Question about Sanyo DS32830H 32" TV
NTSC50 ,V-hold,Auto Sync
Does anyone know if this TV supports any of these?
    Novelist:
    Champion:
  • 275 Answers
Yup, this is a fairly High end model, and supports NTSC50, V Hold is automatic, H-Sync is also automatic
Posted on Sep 07, 2006
DGM tv is auto tuning and finding channels which are lost when the tv is switched off. I want to perform a hard reset to see if this helps, does anyone know how to do this please? Thank you
Try unplugging set while it is turned on. Then press the power button and hold down for about 20 seconds. Then replug the unit and turn on - see what happens.
If that does not work you can contact the support unit at manufacturer web site for possible assistance with your issue.
Aug 30, 2015 | Televison & Video
Lip sync
Vizio HDTV- Lips out of sync
Anyone with a new Vizio E601i-A3 60" or 70" HDTV that is having audio "Lips out of sync problems" with a cable or satellite box.
On Comcast cable boxes (or others), here's what you need to do: FIND MENU for AUDIO or HDMI setup on CABLE BOX or Satellite Box.
FOR COMCAST
1. Turn on TV and have Cable box Turned OFF.
2. Press MENU on COMCAST REMOTE.
3. Go to AUDIO Setting OR HDMI Setting. (On cable or Sat. BOX)
4. Change setting from Auto to L-PCM. (Turn off cable box to exit)
This should resolve any "out of sync" lips to picture after commercials on HD channels.
*This is a handshaking issue from the cable box to the Vizio E601i-A3
Dec 08, 2012 | Vizio 60" E601I-A3 Full HD LED-LCD TV
I own a Gateway FPD1730 LCD monitor. I am curious to know if the External button on the monitor that's called AUTO/SET is a RESET button for the factory settings?
The factory reset is in the on screen menu, the Auto set button is for syncronizing the signals to the PC video incase it went out of sync.
User manual from Gateway: http://support.gateway.com/s/Manuals/Desktops/8510137-web.pdf
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jun 13, 2011 | Gateway FPD 1730 17" Flat Panel LCD...
What do I need to connect my laptop/wii/dvd player to my Sharp Quattron Aquos Led TV? Please need an urgent answer please?
Hello
1 Press MENU to display the MENU screen, and then
press [=> or <=] to select "System Options".
2 Press [Up or Down] to select "Input Terminal Setting", and
then press ENTER.
3 Press [Up or Down] to select "PC input", and then press
ENTER.
4 Press [Up or Down] to select a specifi c adjustment item,
and then press ENTER to set each item.
5 Press [Up or Down] or [=> or <=] to select or adjust the desired
setting, and then press ENTER.
Adjusting the PC Image
Auto Sync. (for Analog PC Input Mode Only)
For automatically adjusting the PC image.
Yes: Auto Sync. starts and "Now adjusting the image."
displays.
No: This function does not work.
When "Auto Sync." is successful, "Completed" displays. If
not, "Auto Sync." failed.
"Auto Sync." may fail even if "Completed" displays.
"Auto Sync." may fail if the computer image has low
resolution, has unclear (black) edges, or is moved while
executing "Auto Sync.".
Be sure to connect the PC to the TV and switch it on before
starting "Auto Sync.".
OK.
Mar 14, 2011 | Sharp Televison & Video
I have a 32 inch Haier TV and my comcast cable remote wont work with it. I need to know how to get my tv to sync with my cable remote.
there is an auto search method....some remotes you can hold the tv button down and then the select button simultanteously for a few seconds to make the light turn red and then proceed with codes, when you get the right code you press the select button again, the light blinks and you are done..... well with out a code its the luck of the draw..... the auto search method is similar to programming the code in....hold the tv button and the select button for a couple seconds until the tv button lights up, but instead of a code.....press the channel up button(that represents the first autosearch code), continue until the tv turns itself off and then press the select button to lock it into the remote...........if you go past the trigger point you can channel down to backtrack.... otherwise drop it in the toilet until it wont work, call the cable company and have them send out a tech with anew remote. they cant charge you for their equipment not working correctly.
trust me, i am a supervisor at a major cable company.
Jan 17, 2010 | Haier HTF20R21 20" TV
My sb 600 fires with the camera but it seems not illuminate
Definately a settings problem. The camera will only syncronize on one specific speed. Youe best bet is to use auto. For manual, you'll have to set the shutter speed at the sync speed.
Flash Sync Speed
  • up to 1/250 X-Sync Speed
  • up to 1/8000 FP High Speed Sync
  • Red-eye reduction
    Red-eye reduction with slow sync
    Rear-curtain sync
    Slow sync
    Front-curtain sync (normal) Flash Sync Modes
  • 1) i-TTL: TTL flash control by 1,005-pixel RGB sensor, built-in flash, SB-800, SB-600, SB-400: i-TTL balanced fill-flash and standard i-TTL flash
    2) AA (Auto Aperture-type) flash: Available with SB-800 used with CPU lens
    3) Non-TTL Auto: Available with Speedlights such as SB-800, 28, 27, and 22S
    4) Range-priority manual flash; available with SB-800 Flash Control
  • Mar 13, 2009 | Nikon Speedlight SB-600 TTL Flash
    Sync
    While the iPhone certainly isn’t the first mobile handset to suffer from freezes, its functional breadth and the fact that many of its users install unsupported third-party applications make the device, generally, more freeze-prone.
    settings can result in a reduction in or complete elimination of freezes:
    • Tap Settings on the home screen. Tap General. Tap Auto-Lock. Set to “Never.”
    • Tap Settings on the home screen. Tap Brightness. Turn Auto-Brightness off.
    Oct 13, 2008 | Apple iPhone 3G
    Sharp 36 inch television-PAL to NTSC conversion
    to convert your tv from pal to ntsc ,find the ceramic filter value 5.0 , 5.5 or 6.0 and change it with 4.5 and . Take note that the ceramic filter of sound and video are defferent ever if it is the same value
    Jun 08, 2008 | Sharp 32C-240 32" TV
    Sanyo DS32830H 32" TV Logo
    133 people viewed this question
    Top Sanyo Televison & Video Experts
     Grubhead
    Grubhead
    Jerry Greenberg
    Jerry Greenberg
    Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
