Question about Linksys Wireless-G Broadband Router
No internet with wireless laptop
I am unable to connect to the internet with wireless laptop even though the router signal shows up very strong
  • 1,031 Answers
Could be that the laptop's encryption settings are wrong and it cannot perform the DHCP and thus may reverts to 169.x.x.x which is called "auto-IP"
Posted on Oct 29, 2008
  • Starnley Johnwells
    Starnley Johnwells Oct 29, 2008
    Normally the ip assignment is when the DHCP server or NAT device doesn't assign an IP address and the PC automatically assigns the Private IP number that goes to no where.
    Double left click on your Wireless connection if you use the Windows Zero configuration Utility, left click on properties, Double Left click on Internet Protocol (TCP/IP) and make sure the top box has a dot in the Obtain IP Address Automatically and Obtain DNS Server Address automatically.
    If these are OK, you may need to ethernet in to the router to see if the DHCP tables are full on your router. If all IP addresses have been pulled that the router can assign and they haven't expired yet, you may not be able to pull a new IP. This would only happen if someone has changed the number of IPs the router could assign out which i dont think so in your own case if the problem still continues then give the TCP/IP interface a new set of addresses. change the settings to "receive DHCP automatically", hope this helps.thanks and God bless do let me know if you need further help
    Genius:
  • 1,550 Answers
You need to configure your wireless router .
Did you configure properly ?
    Brigadier General:
  • 3,614 Answers
May i know whats your router model and also your laptop, the OS that has been installed also there.. and add more info regards to your problem.
thanks
  • micromaster
    micromaster Oct 29, 2008
    for a initial info/solution try to reset your wireless router. you can see a small hole on either right or left area, a paper clip will do to reset the pin inside.
I cannot get internet on my laptop from an open access point with Time Warner internet
Though you are getting strong signals from the router, the router itself may not be connected to the Internet. The owner may leave the router on but power off the modem. It is possible that they may use the router for thier own private network with no connection to the Internet. When you connect to the router, check your network and sharing center to see if you see an X marked on the connection between the router and the Internet. If you do, the router is not connected to the modem.
Good Luck
C2Solutions
Feb 14, 2012 | Computers & Internet
I have an Linksys Wireless G WRT54GS router. I
This is strange... Never heard of it in all my years. Call Linksys www.linksys.com and then ask them becuase this is rare. If they can't find a solution just steal the internet :)
Oct 13, 2009 | Linksys Wireless-G WRT54GS Router...
Trouble connecting to wireless hub
The wireless router you have may need to be configured to your laptop.Call the router manufacturers customer service and they should be able to tell you what to do to get it to work.
Sep 06, 2009 | Acer Aspire 5500 5570-2609 Laptop
On a Dell Latitude - no internet connection
The fact that the lights are on and that you get wireless signal means that the computer is making a connection with the router, but the router is not making a connection to the internet.
Try a sequenced power-cycle. Turn off the computer (completely off, not hibernating or sleeping), then turn off your modem (if you have one) and finally turn off your router.
Wait 5 minutes and turn it on in the backwards order. First the router, then the modem and finally the computer. If it's still not working, contact your ISP's tech support, there's probably an outage in the area or another problem with your internet service,
Aug 03, 2009 | Computers & Internet
No internet access with new Linksys wireless PCI Adapter
Don .bin is a firmware that can upload to the linksys router or any router.
So it seems that your unable to connect wirelessly using the linksys adapter? The Internet connection before is working properly?
*I might advise you to reinstall the driver of your wireless adapter using the latest driver that you can download in there support site.
- Check the Internet connection hardwired to the router if connection works it seems that problem is on the adapter.
Mar 07, 2009 | Linksys Rangeplus Wireless Pc Adapter
Can't connect my Ipod touch to my router?
did you setup a wireless network ? if you didnt go to control panal and then wireless network setup icon and follow instructions (select automatically provide network key option) then follow instructions and finish. once you did that, search through wifi on youf phone it should find your WNetwork and then connect and enjoy. if you want to use internet and have an ADSL modem, make sure that the modem is connected to the internet RJ45 plug on your router. and from router to PC.
good luck, i hope this helps
Dec 30, 2008 | Linksys Wireless-G WUSB54G 802.11g/b
Check to be sure that your network connections are set to automatic(control panel->network connections then right click on your wireless connection go to properties- tcp/ip click on that and check there.
Oct 29, 2008 | Linksys Wireless-G Broadband Router
Strong signal but no connectivity
ya thata right even if u move ur laptop upto 50 feet that will show the speed is good>and try this one try to change or upgrade the driver for ur pcmci card>and change the channel on teh w/l router try using 1>or 11>and rate me solved if its help full
Oct 23, 2007 | D-Link DI-624 Air Plus XtremeG Wireless...
Linksys Wireless-G Broadband Router Logo
96 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
