Question about Canon PIXMA MP210 Photo All-In-One Printer
Canon pixma mp170
Came up first paper jammed, but no paper jammed. now says check printer 5100
  • 412 Answers
Ok.....---
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Posted on Mar 09, 2009
Turn on machine & alarm immediately comes on. Flashing check printer 6000.
Are the cartridges in working order. I had similar problem with another make of printer when printer lights kept flashing and one of the cartridges was defective.
Feb 26, 2014 | Canon PIXMA MP170 All-In-One InkJet...
If i want to print, my printer says chek printer and than 5100. If got a canon pixma mp170
Hi There
Please Do mention below trick to resolve your 5100Error.
  • Turn of your Printer and remove the all connected wired, open the door and checked any Paper Jam is there, because the Jam paper blocked the Ink Cartridge.
  • After try first if you get same error then remove the Installed Cartridge and put again at proper, may now you don't get any error for printing .
Thanks to Visit on Fixya
Oct 12, 2012 | Office Equipment & Supplies
My canon pixma MP170 keeps telling me that ther is
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Dec 30, 2009 | Canon PIXMA MP170 All-In-One InkJet...
5100 ERROR
As per the manual...
Service error 5100 is displayed
Cause: Movement of the FINE Cartridge Holder is blocked.
Action: Clear the paper jam or foreign object that is preventing the FINE Cartridge Holder from moving, cancel printing from your computer, then turn OFF the machine and turn it back ON again.
You might see something blocking the printer head, check inside to see if there is a paper jam, staple, or some other object blocking the print head.
Mar 27, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Printer keeps saying paper jam..there is no paper jam
You can also try using a rubber eraser as the rollers are going. Just take a pencil and lightly rub along the length of the rollers as they are feeding. This should remove the film that clogs the rollers surface.
Dec 21, 2008 | Canon PIXMA MP170 All-In-One InkJet...
Canon pixma mp170 all-in-one printer
hi dirkvannoort
have a look here anything in the faqs section
Canon Australia - PIXMA MP170
riz.
Aug 14, 2008 | Canon PIXMA MP170 All-In-One InkJet...
Error 5100
Service Error 5100 is Displayed
Cause
Action
Sep 27, 2007 | Canon PIXMA MP170 All-In-One InkJet...
Canon MP170
primeramente me salio 5100 pero luego paso a 6000 no se lo que puede pasar ya que no se mueven los cartuchos y no hace el reseteo cuando la enciendo y solamente me sale COMPRUEBE IMPRESORA Y SALE 6000 ERROR. en espera me sean indicados los problemas que se puedan subsanar un saludfo
Feb 28, 2007 | Canon PIXMA MP170 All-In-One InkJet...
Canon PIXMA MP210 Photo All-In-One Printer Logo
256 people viewed this question
old marine
old marine
