Question about Handmark Software MobileLists (950142) for PC, Mac
How to get hands free mode not got thro rt soft key
I tried to change to hands free mode as per instruction manual ie. by pressing right soft key but i could not pl help me. suresh hyd india
I have a problem , is the software for my phone mt6225, i cant
Posted on Oct 30, 2008
Change time on KX-TG4713C
To change the time, pick up a handset with the phone in standby mode. Press the Menu button (the middle soft key below the LCD screen). Then press # 1 0 1 . If you need to change the date, type in the date in a two digit format for month day and year. Press OK (one of the soft keys) when done (or to skip changing the date). Enter the current time with two digits (12 hour time). Then use the arrows to select AM or PM. Press Save (again a soft key) and then press the Off key (to the lower right of the arrow keys).
Panasonic has the manual for the KX-TG4713C and related models here: http://www.panasonic.ae/en/manuals/kx-tg4711.pdf . See page 15 of this PDF.
I hope this helps.
(If your phone is set to French as the display language, you'll get the time in a 24-hour format. In that case, put in 1:30 pm as 13 30 . Then press Save and Off.)
May 04, 2016 | Lands Phones
How do i turn the bluetooth feature on for my rumor 2
  • Insert a microSD card into the slot on the right side of the phone.
  • 2 Connect the phone to your desktop with the USB cable.
  • 3 Select "Transfer Music" on the phone by pressing the "OK" key after highlighting "1 Yes" on the display.
  • 4 Go to your desktop and use Windows Explorer, which will have now opened up, and you can drag and drop files from the desktop to the phone just like another directory.
Use the Rumor Bluetooth to Connect to Your PC or Other Bluetooth Device
  • 1 Set your secondary Bluetooth device into the pairing mode.
  • 2 Open the "Tools" menu on your phone by first making sure it is in the standby mode and the slide is closed. then press the "OK" key and select "Tools."
  • 3 Select "Bluetooth" and press the "OK" key to choose "Pair with Hands-Free." If "Bluetooth Wireless Technology" is turned off follow the prompts to turn it on by pressing the "Left Soft Key."
  • 4 Highlight secondary Bluetooth device on the list of found devices and press the "OK" key.
  • 5 Enter "0000" pin code and press the "OK" key to initiate the pairing process.
  • 6 Enter the device's name and press the "Left Soft Key" for "Save."
  • 7 Connect to your device by pressing the "Left Soft Key."
Mar 01, 2012 | LG Rumor 2 Cell Phone
How to change the time one hour ahead
Changing the time on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
2.- Enter password (default = 266344) - display should read "Terminals & Sets"
3.- Press "NEXT"(bottom right arrow) 5 times - display should read "Time and Date"
4.- Press "SHOW" (top right arrow)- display should read "Hour:___"
5.- Press soft key "CHANGE"
6.- Enter hour - display should read "AM OK or Change"
7.- Select AM or PM
8.- Press "NEXT"(bottom right arrow) - display should read "Minutes:___"
9.- Press soft key "CHANGE"
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___" 12.- Press soft key "CHANGE"
13.- Enter year
14.- Press "NEXT"(bottom right arrow) - display should read "Month:___"
15.- Press soft key "CHANGE"
16.- Enter month
17.- Press "NEXT" (bottom right arrow)- display should read "Day:___"
18.- Press soft key "CHANGE"
19.- Enter day
20.- Press "NEXT" (bottom right arrow)
21.- Press the Rls key
Mar 18, 2010 | Nortel Norstar 16-Line PBX Speakerphone
I want the keytone to be silent - how do I set it to silent?
You have to do the following:
Sound Profile
You can customize various sound profiles for your phone by
changing the sound settings.
1. In Idle mode, press the Menu soft key and select Settings
➔ Sound Profile.
2. Highlight one of the following sound profiles:
• Normal
• Silent
• Driving
• Outdoor
3. Press the Edit soft key to access the sound settings.
4. Press the Change soft key to change the "phone" option.
• To move between the various tabs, use the Left and Right Navigation
keys.
• To highlight individual options, use the Up and Down Navigation keys.
• To change the setting for a highlighted option, press Change ( ).
There you have these options:
– Keypad Tone: allows you to choose between Beep, Xylophone, and
Mute (no tone) for keystrokes on the phone.
– Power On Type: allows you to select the way in which the selected alert
is played when the phone is powered on.
• Melody: the phone sounds the selected melody.
• Vibration: the phone vibrates.
• Vibration & Melody: the phone vibrates and also plays the
melody.
• Mute: the phone neither vibrates nor plays a ringtone. The only
indication of a message is an alert on the display.
5. Press the Save soft key when you are finished.
Normal Profile
To access the available options for this sound profile, press the
Edit soft key.
keys.
• To save your changes, press the Save soft key.
This should do it.
If you still have some problems please download following manual and go to page 69 where you find all related info.
Propel Manual
.pdf
Hope it helped.
Nov 20, 2009 | Samsung Propel A767 Cell Phone
Gives wrong time and day
This is from the Manual. If you want the whole manual, at the end of the instructions, there ia a link to the manual.
Setting Day and Time
Day & Time sets the day and time of your display.
1) Enter the Global Setup menu, and then the Day & Time
submenu option (see "Entering the Menu" on
page 17). Image is for the base.(Here is how)
Entering the Menu
1) In standby mode, press the MENU soft key.
2) Use volume up/down to move the pointer to a desired
main menu (DirectLink Mode, Room Monitor, Handset
Setup, Base Setup, Answ. Setup, Global Setup, and
Deregister HS).
3) Press the OK soft key to select the desired main menu.
To return to the previous screen, press the BACK soft
key.
4) Use volume up/down to select a desired submenu and
then press the OK soft key to enter.
5) In the submenu option, use volume up/down to select
an item. Press the OK soft key to confirm your
selection. For detailed instructions, see the following
sections for the desired submenu option. To return to
the previous screen, press the BACK soft key.
6) To exit the menu, press end on the handset or cid/exit on the base.
2) Press volume up/down to select the day of the week,
and then the → soft key.
3) Press volume up/down to set hour, and then press the → soft key.
4) Press volume up/down to set minute, and then press the → soft key.
5) Press volume up/down to choose A M or P M, and then press the SAVE soft key. You
will hear a confirmation tone.
http://www.uniden.com/pdf/TRU8885-2om.pdf
Jan 08, 2009 | Uniden TRU8885-2 Cordless Phone
Razr V3 audio will only work on speaker phone
If you quickly enther ##debug (##33284). if the 4 doesn't appear then that means the phone regognized the code. press END then once you see you home screen press CLR and then the LEFT SOFT key which brings you into the debug mode. ONce your in there be very carful not to change any settings for it can easily screw up your phone so be cautious. to go through the pages press the LEFT or RIGHT SOFT keys. more prefferd by pressing the RIGHT one. press it a few times till you come to the page where the first line says "ServOPT: NoChg". The second line or the line right after that says "AudioOpt: Auto". Scroll down to it by pressing the down button on your keypad then once the little pointer on the left of the screen is at "AudioOPT:". you'll notice that right on top of the RIGHT SOFT key says change. Pess that till it goes from "Auto" to "Spkr". once your finished all that press Exit (LEFT SOFT KEY) and you will see it going out of the editing mood. Press CLR and the LEFT SOFT key on the keypad again to Exit the debug mode. Once you out to the main screen again press ##debug again to disactivate the Debug mode. Again if the 4 doesn't appear then that means the code registered and it disactivated. If you won't disactivate it it will enter into the mode again by switching your phone off and on again. which you don't want to happen. however if it does happen press the CLR and LEFT SOFT key then you out again. then disactivate it again by pressing ##debug.
If that doesn't solve your problem then i'm sorry but i can't help you. I am also not responsible if you Screw up your Phone.
This only works on the Razr phones so don't try it on other phones.
Sep 03, 2008 | Motorola Mobility RAZR V3
Bijoux Terner Sport Watch Trouble
japgap has it pretty much right .... Start by pressing the Mode Key. It should change the mode (probably to stopwatch first on first press, alarm if Mode Key is pressed again, then time if pressed a third time). (NOTE: pressing the Mode Key to get action isn't about the length of time pressing the key, its about getting a "connection" when pressing!!! The sport watch doesn't have the greatest quality construction so a simple press does not always make a connection).
Once in the time mode, the seconds will be blinking, press the Reset Key to move to minutes and Start Key to advance the minutes, then Reset Key to move to hours and Start key to advance the hours. Mode Key to get back to regular operation.
Aug 24, 2008 | Watches
Phone doesn't ring at station
Sounds like your station (phone) is set to not ring. You need to check your ring assignment.
Feat # *
Enter password (default is 000000)
Press the soft key under "show"
Press the soft key under "next" until 1. STATION appears in the display.
Press the soft key under "show" SHOW STA:_ appears.
Enter your station number and press the show soft key
Press the "next" soft key until RING ASSIGNMENT shows on the display.
Press the "show" soft key. You will see CO LINE 1 : followed by NONE or DAY or NITE or BOTH.
If it says NONE, your phone never rings for an incoming call. If DAY or NIGHT your phone rings depending on the time of day and the time definitions for DAY and NIGHT programmed into the KEY unit. If it says BOTH, your phone should ring all the time.
If you need to change the setting, press the "chg" soft key until the desired setting comes up.
When you're done with LINE 1, press the "next" soft key to move to the next line. Repeat the process for all your active lines. Obvisously changing settings on lines with no CO connection will have no affect.
While your in the mode, check your RECEIVE ASSIGNM as well to make sure your phone is configured to receive incoming call. It was the station feature just before the RING ASSIGNMENT feature.
Hope this helps.
Jun 04, 2008 | Vodavi Starplus SP7314-08 Corded Phone
How to set watch
I just set the time on mine with these instructions 1) With the watch in the regular time display mode (doesn't matter if 12 hour or military time), depress and hold the lower left hand button (mode button). After a few seconds the watch appears to shift to alarm mode and it is blinking. This puts you into the mode for adjusting the alarm.
2) If you want to adjust time, date, etc rather than alarm time, after you have done step one, simply press that same lower left button again, and then it will put you into the time mode, but this time the time mode is blinking and you can adjust the various components (seconds, minutes, hours) then you can use the upper right hand button to navigate thru seconds, minutes and hours. Then you can change the time with the lower right hand button you can only change the time forward. I hope this helps !!!
Apr 02, 2007 | Kenneth Cole RK5034 REACTION
Handmark Software MobileLists (950142) for PC, Mac Logo
70 people viewed this question
Top Handmark Software Computers & Internet Experts
Laxman Bisht
Laxman Bisht
Alun Cox
Tarpan Shrivastava
Tarpan Shrivastava
Are you a Handmark Software Computer and Internet Expert? Answer questions, earn points and help others
