Question about Microsoft Xbox 360 Console
Rarely plays discs
Whenever i put in a disc of any kind my 360 only reads it when it wants to. when the tray closes you hear the disc spinning and the fan come on, but then it acts like there is no disc. the other night while i was trying to load oblivion it made a loud noise like something broke inside and slammed around inside the dvd rom. it scratched my brand new game to hell and im out 40 bucks. im too broke to pay microsoft $100 repair fee + another $100 to renew my warranty. Help me please
Every body tells me to call microsoft about it but here what you do ok u need a new dvd drive and you can buy on e brand new on ebay for like 30 bucks i hade the same prob and then you gotta update your dvd drive and flash it
Posted on Oct 31, 2008
My xbox 360 will not read the disks i put into it. it is like it isn't reading that there is a disk in in the tray. it says open tray then close tray over and over again. it wont spin the disk to read it.
Inspect and clean your disc Take a close look at the bottom side of your game, movie, or music disc (the side without a label or image). Are there scratches? Excessive scratches or smudges can prevent your console from reading the disc. Clean your disc Hold the disc by the edges without touching the top or bottom surfaces. Using a soft, clean, slightly damp cloth, lightly wipe from the center of the disc outward.
· Note Use ONLY water to clean the disc.
· Once the disc is clean, load the disc into your console and see if the disc plays.
Or Click here to download repair guide
Jan 04, 2011 | Microsoft Xbox 360 Console
Tip
XBOX 360 WILL NOT READ DISC SAYS OPEN TRAY
eject the game from the cd console if in the drive make sure your xbox is on warm it up take the disc if it is dirty run under warm water all over the silver side of the disc till dirt and debris gets completely removed after still holding the disc turn off the water and use scott SCOTT brand toilet paper the straight kind and use about four sheets to dry the disc or use a blow dryer, not preffered prefreably scot toilet paper after the disc is dry and warm very dry take your clean index finger and remove the rest of the debris off the disc and when the xbox says open tray let it say close tray close it see if it says read the disc if it says read the disc then it is not your laser or the laser needs to be blowed off with an air gun or compressed air. Get it to say close tray and itll close it self, wait ten seconds turn off the xbox turn it back on and go to my xbox mash play wait for it to read the disc. THE DISC WILL NOT WORK IF IT IS DIRTY I reccomend running it under warm water (let dry on both sides while still holding it properly) use a non scratch cloth to clean the disc preferablly scott toilet paper the smooth kind, after it is dry put the disc in the console if youve tried the disc try a brand new disc it might definately work after it says read if it says play the game then its the disc. If nothing happens like it dont say reading disc then your laser is cracked corrupted, or it has debris on it or is wett. Dont let your laser head get wet because i told you to run it under water make sure the disc is dry and completly free of scratches and smudges. WASH THE DISC WITHOUT SCRATCHING IT. Dont put a wet disc in your x box. Mash the hard drive button down and release mash reset to recycle the xbox green lights. Remove all the cords fromt the xbox wait two weeks or shorter, I waited a month or more before i played my game and it worked after I cleaned it twice one time and a month later i cleaned it without soap and used luke warm water.Remember Open tray, press buttom close tray closing automatically should say read reading reading disc then play if does not read the disc then its your laser. If its your laser and you are sure its your laser do not remove the hardrive or any screws they can tell youve botherd it because that will void your warranty. go to www.xbox.com/support its a pdf file print shipping label follow the steps to repair.
on Jun 13, 2010 | Video Game Consoles & Games
Put disc in xbox 360, said reading then open tray. wont play no discs
@paulhull58 when the disc tray closes push down firmly on the top of your xbox where the tray is. if not clean your disc.
Apr 04, 2010 | Microsoft Xbox 360 Console
Xbox 360 open tray message; not reading discs
If it won't play any games it might be the laser that reads the disk. I would suggest getting it checked out somewhere.
Oct 02, 2009 | Microsoft Xbox 360 Console
My xbox 360 sounds ill
Strangely enough inside any of those game boxes is a simple DVD reader driver like for a PC.
It can be replaced.
First I would try cleaning it with a spray air electronic cleaner or any sort of DVD reader cleaner.
Dust will accumulate in them even with the little door that covers it when closed.
If that's not the case, the sensor can also be cleaned with alcohol and a q-tip if you take off the case or the motor may be going bad ont he DVD drive itself.
Start with the basics.
Jul 23, 2009 | Microsoft Xbox 360 Console
My Xbox 360 Halo 3 edition hardly reads any disc successfully!
This most likley a weak laser .
8 mw 633 nm laser diodes fail in stages
as they get weaker the cd ups voltage
to the laser diode till you get to full gain, affter that
it's time for a new laser .Good news
there cheap 30.00-40.00 and not too
hard to swap out yourself .
Rob
Jun 13, 2009 | Microsoft Xbox 360 Halo 3 Special Edition...
Disc tray won't close
Whenever you need help with your Xbox or Xbox 360 accessories, allways check out Xbox Customer Support
The answer to your question is quite long, so here's a link.
Xbox 360 disc tray help
Hope this helps
May 20, 2009 | Microsoft Xbox 360 Console
Disc tray problems
Redeem your warranty, this issue happens with the tray is going bad, first this small problem next reading problems
May 19, 2008 | Microsoft Xbox 360 Console
Xbox 360 disc drive
To april23
what has most likely happened is that the magnet which holds disks in place has dis-lodged and is now stuck to the roof of the dvd drive. Unfortunately the only way to resolve this would be to open up the xbox 360 and open up the dvd drive to fix.
So if you're not confident at this or in doubt in any way I'd contact Microsoft first if it's still under warranty, if not then it's a case of opening up the drive yourself I'm afraid.
Note. Does the drive attempt to spin up when you put a disk in?
Or does it just make small noises then nothing except "open tray" on screen?
Oct 07, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
63 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
