Question about Brother IntelliFAX 4100 Laser Fax
SAMSUNG SCX-6322DN Error code MM_freeblk.c351jsta keeps coming up. Will not let customer print. Any suggestions? Thanks
2 Suggested Answers
SOURCE: scanner locked?
On some models there is a transport latch to lock the scanner. Look under the scanner (where the copy comes out) and you will see a green slide. Look down thgrough the scanner glass and you will see a lock/unlock symbol.
Posted on Jul 16, 2009
Problem on my All-in-one
Replace all electrolytic capacitors on the secondary side of the power supply board. Or replace the power supply board.
Jan 04, 2012 | Samsung SCX-6322DN All-In-One Laser...
How do i do double sided printing on a multi express 6322dn
hello
these two links will help you figure out HOW TO PRINT DOUBLE SIDE COPY
it is all in the control panel on the printer--very simple to use
http://downloadcenter.samsung.com/content/UM/200910/20091027131536375/Guide_EN.pdf
manula in PDF
http://www.samsung.com/ca/support/detail/supportPrdDetail.do?menu=SP01&prd_mdl_cd=SCX-6322DN/XAA&srchword=SCX-6322DN
Samsung side to download
please help me keep my job - send me 4 thumbs up
Aug 23, 2011 | Samsung Office Equipment & Supplies
Samsung SCX-6322DN power to display "system
Dear
Try to re assembly all harness terminated at main board, Test the machine on toner cart and drum cart opened. System not initialized, check the main board.
Thanks.
Apr 02, 2011 | Samsung SCX-6322DN All-In-One Laser...
Hi Everybody, My 6322DN says "printing...", you
First ckeck the line of the telephone,put another printer and see if you recive the fax on other printer.If you not recive fax possible fax board may be faulty.
Mar 16, 2011 | Samsung SCX-6322DN All-In-One Laser...
My copier keeps flashing open heat error! What does this mean?
your thermostat has blown on your fuser. you need to replace the main board and the fuser. this is a pretty common problem on the samsung scx-6322dn which is practically the same machine.
Dec 15, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Missing the manual - how to collate??
By using the Duplex button on your machine, you can set the machine to
print copies on both sides of paper.
1 Press Duplex.
2 Load originals face up in the ADF.
3 Press the Scroll buttons until the binding option you want appears.
Off: Prints in Normal mode.
1->2Side Short: Prints pages to be read by flipping like a note
pad.
1->2Side Long: Prints pages to be read like a book.
2->1Side: Scans both sides of the original and prints each of them
on separate two papers. (SCX-6322DN only)
2->2Side: Scans both sides of the original and prints them on both
sides of a paper, this function produce exactly the same print out
from the original. (SCX-6322DN only)
2->1Side Rotate2: Scans both sides of the original and prints one
of them on separate two papers, but the information on back side
of the original is printed 180° rotated. (SCX-6322DN only)
4 Press OK to save your selection.
If the mode is enabled, the Duplex button is backlit.
Collation
You can set the machine to sort the copy job. For
example, if you make 2 copies of a 3 page original,
one complete 3 page document will print followed by a
second complete document.
1 Press Copy.
2 Load originals face up into the ADF.
For details about loading an original, see
page 5.1.
3 Enter the number of copies using the number
keypad.
4 Press Menu until Copy Feature appears on the
bottom line of the display and press OK.
5 Press OK when Copy Collation appears.
6 Press the Scroll buttons to select Yes.
7 Press OK or Start to begin copying.
One complete document will print
http://www.websitetoolbox.com/mb/copierquestions
Jan 23, 2009 | Samsung SCX-6322DN All-In-One Laser...
Samsung scx-4521 f
if it's a vertical line in scanned pictures, it's probably a dust bunny on the scanner head, if it's only on printed pages, it's probably a dust bunny on or in the laser assembly or between the laser and the photosensitive drum. if cleaning doesn't get rid of it, you could have a defective scanner head or laser assembly, or a scratch on the photosensitive drum.
Jun 27, 2006 | Samsung SCX 4521F All-In-One Laser Printer
Brother IntelliFAX 4100 Laser Fax Logo
157 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
