Question about Mitsubishi WS-65807 65" Rear Projection Television
Remove screen? THis is wierd....I had a insect get between the "outside" screen and the "inside" screen of my Mitsu diamond series 65" WS HDTV. How can I get it out? How does the outside screen come off?
I watched the set up guys install the screen on my WS-73907. They poped it in with great difficulty which made me think it would be difficult to get back out.
Posted on May 02, 2007
1998 73" Mitsu diamond the RBG/HV Im trying to
I'm not sure that the set can handle the speed, but make sure that the sync pulse is on the green when you make the connection. Also, you must use the component input not the composite. IF hte picture ends up being purple, you will need ot change the set from YPrPb to RBG as well.
Good luck,
Dan
Apr 05, 2011 | Mitsubishi WS-65809 65" Rear Projection...
I have slightly double images on screen on my Mitsu. WS 65809
just go to convergence adjusment , and try to todo that , some times this tv u need todo little tunup
Aug 26, 2010 | Mitsubishi WS-65809 65" Rear Projection...
I have the mitsubishi hdtv 65" diamond series with the blurry problem posted on 1/7/10. My model# ws-65711 has the same convergence problem. How can I fix this??
There are two convergence integrated circuits that have to be replaced. The center printed circuit board has to be removed to unsolder the chips. You might want to refer this to a local Mitsubishi servicer.
May 28, 2010 | Mitsubishi Diamond WD-65831 65" Projection...
Mitsubishi WS-65313 Blinking Screen
Does your system have hdmi input. If so hook up cable box, if it has hdmi, to the tv and see if that works.
If that clears up your problem you have a problem with the av board or boards.
I have found that most of the newer systems do not like the voltage and frequency from xboxes, playstations, or computers very well using the rca out and in.
Let me know what you find out. I might have a better solution for you.
Dec 18, 2008 | Mitsubishi WS-65313 65" Rear Projection...
I have a mitsubishi DLP big screen TV where timer keeps blinking continuously after I have unplugged and plugged in and TV wont turn on.
THERE IS NO NEED TO REPLACE THE BRAIN. THE CAPACITORS THAT ARE NEEDED TO REPAIR THIS PROBLEM CAN BE PURCHASED FROM RADIO SHACK. I REPLACED THE 4 CAPACITORS THAT ARE LOCATED INSIDE THE BRAIN, AND I FIXED IT IN 30 MINUTES, COST OF $8. IT HAS BEEN WORKING GREAT FOR OVER ONE YEAR SINCE.
Nov 29, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsu 65513
I also have the blinking green light problem with my WS-65513 Mitsubishi TV. I would appreciate any information you could send to help fix this problem. Thank you, Keith. elitemachine @netnitco.net
Nov 04, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi ws-55517
the outside screen is called a linticular lens and the inside one is the fresnele lens. They both should come out together from the front as the trim on this set if im not mistaking pulls or slides off then theres mounting plates holding it on. Becarefull and dont try to clean the mirror as the coatings on the outside of the mirror. Also be very carefull not to touch any componets as theres extremly hi voltage in these sets even with them unplugged. Good Luck
Jun 14, 2006 | Mitsubishi WS-55807 TV
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
88 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
