Question about Intertherm P3RA-048K Air Conditioner
Intertherm heating Unit comes on but the blower doesnt work, and it just clicks. I just started having this problem, do you think that when I vaccumed all the dust out I might have disconnected a wire? It was working just fine before then. It even worked afterwards, I noticed it the next day that it wasnt run properly.
My heating unit is blowing cool air. The thermostat will start the blower when the unit is turned on at the thermostat, but the air isn't hot. But,when I turn the unit on at the furnace/blower using the "Fan On" button, I can see the heating element heat up. After the blower starts the heating element does out. What could be the problem?
Posted on Dec 18, 2008
I have an intertherm furnace model number 901282 and it will not heat my house when i turn on the thermostat it starts but just blows out cold air pleases help
The blower should come on after ignition occurs. When the blower comes on first ignition will not be activated as the thermostat signal shows the heat is on. This happens when the blower relay is stuck in the on condition
Nov 21, 2014 | Intertherm Heating & Cooling
Intertherm furnace burner comes on, but blower does not. If I turn thermostat off then back on until it clicks the fan will then come on. It does not do this all of the time, just now and then.
Furnace burner and heat element are not the same. I think the fan time delay, a sensor that turns the fan on when this sensor senses heat, is shot and needs replacing, for a furnace type heat ( gas heat)
Aug 08, 2017 | Intertherm E3EB010H Electric Furnac
Intertherm heating unit shakes and making sounds
you either have dirt on blower wheel or it went out of balance. have had some that center hub comes loose. if its not dirt on fins wheel is bad
Feb 13, 2012 | Intertherm Heating & Cooling
Intertherm unit : heat is on and Iam energized at the motor but It does not turn on !! Blower motor works on cooling!! ???
try to switch the speed of the blower to a diffrent speed to se if that works(usually its the red wire for heat) . make sure to turn power off before disconnecting.
Jan 14, 2011 | Intertherm Heating & Cooling
I have an intertherm electric furnace FEH-A020, with multispeed blower installed when A/C added. My problem is blower operation. at the end of the cooling season with fan set to auto operation the fan ran...
The model of T-stat you gave comes up as a discontinued model on Honeywell's web site, but it looks to be a manual stat that type of stat would have to be wired with a summer winter switch with electric heat, allowing it to turn on the fan with a call for heat. If yours is a programmable T-stat you would need to select electric heat or in the installers set up change the default setting for fan from unit controls fan in heat to thermostat controls fan.
Oct 17, 2009 | Intertherm P3RA-048K Air Conditioner
I have a Intertherm heating and air conditioner it is a Manufactured Home. The furnace model number is E2EB-017HA. When you flip the switch to heat and move the control arm up nothing happens. You can go...
When you turn the on/off switch to on you are turning on the "fan switch" and the blower motor is only coming on. When you turn the switch to cool and move the tempature control lever down you are turning on the air conditioner...So it sounds like your heater is not working. Is the heater electronic ignition or does it have a pilot? If it has a pilot the heater may not be working because the pilot is out and will need to be lit. If it is electronic ignition you will need to inspect the unit to determine what component is faulty. Could be the igniter,gas control valve,ect. Verify that gas is not shut off to unit at line valve and gas control valve on unit.
Oct 07, 2009 | Intertherm Heating & Cooling
2005 pathfinder heater fan doesnt work
the blower motor is not working. a wire may have come loose, or the fuse is blown. i think on the 2005s the blower motor is located where the passengers feet go. i attempted to replace this myself, and realized before i started that it wasn't worth the 55 bucks to have someone else do it.
Jan 02, 2009 | 2005 Nissan Pathfinder
Intertherm P3RA-048K Air Conditioner Logo
229 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
