Question about Asko Dryers
Asko dryer 7005
My asko dryer model 7005 runs but is not heating the drum. I alresady checked the two fuses in the rear. Thanks
  • 5 Answers
SOURCE: asko 7005
Go reset your circuit breaker. Even if it didn't pop out, reset it.
Posted on Dec 14, 2008
rogrrabbit
  • 986 Answers
SOURCE: Asko dryer 7005 will not start. When I touched
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a broken door latch, a bad door switch or even a broken door switch actuator, in a dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down.
Posted on Nov 22, 2009
Testimonial: "It was the fuse."
Nicesuit
  • 61 Answers
SOURCE: Asko dryer model#7005 when i start the dryer i
Hi There, Sounds like there is a relay switch that may be faulty, the power should latch on when you press the start button, I am unsure of this model type, but usually there is a small PCB inside the unit behind the facia, remove the top to expose it, and you can either replace the PCB or replace the relay the latter being cheaper but more work as you will have to reflow and solder the relay
Posted on Dec 07, 2009
rogrrabbit
  • 986 Answers
SOURCE: asko 7005 dryer is making a strange sound while
All dryers have to have a way of allowing the tumbler (that's the thing you put the clothes in) to turn freely, not all of them are the same tho,some use bearings, some use slides,others use rollers. Over time these rollers will need to be oiled,the slides will get thin and start metal to metal contact causing a noise, The rear bearings will then start to make their way to china and cause the tumbler to rub into the heating element and OUCH! These things will cause the motor to prematurely DIE! Its best to examine the dryers, rollers, and slides when you first hear the noise, but who does?
Posted on Dec 23, 2009
Macmarkus
  • 2605 Answers
SOURCE: I have a 7005 asko dryer and it is not drying
Hi, Sorry you have had to wait so long for an answer or possible solution. Hopefully it's not too late. There are two things to look for on an Asko dryer that is heating & tumbling but not drying ( since you've indicated the lint screen has been cleaned ) 1) a clogged vent...however this doesn't seem likely since you have heat & a poor vent usually trips the manual hi-limit reset on the heater housing in back. 2) a loose or broken exhaust blower wheel...this IS most likely and I've come across quite a few. The squirrel cage type blower has a "D" shaped shaft which fits to the shaft of the motor and is held there via a single nut. Over time or use, the blower will stripe the "D" shape shaft which enables it to not move the exhaust sufficiently, hence the items do not dry properly or as they once did. You can chrck this by pulling the access panel off followed by the plastic covering ( exhaust housing covers ) to expose the blower wheel. If it spins freely and independant of the motor, you'll need to tighten it or, more likely need to replace it. Hope this was helpful in solving your problem. Thanks for coming to "fixya" and let me know if I can assist you further. Good luck. Macmarkus :)
Posted on Apr 04, 2010
My asko dryer 7005 works the heating element but the drum d,not turn
broken belt , defective timer, defective board if electronic, defective push button start switch, defective cintrifugal switch in the motor itsself, defective motor, foreign object blocking fan motor in housing, stuck drum rollers.
Mar 02, 2012 | Asko Dryers
Asko 7005 dryer, start capcitor is cracked and has hard goo coming out the side, dryer wouldn't start and stay running, now it won't start at all. Could the capacitor be the problem or do you think...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 17, 2011 | Asko T781 Electric Dryer
My asko dryer 7005 works but there is no heat. Do you think the heating element needs to be replaced? Thank you
Hello & Welcome to FixYa
If you have already tried cleaning the vent then the problem is with the Thermostat. When the thermostat goes bad it cannot be reset and replacing it is recommended repair.It is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test it for continuity before replacing, if thermostat reads continuity then please get back to me if you have any other questions.
Kevin
May 22, 2011 | Asko T700 Electric Commercial Dryer
7005 dryer will not start when i push the start button
Welcome to FixYa.
I don't know how far you've gone since posting here four hours ago at FixYa but I can tell you 2 of the most likely reason your Asko 7005 dryer will not start.
The first place I'd direct you, would be at the back of the dryer to check the fuses, there are two 15A - 240V slo-blow fuses. In fact both possibilities will be confimed or dismissed at the back of the unit.
If you look at the back as I alluded to by the power cord you'll see two small gray disc/button looking items, these are the fuse holders. You should see this...
i.e.
**Be sure to turn off the power to the dryer or unplug it from the wall before performing any service suggested here please...safety first**
To access and check the fuses, you'll need to remove the holders. To do this requires only a flat screw driver, or even a butter knife and a multi-meter or "OHM" meter to check them.
(Alternately you can switch the fuse with a known good fuse to verify if it is blown )
Insert your tool of choice into the slot in the holder and turn it 1/4 turn counter-clockwise (right) and the holder should be in the position to remove...it may require some giggling to get it out as they have been known to get "stuck" from heat.
Once out this is what you should be presented with...
i.e.
If you remove this fuse from the holder and measure the continuity, you'll know if it is any good.
The other possibility I spoke of is the hi-limit cut out thermostat. It is also located at the back of the dryer.
This is what to look for...
Oct 02, 2010 | Asko T700 Electric Commercial Dryer
Asko dryer has no power.Washer ok
By-passed fuses,dealer said he's done hundreds.Saved me a service call.This is the 1st and only problem we've had in 10 years! We love our Asco.
Feb 16, 2010 | Asko Dryers
Nov 22, 2009 | Dryers
Asko 7005
Oct 25, 2008 | Dryers
Asko 7005 and washer 10505
1) there is a reset button on the back panel of you dryer it is in the middle black rubber...
2) you really can't the asko washer needs a 240v to run... You can hire an licenced electrician to wire a 240v plug for your asko washer if you do not want to plug it into the dryer
Jul 01, 2008 | Asko W6021 Front Load Washer
Dryers Logo
147 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
