Question about Rinnai RHFE-556FAIII 21,500 BTU Ductless Energy Saver Heater - LP(Propane) Gas
My rinnai 556fa propane heater
When i turn heater on it works for about 5 mins then it beeps 5 times all lights flash and get no heat help thanks rinnai model 556fa propane heater
I had the identical trouble with my Rinnai 431F just now & read the unanswered posts.
I checked my intake & exhaust & found them connected & intact then went out to check the exterior vent assembly. The "bell" or dome was almost entirely clogged with ice.
I suspect the 60 - 76 lights flashing means insufficient combustion air.
Anyway, I took a hair dryer to it & in 10 minutes it was working as well as ever.
This won't help you October posters but if anyone else has this problem in the future I would start with the outside vent assembly. Get a good look right up inside because I would have missed this ice if I didn't get up close with a flashlight.
Here's a good source for manuals too...
http://www.houseneeds.com/products_rinnai.asp
I'm going back to bed.
M.
Posted on Dec 22, 2008
Rinnai code 99
i am not an expert. this is how i fixed my rinnai code 99. my rinnai 100 4f would run for few seconds then the red light would continue to flash. code 99 would come up.i took the unit out of service. i notice that the fresh air hose had two very small hoses located on it's elbow had been switched around when i took it to be serviced. the unit worked well. how ever. i changed my mind when i realized the service was not need. anyway the two small hoses on the elbow one office is larger than the other and they must be put on the correct one,i switched them around the unit flamed up. and now i have sweet heat again.no code 99.
Dec 17, 2016 | Rinnai Heating & Cooling
I HAVE A JACUZZI HEATER RINNAI 95GS-5 DO THINK PROPANE WOULD WORK ON THIS ITEM
Contact Rinnai, or look at product manual.
Products rated for natural gas do not work with propane.
Propane burns hotter and has more pressure... wrong gas can cause explosion
Gene
Feb 11, 2015 | Rinnai Water Heaters
My rinnai 556fa thinks that it is 10 degrees warmer in space than setting and won't come on???
Where is the room sensor? High on the wall will be warmer than close to the floor.
Tom
Sep 30, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai rhfe-431faIII heater malfunction
Either the high limit switch is either defective or the wire has come off and the circuit is open. It is found under the heat shield on the front of the heat exchanger. Or there is a blockage in the flue or the blower motor is not running. Take the to trim piece off that is closest to the wall and disconnect the gray plastic hose off of the vent termination and try to start the unit. If it starts, you need to clear out the outer ring on the vent termination. If it continues to fail, there is still a problem and now you will need the installer back. Check all electrical connections going to the circuit board while you have the front cover off.
Mar 28, 2010 | Rinnai Heating & Cooling
Where is the pilot light on Rinnai EnergySaver 1001F
If you smell gas in a Rinnai you have a big issue. This heater is what is called a direct vent heater with an electronic ignition so the combustion chamber is sealed and the smell of gas is an indication that you have a gas leak. Please call a professional today.
Oct 13, 2009 | Rinnai Heating & Cooling
Rinnai tankless water heater
LC is the error code that you get when you have limescale buildup in the heat exchanger. You need to flush your heat exchanger. If you have the manual for your water heater, use it. The manual to mine is attached. The procedure for flushing it is covered on page 12. I suggest that you have a certified Rinnai plumber perform this task as it requires a ciruclating pump and some hoses that you need to connect to your water heater. If you don't perform this task, it is possible that you will need to replace your heat exchanger and this is not something covered by Rinnai's warranty.
Sep 21, 2009 | Rinnai Webstone The isolator EXP tankless...
Rinnai EnergySaver 556F Heater flashes
I'm picking up a faint propane scent when the heater is completely turned off. When I turn the heater on it lights fine so I don't suspect it's the pilot light. Is this an issue with the installation of the fuel line, or could it still be the pilot? Any ideas on troubleshooting the source?
Nov 10, 2007 | Rinnai EnergySaver 556 Air Conditioner
Heating & Cooling Logo
443 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
