Question about Omron Hj 720ITC Advanced Pocket Pedometer
Setting diretins I cannot find my little manual - and do not know how to set it to measure my step - clear it & reset it. I have tried to follow the directions printed on it - but it is not working out. Do you have an electronic manual for setting the device?
  • 2 more comments
  • Joan Bozman Dec 07, 2008
    I have the exact same problem with my Omrom "Walking Style" Pedometer. I can't figure out how to set it up to measure steps and cannot find set up instructions on line.
    I cannot figure out how to set my Omron Digital pedometer to measure steps, so it inaccurately measures my mileage. It's always off by about a half mile.
  • Beaverpal Jan 08, 2009
    I have an Omron Walking Style HJ-112 and cannot find a manual anywhere on-line.
  • Anonymous Feb 11, 2009
    I can set the time but I lost the instructions and I do not know how to set the rest of the information.
The manual for the Omron Walking Style II Pedometer can be found at
http://www.omron-healthcare.com/images/bymanager/EU_weight/step_counter/IM_HJ_113_E_.pdf?_ver1_i2_fied3
Posted on Jan 17, 2009
Motorola v8 master reset
In order to reset a phone you can look for the steps depending on the model of your device from this website: How to perform Master Reset Master Clear, but you can follow the steps from your specific phone from here: Linux Java Non Touchscreen Master Reset Master Clear
Jun 30, 2014 | Motorola RAZR Cell Phones
I can't figure out how to set the time and date on the HEM7300REL blood pressure monitor. I have a manual and have followed the instructions without results. I don't see a reset hold on the machine. do...
If you remove and replace your batteries...you will not lose the memory. The unit will store up to 90 measurements in non-volatile memory...so it will stay there.
I have the same unit and use these directions....and never had issues with setting the date and time.
2.2
Setting the Date and Time
Your blood pressure monitor automatically stores up to 90
measurements values with the date and time. To make use of the
memory and average values functions:
• Set the unit to the correct date and time before taking a measurement
for the first time.
• If the batteries have been removed for more than 30 seconds, the
Date/Time setting will need to be set.
1. Press and hold the Date/time
setting button (
) to adjust the
date and time. The year digits
(2008) will flash on the display.
2. Press the Memory button ( ) to
advance the digits one at a time.
Notes:
• The range for the year setting is
2008 to 2030. If the year
reaches 2030, it will return to
2008.
• If you hold down the Memory
button ( ), the digits will
advance rapidly.
3.
Press the Date/time setting
button (
) to confirm the setting
when the desired number
appears on the display.
The year is set and the month
digits flash on the display.
4.
Repeat steps 2 and 3 to set the
month.
The month is set and the day
5.
day.
The day is set and the hour digits
6.
hour.
The hour is set and the minutes
7.
minutes.
The minutes settings is set.
button (
) to turn the monitor
off.
When adjusting the date and
time, press the Date/time setting
button (
on, follow the steps above, and press the START/STOP
button to turn the monitor off.
Good luck.
Semper Fi,
Z
Jan 31, 2018 | Omron HEM-780N2 Automatic Blood Pressure...
I need to know how to adjust the float on my cvk32 carb
float level is usually per bike. you can try to start at 16mm give or take 1mm this is the setting for a 1989 kdx 200/220. it is measured from the bottom of float to the mating surface just touching needle. the best way is a service manual or owners manual should tell you. You can play with them a little by changing the measurements you can richen or lean the fuel a little, example 18mm would be leaner, and 14 would be richer.
Dec 25, 2012 | Motorcycles
Setting the clock on a brinks timer 44-1011
I finally found the instructions for the Brinks timer 44-1011 and they work.
    • BRINKS DIGITAL TIMER 44-1011 INSTRUCTIONS
    • CURRENT TIME SETTING
    • 1*Press and hold the OK button for 4 seconds. Hour Display flashes.
    • 2*Press +/MANUAL or - to select the hour. Press OK to confirm.
    • 3*Minute display will now flash. Press +/MANUAL or - to select the minute. Press OK to confirm.
    • 4*Press MENU to exit the time setting mode. Now the timer is in clock mode.
    • PROGRAM SETTING NOTE: This timer can be set up for up to 2 different programs. We will use PROG 1 for this example, however these steps can be repeated for any of the 2 programs. To cycle through the individual programs use the +/MANUAL or - after pressing MENU in step one until the desired PROG "#" is flashing. To clear a program setting hit the RECALL button when you have the program selected.
    • 1*Press MENU button, PROG 1 "ON" will flash, press OK.
    • 2*Hour will flash. Cycle with +/MANUAL or - to desired hour, press OK.
    • 3*Minutes will flash. Cycle through minutes +/MANUAL or - to desired minute, press OK.
    • 4*Program will be flashing again. Press +/MANUAL to get to PROG 1 "OFF" blinking, press OK.
    • 5*Repeat steps 2-4 to complete PROG 1 setting.
    • 6*When done setting programs press the MENU button to return to clock mode.
    • 7*Press +/MANUAL to have LCD showing either "AUTO ON" or "AUTO OFF" for the timer to execute the programmed settings.
    • DAYLIGHT SAVING TIME SETTING (DLST)
    • 1*In clock mode, press RECALL to turn on or off the Daylight Saving Time.
    • 2*Turn on DLST, the below of LCD shows +1H. Time is adjusted by adding one hour.
    • 3*Turn off DLST, +1H will disappear and LCD shows the real time. MANUAL OVERRIDE AND ALWAYS ON/OFF When in clock mode the +/MANUAL sign cycles through
    • 4 settings that serve as manual override. **ON - Indicates that the timer is in the ON mode, and will always be on regardless of the programmed setting. **AUTO ON - At this selection, the timer will come on regardless of the programmed setting, but it will follow the next programmed command. **OFF - Indicates that the timer is always off (i.e. the wall socket is turned off) **AUTO OFF - Indicates that the timer is in the OFF mode until the next programmed step that turns it ON.
    • NOTE: For normal timer function, the selection must be either "AUTO ON" or "AUTO OFF". RESET At any mode, press RESET for 5 seconds. All settings will be cleared, return to clock mode, 12:00 MO, AM, AUTO OFF will be shown on LCD
I hope this is helpful. It was a bear to find.
Dec 24, 2012 | Hardware & Accessories
I have an ACURITE 00590A1-RX. My time is off by 10 minutes. i don't have my manual and would like to know how to reset it. If possible, tell me how to download a manual.
From the manual, such as it is:
Set the Time Manually:
If you want to set your alarm clock a little ahead or if the unit ever loses time for any reason, the time can be set manually by following these steps.
1) Press and hold the "CH./SET" button for seven seconds to begin the manual time set mode. (2 BEEPS) The hour will flash on and off.
2) Adjust each setting by pressing the "+" or "-" buttons. Confirm and move on to the next setting by pressing the "CH./SET" button.
MANUAL TIME ADJUST SEQUENCE: hour, minute, year, month, date
This works for me. You have to be sure to keep pressing the CH/SET button for the full seven seconds -- the first beep the the clock gives you will only allow you to set the time zone and DST function.
Aug 25, 2011 | Acu-Rite AcuRite 00592A2 Wireless Humidity...
My toyota corolla 2006 model has the maint. required lights on. what does that mean?
It means your car needs an oil change, based on mileage. If you take your car to get the oil changed, they can reset the light for you. If you want the light off now, try holding in the odometer reset button, with the key on but engine off, until little dashes appear then one by one dissapear. This procedure may need to be done either on the odometer total mileage or trip A mileage or trip B mileage.
Step 1: Have car off.
Step 2: Push and hold in trip reset button.
Step 3: While still holding button in, turn key to ON, but engine off. Wait for the little dashes to appear and disapear. If it doesn't work on the odometer setting. before turning key off, switch to Trip A setting. If the procedure doesn't work on the odometer setting or Trip A, try Trip B setting.
Step 4: Turn key off. Then start car. Maint. required light should be off.
Jul 15, 2011 | 2006 Toyota Corolla
I need to find instructions on how to reprogram an Intermatic indoor wall timer.
You posted under ST01C Intermatic battery operated timer.
If you have different timer, then add a comment.
Let's review ST01C timer for a moment.
Programming will stay inside timer memory indefinitely until timer no longer works.
Even if battery is removed, programs remain. Current time setting does not remain in memory.
If battery goes dead, then current time will disappear, but programs remain forever.
If previous programming was correct, you might only need to set current time,.
In that case, you do not want to 'reset' timer and clear memory.
If you want to clear old programming entirely, then you can 'reset' timer using following instructions.
Press and hold on-off button, and then use paper clip to push in reset button for 3 seconds.
Release reset button but keep holding on-off button until INIT displays momentarily.
Release on-off button.
If display does not show, then timer battery is bad, or timer is bad.
For instructions how to set current time, click link below.
In addition to current time, the link has ST01C manual and also has EZ to follow instructions and photos for setting on-off times (but not astro times)
http://waterheatertimer.org/ST01C-program.html
Instructions are different for astro dawn to dusk.
Add a comment at any time if you need free help with specific steps in the manual.
If you do not want to read the manual or open a link and read the steps or add a comment for further free help, then you can pay a fixya expert for phone support and that person will walk you through the steps while on the phone.
Keep in mind that ST01C timer has 1 year limited warranty, and your timer might be broken.
In that case you should try the free steps first.
Dec 16, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I have the Merriam-Webster® Speaking Dictionary & Thesaurus (MWS-1840) The screen is erratic. I tried to push clear at the same time as the on/off button, but nothing happened. So I...
If the screen performs eratically, then the only way is resetting the bookman, here is the exact procedure for resetting the Bookman,
Follow these exact steps for performing the soft reset:
1)First Press the clear button and press the ON/OFF button twice..
If this soft reset procedure doesnt work, then try hard reset..
Warning: Doing a hard reset will delete all the setting saved by you..
Here is the procedure for performing hard reset..
1)Hold CLEAR and ON/OFF button for 5-10 seconds, this should perform a hard reset, if you still have issue, follow the next step
2)Use paperclip and gently press the RESET button,
Reset button is present in a pin hole sized block present at the backside of the bookman
Any of the following procedure should solve your issue
Please leave me comment, if you need further assistance
Rnj VinodKumar
Jan 31, 2010 | Franklin Office Equipment & Supplies
Omron Hj 720ITC Advanced Pocket Pedometer Logo
556 people viewed this question
Top Omron Sport & Outdoor - Others Experts
ka4iup
ka4iup
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Are you an Omron Sport and Outdoor - Other Expert? Answer questions, earn points and help others
