Question about Zenith C32V36 32" TV
No picture or sound
Had tv on, then the picture went into a vertical line then had a burning smell from the back, now when i try to turn the tv on all i hear is a clicking sound, unplugged the tv for 3 hours, then tried to turn on with same results nothing but a clicking sound.
  • Anonymous Nov 15, 2008
    TV was on then picture went out, came on for a few seconds and went back out. Unplugged it off for a few minutes, plugged back in heard a click inside and still no picture. Did the samething a day later with the same results.
    President:
  • 3,130 Answers
If you had a burning smell, well the board is toast. These sets are made to replace the entire board at one time. Before installing the replacement module, the picture tube should be checked. A defective picture tube ( such as a G1 short) may cause a failure in the power supply section.
Posted on Sep 07, 2006
What causes my LG 55LS4600 55" tv to have sound but no picture.
It is a common problem for the LG model. The problem
is defective LED back lights ASSY. You have to open the display panel & replace the burned LED strips.
Jan 13, 2018 | LG Televison & Video
There were lines at top of TV for sometime then today TV just shut off by it self and burning smell was apparent. Tried turning tv back on and just got souns and a bright line through center of TV. My...
you have a vertical problem . You will need the chip or IC. please check the voltage source to the chip(IC). Diode could be short. Ic had bad solder joints and there are 2 caps that will need to be replaced 100uf or 220 uf caps in the vertical circuits.
Nov 04, 2010 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
ASTV3619WS went pop and burning smell
replace capactors on mains power board they will have raised tops and look like little batteries with white kine on one side replace with same value e.g (2000.mf 25v) make sure line is on same side take picture to help
Dec 16, 2009 | Televison & Video
I have a 50803 projection tv. The picture went out. It started with a green tint and lines going across it. I turned off the tv and then turned it back on. Now there isn't any picture at all. There was...
This is very simple to repair if have burning parts smell,replaced parts that burning smell,the parts that cause by the burning smell part,make it to dies that hard to find.My sugestion replaced the DM power board,first to get power back,than go on from there.
Dec 12, 2009 | Mitsubishi VS-50803 50" Rear Projection...
TV has sound but the screen looks like it is going out has double, colors green, yellow, red. Went off by itself once. Wavy looking. Smelled burning in back, when it went off by itself.
you're describing a power convergence amp problem, usually starts out at random color shdes or gohsts around the images more noticeable on scenes with letters or horizontal and vertical lines. the power amps overheat and sometimes will short out causing the fusible resistors to burn out. these amps are usually mounted on heavy metal dissipation units in one of the main boards.
Jul 30, 2009 | Samsung Televison & Video
Screen black no sound or picture with line in center
this is a common problem,the vertical hold has been damaged.dont leave the teli. on,the white line will burn the middle of the screen and leave a black mark. You need a new integrated circuit(i.c.) for vertical hold.
Mar 17, 2009 | Televison & Video
Polaroid ttm-2401
To me, sounds like a picture tube issue. horizontal / vertical controls don't fix it. then its dead.
Jun 22, 2008 | Polaroid TTM-2401 TV
No Picture
are you getting one bright horizontal line with sound.
if it is a case
then your problem is in vertical section
but remember to minimize brightness to avoid screen burn.
check
  • supply to vertical section
  • loose contact or print break in vertical output section.
  • any capacitor or low value resistor failure in vertical output section.
  • connector loose which is going to deflection coil.
  • vertical ic might be faulty.
  • hope this will help.
  • good luck
Oct 14, 2007 | Televison & Video
Vestel - 5555M TXT - Sound ok but no picture.
The fact that you smell something burning tell Us a part is cooked,sometimes is easier to find them because you can see they are degraded,this things happen for no reason but I dont think is the picture tubes that went bad,by the description it might be something simple,if the picture quality was good before is likely worth repairing it.The repair will involve removing the defective part and then soldering in the new one,be safe and call for assistance from a servicer at least for an estimate.
Oct 09, 2006 | RCA P46924 46" Rear Projection Television
Zenith C32V36 32" TV Logo
171 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
