Question about Motorola Mobility RAZR V3
My Nokia 6230i screen wont show
I have a Nokia 6230i and everytime I switch it on it lights up and everything but then it doesn't show the actual writting and when you enter you pin it shows the xxxxx but then when it's actually on it will only show certain things and everything else just black, What do I do?
  • hustler210 Oct 30, 2008
    But isn't that the same as going to the shop to get it fixed? Cant I jus type in some master reset code and hope it works?
    Problem Solver:
  • 7 Answers
Change the lcd.
Posted on Oct 30, 2008
  • wennie91078 Nov 21, 2008
    well,on that problem,u cant just dial your pin code,you said its all black,.its because some parts are loss connect,its we called FLAKES (ribbon from LCD to BORD.) or try to find the shop with a free chick up.hope you' find a solution for your problem.
Nokia 6230i security code
The best solution for your mobile is to do a master rest. It would restore your phone to default factory settings as you expected. You can get a free master reset code for Nokia 6230i from www.unlock-free.com/nokia-master/nokia-6230i.html just submit your IMEI number here and the free code will be provided to you.
May 17, 2012 | Cell Phones
What would happen if i restore factory settings on my nokia 6230i
yes you will lost it, and everything that is saved on your phones memory
Dec 14, 2008 | Nokia 6230i Cellular Phone
N 73 screen
remove the memory card and try it work's properly. after u just insert the memory card i likely to be working.. better u need to format the memory card..
Sep 06, 2008 | Nokia 6230i Cellular Phone
Display problem
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is your solution! Please vote!
Jul 30, 2008 | Nokia 6230i Cellular Phone
Unlocking code for 6230i
i neeed help to take my code offf
Jul 12, 2008 | Nokia 6230i Cellular Phone
Nokia 6230i my screen keeps going blank
remove MMC from ur mobile,then switch on ur mobile then press restore key that is *#7370# after inserting this u have to enter 12345 as factory code, then it will start
Jun 16, 2008 | Nokia 6230i Cellular Phone
Nokia 6230i
Yes, i got nokia 6230i with the same problem, that is the only minus of this model everything is great except from the volume
Mar 13, 2008 | Nokia 6230
Tranfer of contacts from Nokia 6230I to new phone
How about getting another Nokia 6230i and then using the functioning 6230i, do the same steps in transferring the contacts to your phone. :)
Feb 20, 2008 | Nokia 6230i Cellular Phone
Showing not charging display on screen when we hold for charging the mobile.
cause of the fault sometimes is in the charger it might not compatible with your phone try to use another charger, if the fault remain, refer it to service personel, I suggest it is the charging pin problem try to replace it, or maybe in battery terminal should fix the contact to battery.
Jun 22, 2007 | Nokia 6230i Cellular Phone
Motorola Mobility RAZR V3 Logo
81 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
