimmer Logo
330 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
