Ricoh Aficio 1018D Copier
Problem for Ricoh Aficio 1018D Copier
Change developer for Aficio 1018
By otolliver on Oct 29, 2008
I need to change the developer for an Aficio 1018 - need instructions.
Thank you
Odette
Best Solution
posted on Jan 17, 2009
Very Helpful)
jrmicallef
Rank: Guru  Ricoh Expert
Rating: 90%, 63 votes
Open the front and right covers and remove the toner bottle holder unit.
Pull out the Photoconductor unit(PCU) with your thumb pressing on the latch on the left side of the PCU.
Separate the top part from(drum) the bottom part(developer unit), by removing the front piece 1 screw and rear piece 2 screws and 1 coupling(pull out).
Now remove 1 front screw, 2 rear screws and other 2 top rear screws to separate the top and bottom parts of the dev. unit.
Then place your finger under the front-side and rear-side flaps and push out so that the flaps pops off the peg.
Set the coupling removed, back to the shaft and turn the coupling to remove the developer from the roller.
Turn upside down the lower part of the dev. unit to remove all the developer by turning its gears.
Load new developer evenly in the openings of the lower dev. unit and pay attention not to spill developer on the gears.
Reassemble the whole PCU properly.
Reinstall back the PCU and toner unit and close the front and right covers.
Switch on the machine, enter SP mode- Clear key, 107, hold and press Stop key.
Enter SP 2-214 and execute to reinitialize the TD sensor.
Switch off and on the machine.
Good luck and please rate me, thanks.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Ricoh Aficio 1018D Copier
Questions and Unsolved Problems for Ricoh Aficio 1018D Copier
Do you recommend Ricoh Aficio 1018D Copier?
Answer
Answer
I have a brothers mfc 5840cn it will not print error message is unable to init, I have done the... (More)
Answer
Royal 1280mx shredder suddenly stopped working. No power light, no motor activity. I suspect a... (More)
Answer
canon mp530 printhead QY6-0059-000
Answer
samsung projection lamp
Answer
My canon S9000 uses my MAC OSX 10.5.8 Since I cleared a paper jam, and as far as I can see... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Copier Experts
Top Copier & Fax Repairmen
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
