Question about Toshiba 2060 Copier
The papers show white
The papers show
    Problem Solver:
  • 15 Answers
The Carona wire is cut. ther are two carona wires one is Main charger carona wire and another one is transfer carona wire.
Transfer carona wire is at the botton of the copier when you lift the top cover
main charger carona is in the top. it is in the drum unit.
then other may be the developer is not there (insufficient).
toner and developer mixer may be less.
for further mail me at ramanathanr@integramicro.com
Posted on Nov 11, 2008
My screen wall paper is not right. Trees are white, camera shows my vase as white. It is purple. How canifix this?
ARE YOU USING MANUAL WHITE BALANCE IF SO CHANGE SETTING TO AUTO WHITE BALANCE MIGHT REMEDY YOUR PROBLEM
Aug 22, 2015 | Cameras
When I scan a white or Blu or green line on my paper scan show
It might be that you need to clean the printer heads. Your manual should tell you how to do that; also you might be able to Google an online manual for you printer model.
Jul 04, 2014 | Konica Minolta bizhub C450 Scanner
Canon mf5650 showing red light blinking on LCD display showing change pape size
I think then you should change the paper. if you are using right paper size then you should check settings.
Mercedes Performance Chip
Aug 17, 2012 | Canon imageRUNNER 1023N Black and White...
Unable to print from canon imagerunner 3100
Select the paper source(paper tray) on the computer,select paper size.
Jan 03, 2012 | Canon Diplomat Office Equipment & Supplies
Our shop's Canon ImageRunner 3025 shows a jammed paper error, but there is not jammed paper in the copier that I can see. So what else could be triggering this jammed paper error? Thanks, Seth
You need not to pannic.Those paper jams are always there... What you need to do is to check you paper arrangement in papers tray sometime rough arrange may led to paper jams everytime
Thanks
Omari Saburi
Mar 04, 2011 | Canon ImageRunner 3025 Black and White...
Im having a problem with my canon mp 510 scanner, the problem is when i go to scan a piece of white paper with black writing on it, it reverses and shows me on the computer black paper with white writing...
this could be because.. in the printer preference / properties .. you have the option of Mirror printing../mirror image.. so, pls uncheck/disable that.
Also make sure that you are keeping the paper face down , correctly on the slot provided ..
Sep 07, 2010 | Office Equipment & Supplies
My colour print has a white patch
this could be as a result of the machine not being set up for the xerox paper you may need to set up a tray as thisck paper or colour special paper as the machine is running at full speed and needs to slow down for the fuser to be able to work properly on the different paper the toner is not fusing properly to the page. check your paper type settings and if neccessary use the bypass or maunual feed tray.. Good Luck A
Jan 16, 2009 | Office Equipment & Supplies
Paper jam flasher
Henry, try blowing it all out with compressed air to clear jamb.
Nov 27, 2008 | Canon NP 7130 Black and White Copier
Black cardstock
There is no white ink in the printer. White needs to come from the paper.
The inks in your printer can only make your paper DARKER, and you can't get any darker than black.
Oct 08, 2008 | Lexmark P6250 All-In-One InkJet Photo...
42 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
