Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Error Message C-2253
I am getting error message C-2253, it says malfunction detected, call your tech rep. It came out of nowhere, was working fine earlier. Please help...
  • Stephanie Oct 31, 2008
    Had someone look at it. Found that the 'board' and motor were bad, both needed to be replaced, about $1700 in parts alone. Ugh. Thanks anyway
Nightangel is right on this one, almoust all of the cases whit that malfunction is becouse the IU's are transported or stored wrong and all the developer inside it is packed together in one side of the IU, try to shake it and turn it by hand.
Posted on Nov 27, 2008
Caution: machine trouble, service call c0500 i'm using bizhub 160
Posted on Dec 10, 2008
    Champion:
  • 214 Answers
C2253: Color PC Drum Motor’s failure to turn
try to turn these IU's manually, and reset the error, sometimes helps, because usually motors works fine. also you may try to change IUs
Posted on Nov 12, 2008
  • jeffrey687
    jeffrey687 Sep 12, 2012
    How do you reset the error?
Di550 error code
1. Run "Hard Disk Format" selected in the following sequence: Tech. Rep.
Mode  Function  Image Memory.
2. If the same malfunction persists, change Hard Disk Drive.
3. If the malfunction is detected a third time, change Memory Board.
service mode :meter count, stop 00 stop 01
Jan 22, 2014 | Konica Minolta Office Equipment & Supplies
Malfunction Code C0400
You might try Googling the copier name, model number and/or any error code message you receive.
Nov 11, 2013 | Konica Minolta Office Equipment & Supplies
I see this message on the screen. A malfunction was detected. please call technical Rep code: C0200 what should i do if i don't want to call?
Code C0200
Description
PC Drum Charge, Image Transfer, Paper Separator Corona malfunction
Detection Timing
The leak signal (SCD) turns ON after the PC
Drum Charge and Image Transfer/Paper Separator
Corona output has been turned ON.
Try this:
C0200: Corona Malfunctions
Relevant Electrical Parts
  • High Voltage Unit HV1
  • Master Board PWB-A
Jul 06, 2011 | Minolta EP4000/5000 CS/PRO Copier
Minolta Di3510F indicated malfunction error with code COBAO. Can anyone help?
COBAo = Elevate mechanism malfunction.
The exit tray home position sensor is not blocked even after the lapse of a given period of time after the tray has started moving up.
An encoder clock input is not detected within a given period of time during operation of the tray.Check the sensors,motors and his connectors.
How to reset:
1. Press the trouble reset switch on the Tech.Rep.Setting Switches Board to reset the following malfunctions:scanner,fusing,exposure related malfunctions and C3FF.
2. For any other malfunctions open and close the front door or turn OFF and ON the power switch.
Aug 07, 2009 | Minolta Di3510f Bizhub Copier
Error c12c0 in minolta di 550
C12CX (X is any value) deals with the hard drive
1. Run “Hard Disk Format” selected in the following sequence: Tech. Rep. Mode - Function - Image Memory.
To enter Tech Rep Mode:
1. Press the Utility key.
2. Touch Meter Count.
3. Press the following keys in this order: Stop - 0 - 0 - Stop - 0 - 1.
4. Select Tech. Rep. Mode.
Oct 28, 2008 | Konica Minolta DiALTA Di200 Copier
Error c12co in minolta di550
Minolta Di520 - Request of Refund
I understand now, unfortunately i didn't do the live chat nor am i paid for helping, just like you i came acrossed this site and thought i'd help a few people by donating some spare time.
I am however an IT engineer and am familiar with your copier, as i suggested earlier reset the tech rep switch and see if it clears your error.
I suggest you contact the site for your refund.
Regards
May 19, 2008 | Minolta DiALTA Di520 Laser Printer
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
2,063 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
