Question about Fuji FinePix S7000 Digital Camera
White Square with brighter Oval in middle on LCD and Pictures
I have a Fuji FinePix S7000 and it recently developed a large white square that covers almost the entire image. There is a also a brighter oval in the middle of the square. This distortion shows up on the LCD as well as the downloaded photos. Fuji quoted the repair cost as 166.00 which is ridiculous. That's almost 1/2 of what I paid originally. The camera gets mild use and has never been mistreated. Any ideas? Thanks in advance for any information!
  • Adam Ripka Sep 09, 2006
    scrajmer,
    I think you might be on the right track. I did what you told me to and even though I couldn't really see anything, it definitely affected the pictures. I zoomed the camera completely in and out as far as it would go and did this a few times. Then I took a picture and the distortion was a lot better. Then I used the manual zoom and I actually got one picture to take without any distortion at all. Is there anything else I can do to completely eliminate this issue? Would I have to take anything apart to fix this? I appreciate the tip and I'm wondering if from my results you are able to pinpoint the problem.
    Thanks for the help!
I have the same problem. Did you find a solution ? I love this camera and do noit want to part with it. Please help.
Posted on Nov 11, 2006
  • 188 Answers
Have you checked the lense assembly. One of the possible cause may be any of the lense element, inside the lense assembly may have dislocated from its fitting. Just swithc on the camera look inside the lense from the front and try to zoom the camera. if you happen to find any obsticle in the movement may be i am right.
Posted on Sep 07, 2006
My fuji s7000 zoom has coloured wavey lines when turned on. It goes back to normal intermitantly but at the moment it is constant Ian
Hi Ian.
If the lines are reproduced in the pictures taken, then the image sensor located behind the lens is starting to fail. The problem will usually get progressively worse until you won't be able to shoot regular pictures anymore.
Call Fuji and ask about repair. You can get a quote from a third party here: Repair.
Regards.
Ginko
May 27, 2011 | Fuji FinePix S7000 Digital Camera
My fuji S7000 automatically shut down (Switched off) frequently while I am taking pictures. Let me know what is the problem?
If the batteries are OK, then the shutdown has a simply-cured physical cause. Open the CF card door and look for a small square opening at the bottom of the door. Look inside this and there should be a small plastic 'plate' or flap. DO NOT TRY PUSHING IT WITH A PENCIL OR NEEDLE etc. The bad news is that if you DO see that flap inside the little square opening, then your problem probably lies elsewhere. But if what you see looks like the tip of a pencil, then THAT'S your problem. The flap is there to keep dust out. It's thickness is needed so that closing the door operates the switch. Without it, the door seems to be open and the camera shuts down. If you can find an alternative for that small plate, your problem should be solved. One solution is to attach a small (about 3mm square) piece of foam pad to the tip of the protrusion inside the square. A typical example for this type of foam pad is what scrapbookers fasten photos into their albums. There will be other solutions - but the loss of that flap will be the cause.
Mar 14, 2011 | Fuji FinePix S7000 Digital Camera
My camera only shows half a picture after I take the picture on the little screen and if I keep taking pictures it goes all white? it's not the batteries. thank you
Hello - from a fellow Fuji user.
I'm assuming the pictures are looking OK on the PC when you download. If so this will be a LCD fault.
If NOT and the downloaded pictures are the same on the screen and the PC , then it looks like a sensor problem (CCD chip). I just did a quick search on the google.co.uk site and could only find 4 complaints , so it's pretty rare.
Try re-formatting the SD card just to eliminate that from the equation --
http://forums.steves-digicams.com/fujifilm/152895-fuji-finepix-s7000.html
Plus there are S7000 forums to ask like http://forums.techguy.org/digital-photography-imaging/562485-fuji-finepix-s7000-problem.html
Hope this helps , but , if it's a sensor problem I hope it's still under warrantee -- Ray
Jan 14, 2011 | Fuji FinePix S7000 Digital Camera
Set s7000 white balance
Navigate through the settings menu's until you find the one that addresses the white balance. Either leave it set to automatic or experiment with different settings until you are pleased with the results. If this was helpful, please rate.
Sep 04, 2009 | Fuji FinePix S7000 Digital Camera
Photos are "whited" out, like a burned out image in the center
Did you point it at the Sun?
I think you have burned out the CCD/CMOS sensor.
The display wont have been affected.
If its not insured for accidental damage, its a bin job!
Apr 29, 2009 | Fuji FinePix S7000 Digital Camera
WHITE STORED PICTURES
CCD failure image sensor failure
ur camera may be on serviceadvisory list just mail the fuji film with serial number i am prettysure they will repair free of charge it is a manufacturing fault insome units manufactured b4 2005 u have to email them they will repairit free of charge
http://www.fujifilmusa.com/support/ServiceSupportProduct.do?prodcat=616757
pls rate me FIXYA for this if u like
Jan 27, 2009 | Fuji FinePix S7000 Digital Camera
Problem in Fuji FinePix S7000 digital camera.
ur camera may be on service advisory list just mail the fuji film with serial number i am pretty sure they will repair free of charge it is a manufacturing fault in some units manufactured b4 2005 u have to email them they will repair it free of charge
Dec 31, 2008 | Fuji FinePix S7000 Digital Camera
White preview screen after pic taken
Have u tried switching the view from and eyeview(viewfinder) to LCD while viewing pictures. Sometimes we forget it and panic. Hope it helps. Good Luck.
Nov 20, 2008 | Fuji FinePix S7000 Digital Camera
Cloudy white pictures
Cloudy images are usually a result of ccd gone bad. Try power reset, maybe it helps..
Jan 12, 2008 | Fuji FinePix S7000 Digital Camera
Picture is almost completely white...
This is a CCD/processor problem for the still image side. Fuji Technical Help team will advise what your next moves will be.
Jul 09, 2007 | Fuji FinePix S3000 Digital Camera
Fuji FinePix S7000 Digital Camera Logo
171 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
KJ Soni
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
