Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
  • 1 more comment
  • etrepicefine Nov 15, 2008
    i have the same problem. the door goes up about half a foot and then stops. When i push the button, it closes and then goes up again half a foot. Help!!!!!
  • sajjadC Nov 18, 2008
    Yestrday, my door wouldn't go up. I had to help it go up. If I disconnect the door, the chain moves. Maybe it cannot take the load or the motor need some maintenance?
  • rssistrunk Nov 18, 2008
    Press the button, goes up about 2 feet. Multiple tries eventually get the door to raise correctly.
I also had the same problem with a liftmaster garage door opener. The garage door stopped about two feet off the floor and would not open any further. I inspected the screw drive position where the door stopped and decided to use a lubricant like WD 40 to lube that area of the screw drive. After doing this the door starting working and as an added benefit the operation of the door became much quieter.
Problem solved!!! All the screw drive needed was some lubricant. I checked the operating manual for this opener and didnot find this solution there.
Take care,
Posted on Nov 19, 2008
this solved the problem I could not fix for 2 years. A little WD40 on the screw drive did the trick.
Posted on Dec 22, 2008
The garage door hums for a few seconds and then stops, the door won't go up or down.
Make sure the trolley isn't jammed against the bolt just in front of the motor.
Oct 29, 2011 | Sears Craftsman LiftMaster Chamberlain...
Hi I have a Chamberlain garage door system. I use the remote to shut the door. The door goes down to a foot off the ground and goes back up again. I've tried for over an hour to get it to shut and it won't...
The motor has probably been shut off by the thermal protector. Wait 15 to 20 minutes and it will reset itself.
If when the door reverses and goes back up, the main light flashes 10 times it is a door sensor problem. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a bit. If you cannot get both lights to come on you have a bad sensor.
Feb 18, 2011 | Sears Craftsman LiftMaster Chamberlain...
Problems opening garage door on cold mornings
If you have used grease on any part of the door hardware or tracks you will have to clean it all off. The recommended lubricant for the hardware is silicon spray and nothing at all on the tracks. You can also increase the up force which you will find on the rear of the motor unit near all those white wires.
Nov 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
When I push the button it only runs for 1 sec and stops...even with the door manually removed from the track system..I have a craftsman 139.53603 opener.
my craftsman garage door open about one ft and stop when i try to push the wall button or the remote pad it completely stop working
Oct 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman - chain drive. now open won't travel more than 1 ft.
Sounds like you have a bad RPM sensor board. This is a small printed circuit board just in front of the motor.
Sep 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener doesnt close all the way.
The motor is probably either stalling because the door is too stiff, or you have a beam break detector that is being triggered when the door is halfway down.
Nov 23, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Chamberlain Liftmaster Professional 1/2 HP
Okay...upon further inspection, my left spring has broken in two. Going to call around for some quotes to replace the spring. Thanks for the suggestions.
Jul 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,116 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Are you a Sears Building Material Expert? Answer questions, earn points and help others
