Question about Whirlpool Duet GHW9150P Front Load Washer
Impeller - whirlpool duet front load
The impeller and shaft slip out about 1/2 inch from motor housing and stops pumping water. I can push it back in but it slips back out before a wash cycle can finish . Do I need a new pump motor ?
    President:
  • Whirlpool Master
  • 2,651 Answers
Youll def need to replace the drain pump assy part number 280170
Posted on Oct 30, 2008
My water don't drain after a full cycle
A very common cause for reluctant draining is that the pump filter is blocked or the pump motor has failed. Check the pump filter via the small access door at floor level (might be behind kick plate) Carefully unscrew the round 'plug' and clear filter. Also check that there isnt a coin or similair stopping the impeller from turning. Any water in the machine will flow out during this operation. Leaning the machine back and bailing it out first will help...Good luck .....Nomess
Apr 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet leaves standing water or it will flood the floor.
the drain pump motor went bad on mine. ( i think the motor worked fine, the impeller which is plastic was stripped where the motor shaft goes into the impeller) i bought a new pump for about a hundred dollars and installed myself. if you are the least bit handy, you can too. it's a bolt-on fix.however, like moyerboy says, make sure that there are no blockages from the bottom of the drum to the drain pipe. i once found a sock stuck in the pipe.
Jan 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Failure to drain, stuck in the drain part of cycle
Try to drain as much water as possibel then remove front cover you will see the pump motor.unscrew the pump housing and look for some object that is blocking the impeller.
Sep 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Changing motor hayward 1.5 HP
Super pumps are very easy. If it is a northstar it is more difficult. Super pump. You will need 1 motor, 1 pump seal, 1 diffuser gasket, 1 housing gasket. turn off breaker, disconnect wires -noting whether it is 110 or 220 volts- , unscrew four bolts on back of pump housing (shaft side of motor), pull out motor with rear housing and diffuser (sometimes diffuser sticks inside), on wire side of motor hold shaft with wrench (flathead in some cases, but it is harder), unscrew impeller counter clockwise (like normal screw - you will nee a big pair of channel locks or a strap wrench), there are two pieces of the back housing and once the impailer is off you can remove the half that is closest to the end of the shaft to reveal four more screws, unscrew those four screws. screw back part of rear housing onto new motor. Install new pump seal to front part of rear housing and impeller, slide on front part of rear housing and then screw on impeller while holding shaft on wire side with wrench (only hand tight), replace housing gasket, replace diffuser gasket, slide into front housing and screw in four bolts. If electrical was 110 you will need to move the jumper on the wire end..if it was 220 then just hook kup wires...doesnt matter which is which as long as green or bare goes to the ground screw.
Mar 14, 2009 | Hayward 2HP Pool Pump Motor A O Smith...
My whrilpool duet washer is flashing a error code of h and f
I found that my washer would not drain which is why I was getting the F02 code. I first pulled the strainer to see if it was plugged and it wasn't. I turned the little impeller to the right of the housing and it was free moving but it moved in and out as well as turned. That made me curious. I then to a shop vac and pulled on the drain hose at the wall hook up. It pulled and I could put my hand inside the strainer housing and felt the suction.
This led me to my last tought which was to pull the pump off the strainer housing. It only took three screws and when I pulled it I saw the impeller. When I pulled pack on the impeller it cam right out of the motor and I could see the end of the shaft had sheared and the grinding sound I heard was the shaft ends grinding and it was not able to move any water from the basin.
Im now looking for a new pump cause Im sure its one unit. So far they are over $100 for the complete housing and pump. Im hoping I can just find the pump.
Dec 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
GHW9100LW randomly stops during cycles, has a severe clicking noise
the water leaking back in may be due to a fill valve not fully shuting off allowing water to leak into washer after shut off...reclean pump ck as far as possible into pump itself something may be hung in impeller the shaking may be due to excess water in clothes causing off balance and shaking ..cleaning pump may solve problem..if possible pull pump completely out to clean ck pump impeller to be sure it has not come loose on motor shaft this would also cause slow or no pump out ..if impeller is loose replace pump..good luck
Nov 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F2 problem
f2 is usually and indication of drain problems usually something in pump ..have seen impeller on pump shaft come loose and freewheel..remove pump completely 3-4 screws hold pump motor to housing remove them try turning impeller if impeller spins free replace pump ..impeller will usually have some resistance when turned by hand..a free spin on impeller indicates it has come free of motor shaft
Aug 28, 2008 | Kenmore Elite 45986 Front Load Washer
Grinding during the spin cycle
To check for a bad bearing, open the door, pull back the door seal then grab the plastic outer tub with one hand and the inner basket with the other hand. If you can lift on the basket and wiggle up and down, the tub bearing is bad. If OK, the noise may be coming from the pump. The pump impeller may have come loose and is rubbing on the pump housing.
To check impeller, remove the bottom access panel. There you will find a pump filter that you can unscrew and remove debris. UNSCREW AND DRAIN SLOWLY as there will be lots of water to catch..
Look inside the small hole of the pump and check impeller, it should be set back against the motor.
If bearing, check limited warranty.. bearing may still be covered...
Regards,
Richard
Jun 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport Front loading washer and dryer with error code
An easy Fix. Take off the kick panel, 3 screws 1/4 inch. Make sure you have a shop vac ready or a lot of towels as there will be some water. Always disconnect power to washer and dryer, and turn off water to washer. Your filter most likely is clogged with change, screws, lint, and other household stuff that we leave in our pockets! Unscrew the cap on the filter, easy to find, since you have the kick panel off! Take everything out of the filter. Take your shop vac and **** out remaining stuff in hose. Also, **** up any water that has leaked in and around the washer. Screw the cap back on hand tight, put the kick panel back on, turn your water back on, plug it in and there you go! Maybe takes an hour and saves you a repair bill. If you are not comfortable with this procedure then call a maintenance person that is qualified. 775f844.jpg
Dec 26, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
307 people viewed this question
Dan Webster
Dan Webster
Sal De
