Question about GE (PSS26MSRSS) Side by Side Refrigerator
Location of GE refrigerator circuit board
I have to change the circuit board on my GE side by side refrigerator (Model # GSS221BPHWW). Before I perform unnecessary disassembly, can someone tell me where this board is located in the refrigerator?
    President:
  • 331 Answers
The main board is located behind the unit at the lower right hand corner behind a panel that's about 8" X 12".
Posted on Oct 29, 2008
    Director Badge:
    Uploaded 100 video answers.
  • GE Master
  • 488 Answers
I have Video how to disassemble ge side by side refrigerator. toward the end you will see how to replace board.
Posted on Nov 26, 2015
No power to compressor
Is GSS25JFPCC the correct model number? If yes and many other GE refrigerators that have a motherboard. The motherboard for your refrigerator is found on the back and is item location 801 found HERE If you would like to replace the=> WR55X10942 Main Control Board or here=> WR55X10942 Main Control Board
I can provide you a service manual and explain all the things to consider when replacing the board. Things like fan motors, compressor start relay/overload and run capacitor also need to be examined to prevent the new board from going bad. A fan motor can cause this if it shorts. Yours sounds like the compressor circuit on the board down to the compressor has shorted on the morher board. I am here if you would like my assistance, Sea Breeze
Aug 31, 2013 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Model GSS25SGMCBS coil freezes.heater checkedout ok service man changed the circuit board for $312.After 3 days, same problem again. Freeze temp ok but refrigirator sectio quit working after coil freezes....
Control board is new, heaters ok, Check defrost thermostat and thermisters located on evaporator.
PC board not getting information to defrost properly.See site below
Also check the fill tube at ice maker . Iv'e seen these get loose and fill evaporator with water causing ice block
good luck
GE Refrigerator Repair Guide
Aug 16, 2011 | GE GSS25SGMBS Side by Side Refrigerator
GE model GSS22JEMDWW. Replaced the compressor six
check the RTX overload on the compressor body its bad and trying to start the compressor
Dec 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE PSS25MGMCAA refrigerator - Bad circuit board??
You need to change the board . Part number WR55X10656 . The board relay , cannot be changed . Power surges , dirty condensor coils , and usage , are the most common causes , for board failure .
Sep 23, 2009 | GE Refrigerators
Freezer is working but the refrigerator is warm Parts changed defrost thermostate defrost heater main cicuit board
Try changing the number 1 thermistor (tells circuit board about damper operation ) If still frost , replace # 4 and 5 thermistor .
Aug 05, 2009 | GE GSL25JFPBS Side by Side Refrigerator
REFRIGERATOR HEATS UP TO 90
gheck and see if your condenser fan working or pull the refrigerator 3/4 off the wall
Feb 23, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE MODEL GSH25JSRF-SS PROBLEM HELP PLEASE
I had the same problem back in March. First the water and ice dispensers stopped working, then the clicking started and the compressor wouldn't turn on. I replaced the circuit board and everything started working again, until today. This is a very common problem with the circuit board on these refrigerators. Do a search for "GE circuit board" and you'll see what I mean. GE issued a service bulletin to its technicians that this service should be provided free of charge, and anyone who already paid to have the circuit board replaced will be reimbursed. I wish I would've known about it 6 months ago. I will be calling GE Consumer Affairs on Monday to get this resolved.
Jul 26, 2008 | GE GSL25JFPBS Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
1,252 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
