-   i have the same problum s1861 no power i love my ionic air purifier and would like to be able to get it fixed or fix it myself -   Guest
Jan 05, 2009
-   I have the same problem. I have a desk top GP ionic breeze. Replaced the bulb then had no power. -   w_kk_a
Nov 03, 2008
-   We had the Quadra Ionic Breeze for 2 years then bought the GP SI730 after kidney transplant 4.5 years ago. The original Quadra is still working but the second unit only worked for 3 years and supposedly had a 5-year warranty. I hadn't heard about Sharper Image until I tried to find out how to get the unit serviced.
Although they don't remove all dust from the air they did reduce the snoring (which is a problem when the Quadra is off).
I posted a solution to a similar problem I had with my Ionic Breeze GP. I was able to replace a bad switch and get the unit working again. Details are in the following Fixya article:
took out the blades, cleaned them...took off the back and front grids, cleaned them, even wiped down...
(More)
took out the blades, cleaned them...took off the back and front grids, cleaned them, even wiped down the little wires ----- it's clean, just the red indicator light won't go off.
I took the filter out and cleaned it. It was working at that time. I cleaned the filter and it will...
(More)
I took the filter out and cleaned it. It was working at that time. I cleaned the filter and it will not come on. I attemped several times, tried everything & it still will not work
My Ionic Breeze GP clean light is flashing. I've cleaned the unit in and out, flipped it over a few...
(More)
My Ionic Breeze GP clean light is flashing. I've cleaned the unit in and out, flipped it over a few times - no luck. It turns on for 5 seconds and then the lights are on but air stops coming out. Any idea how to fix this?
