Question about Kenmore 72056 Air Conditioner
Need help how do you get the front off of unit?
Removing unit
To remove, you will need to remove four bolts on the top of the unit.
Unplug it first, then remove the two bolts nearest the wall first. It would help to place something under the front of the unit about two inches shorter, to catch the unit as you remove the front bolts. The bolts are long, so be prepared for a lot of turns. A ratchet helps. The unit will lower in the front as you remove the last bolt. There is a bracket screwed to the wall behind the unit, with a lip at the bottom that holds the back of the unit. After the front has lowered, lift the back up about an inch, and pull the whole unit away from the wall. Remember to pull the power cord out of the cabinet before moving the unit away. Hope this helps.
Jun 14, 2014 | Kenmore 62702 Microwave Oven
Turn signals won't work
the flasher unit maybe problem but you need all lights working like brake lights.
if flasher light stay on front and rear then the flasher unit is defect or no power to unit have a look
hope it helps rate it
Oct 05, 2013 | Pontiac Firebird Cars & Trucks
Printer says drum error see trouble shooting and maintenence care in manual. I have replace toner and drum
Drum Error:
The corona wire on the drum unit
needs to be cleaned.
Clean the corona wire on the drum unit.
(See Cleaning the corona wire on page 122.)
or
The drum unit has reached the
end of its life.
Replace the drum unit.
(See Replacing the drum unit on page 130.)
and/or
Open the front cover
press Clear/Back
Press Start, then 00
after the screen show "accepted"
close the front cover and you are good to go.
Oct 27, 2010 | Brother Tn650 AllInOne Laser Printer
My truck smells like anti-freeze and the left side of the windshield fogs up... the defrost only blows hot air on the passenger side. Ive been told by two shops that I have to replace the heater core... I...
You need to replace the front one, that one sit under the dash, your truck has front and rear a/c and heater, the rear heater core is for the rear unit, that heater core is to give you heat for the rear unit, that heater core sit in the rear of your truck inside on the side, that one don't have anything to do with the front one leaking, order the one for the front unit. hope this was very helpful.
Aug 18, 2010 | Chevrolet TrailBlazer Cars & Trucks
Hi, I need a spare wheel for one of the back wheel for my Quinny Buzz Three wheel. Where can I get one?
You can buy all the types of buzz wheels (front 3 wheel unit, front 4 wheel fork unit, front 3 all terrain air inflated unit and rear wheels) direct from Dorel, go to http://www.dorel.co.uk/contact-us/ or Tel: 01842 763281., they are always super helpful and very nice. Or you can buy them from this retailer (which I found to be a good deal cheaper) http://babyequipmentcomplete.com/main_site/main/index.php?pge=check or on ebay which are definitely more expensive for new wheels, but perhaps not for used ones. Hope this helps.
Apr 06, 2010 | Quinny Buzz Three Wheel Stroller
I need a new front wheel for my quinny buzz, where can i buy ibe that isnt ebay?
You can buy all the types of buzz wheels (front 3 wheel unit, front 4 wheel fork unit, front 3 all terrain air inflated unit and rear wheels) direct from Dorel, go to http://www.dorel.co.uk/contact-us/ or Tel: 01842 763281., they are always super helpful and very nice. Or you can buy them from this retailer (which I found to be a good deal cheaper) http://babyequipmentcomplete.com/main_site/main/index.php?pge=check. Hope this helps.
Mar 13, 2010 | Quinny Buzz Jogger
All the refrigerant and compressor oil blew out the front of my '92 300zx twin turbo while trying to re-charge the a/c with a diy kit. I noticed the leak was coming from the front of the car just behind...
For starters that's not the sending unit it's the compressor and you have blown out the front seal. Your going to need to replace the compressor and when charging the system be sure to monitor the pressures from both discharge and suction side. This is very important because when the discharge pressure gets too high it blows out the front compressor seal. Hope this helps. Good luck.
Aug 11, 2009 | 2005 Dodge Durango
Need to reset samsung dvd vr357
With the unit on, hold down the FFW and RW buttons TOGETHER. Do this in front of the unit, NOT ON THE REMOTE CONTROL.
The unit should either open the tray or say REST OK on the front panel.
Hope this helps!!
Jun 25, 2009 | Samsung DVD-VR357
Oil leak at front of motor near oil filter, but not the filter
get out your light and rag and get it wiped down good and also make sure your oil sending unit is not leaking .. After you have wiped it down good run engine to see with a light to see if you can see just where it is coming from.. Front seal or sending unit is likley Holler if you need more thanks Jerry
Jan 30, 2009 | 1990 Mitsubishi Montero
F H displayed on front
it means no water is entering unit,,,check hot and cold hose,,,clean your inlet screen ..look for a kink in your hoses,,also check and make sure water is leaving unit,,if water isnt leave than ,,unit will not let water in ,,in case of an overfill..if you need help cleaning pump filter let me know...onthejob
Jan 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 72056 Air Conditioner Logo
24 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
