Question about Pitco Frialator SG14 Deep Fryer
Pilot light will not stay lit
The pilot will light, but goes out after releasing the control knob. Detached lead to the pilot electrode, resistance characteristics similar to known good electrode.
  • 11 more comments
  • Anonymous Nov 23, 2007
    My pilot light is on but the deep fryer won't turn on...what do I do?
  • valmar Dec 03, 2007
    The cord simiply falls out of the outlet on the back of the fryer
  • MERVIN203 Jan 03, 2008
    REPLACED AND GENERATOR& VALVE ON MY FRYER, NOW WHEN I TURN THE THERMASTAT ON PILOT GOES OUT
  • Anonymous Mar 26, 2008
    Pilot light does n't stay on, thermopile reading at open circuit is 800 milivolts. Is the
  • Anonymous May 08, 2008
    pilot light will not ignite
  • alkad May 15, 2008
    Have a concord ideal sprint boiler. The pilot light is not staying on. Have changed the thermo couple...but still not coming on. Do i need a new boiler?
  • Palchadha Jun 12, 2008
    I have JCP FRIALATOR DEEP FRYER we emptied the tank during this time pilot went off and now we are trying to turn the pilot on but when we release the knob pilot also goes off even after holding for long time
  • Anonymous Jul 20, 2008
    dean deep fry pilot light willnot lit
  • Anonymous Nov 13, 2008
    Pilot goes on ok and will stay on until I turn it up to a temperature and then all of a sudden it is out.
  • Anonymous Dec 06, 2008
    When I release my control knob my pilot goes out.It wont stay lit.
  • mingoangie38 Jan 14, 2009
    i have the same problem i need it fixed by jan22
  • Anonymous Jan 29, 2009
    pilot will not stay lit
  • carter2728 Apr 07, 2009
    pilot light will not stay lit
My pilot is lighting but my deep fryer wont light
Posted on Nov 21, 2009
    Novelist:
  • 75 Answers
Hi, I believe the thermocouple needs replaced. Sounds like it is a millivolt thermocouple and produces voltage to open the gas valve. Good luck. kstfas
Posted on Oct 06, 2006
  • Ronnie Mason
    Ronnie Mason Oct 06, 2006
    I think you can download the manual on this fryer from here. Im not sure which one you are working on. http://www.pitco.com/downloads.htm
    Let me know.
    kstfas
  • Ronnie Mason
    Ronnie Mason Sep 21, 2007
    Did you get your fryer working? What was the problem? Let me know.
    kstfas
Try clicking thr reset botton. and if youve changed the thermol copple and it didnt work.then its your gas valve it is either stuck.or needs replacing. hope this helps
Posted on Nov 21, 2008
I just fixed the same problem by replacing the thermo-coupler. 6 bucks at the H depot, shhhwinggg, hot water again.
Posted on Apr 19, 2007
4 Suggested Answers
kebah
  • 684 Answers
SOURCE: the pilot light goes out
Hi there.
Check the thermopile, it must be clean and free of soot or any form of dirt. The gas pressure must be sufficient and all wiring should be tightly connected. Check also the hi limit, it should have continuity across its terminals when tested with an ohm meter.
Regards.
Posted on Jul 23, 2011
SOURCE: Pilot light won't stay lit
Wrong voltage thermocouple? must have 400mv, residential uses 25-40mv.
Posted on Feb 13, 2008
burzerko
  • 254 Answers
SOURCE: No Pilot Light
This device actually uses a thermopile it is part number P5047541. There are two things to check here ensure that you have had the right part installed be verifying the part number and also check that the sensing end of the thermopile is directly in the path of the flame.
Posted on Jun 04, 2008
Oven lights but then flame goes out as soon as I release the knob
The flame sensor seems to be bad.
When I light my pilot light, it stays on till I release the button ...
askville.amazon.com > Home > Home Improvement
Mar 18, 2008 - Similar Questions: light pilot stays till release button suggestions ... If you have held it for a long time and it still won't stay lit, then your thermocouple is bad.... the gas valve doesn't think a flame is burning the gas coming out of the pilot ... less likely but somewhat common is the gasvalve... if the knob you are ...
Troubleshooting Gas Range and Oven Problems ' Back ...
blog.etundra.com > Tundra's Tech Talk
Dec 15, 2015 | Fisher Paykel Fisher & Paykel 24-in...
Pilot light blew out by a fan..I turned the control off..How do I Ignite Please
First locate where to light pilot. You can do this by following thin aluminum colored tubing from control valve to inside heater.In general on top of your gas control valve is a knob. Turn indicator of this knob to pilot and depress knob. This will start gas flow to pilot at end of thin tube. Hold this knob in the depressed position and light pilot. DO NOT release knob for 30 -45 seconds. Then release knob and pilot will remain lit. Then turn knob to on position. If pilot will not stay lit you may need a new thermo coupler, which senses heat from flame to keep pilot gas flow open.
Good luck
Mar 10, 2015 | Heating & Cooling
Totai heater wont stay on after lit
Without a pilot flame sensor signal the pilot light will not stay on and the heater won't work. Try Replacing the pilot flame sensor, the pilot flame burns on to it and it connects to the valve. It looks like a wire.
Nov 26, 2017 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Have winrich perfecta ventfree lp model 6380. Very hard to start. Ignition switch never worked correctly. Pilot and ods showing corrosion. Doesn't stay lit very long. Can I replace the pilot/ods a
First clean out pilot light with can of air , or blow down it with a tude.
Then brush electrode clean with a clean paint brush ,chech to see if electrode is in the right postion to light the gas not too far away and the spark is strong , Clean thermopile head if fitted, then check thermocuople /thermopile connections are tight . see if this helps .
Oct 28, 2012 | Heating & Cooling
How do i light pilot light?
Remove front cover,or just lower section if you can. they usually just need to be lifted up about an inch or so and pulled out. However some have covers that snap in place. After you remove cover locate gas valve. It should have a control knob on top with markings for on, off, and pilot. Set control to pilot. Follow lines from gas valve to burner compartment, one goes to main burner one ,small copper colored line is the thermocouple, other line is the pilot. Turn thermostat down as far as it will go. Make sure gas supply valve in line to heater is on and then depress pilot control , when you have pilot control depressed have a match or other small flame source close to pilot assembly. If it lights then hold down on pilot control for a couple of mins. Slowly release pilot control and if it stays lit turn gas control to on. Turn thermostat up to call for heat and burner should light. If pilot doesn't stay lit when you release pilot control then try again holding pilot down longer. If it still won't stay lit then thermocouple will need replace. Good luck. Thanks
Nov 22, 2010 | Williams 6508732 Gas Heater
My intertherm mgha is having pilot issues. The
The problem will be in what senses the pilot is lit. Either a thermocouple or maybe it uses an electrode and flame rectification. If it is an electrode you can try cleaning it. If it is a thermocouple you will have to replace it.
May 02, 2010 | Heating & Cooling
Greenhouse Heater pilot light will not stay lit
replace the thermocouple. it is a small copper tube that screws into the gas valve and goes to the pilot assembly. a good haedware store that sells heaters will have one. they come in various lengths 18"-48".
Nov 30, 2009 | Heating & Cooling
My electrolux oven won't stay lit
Right above your pilot light, there is a little temperature probe. It either needs to be cleaned, replaced, or adjusted closer to the top of the pilot flame. Hope this helps. Good luck!
Nov 07, 2009 | Cars & Trucks
Re Williams 3003622 Heater Please advise how to ignite pilot light.
You will first need to turn the control knob to pilot. Then depress the control knob button and hold it. Then press the push button piezo igniter several times until pilot lights or open pilot inspection cover and manually light pilot with match/lighter. You may need to hold the control knob for at least a minute. Then release the control knob and if the pilot stays lit then turn the control knob to on. If it does not light then repeat the process again.
Oct 27, 2009 | Williams 3003622 Ceramic Wall Mounted...
You can not check a thermocouple by resistence. You have to check it by millivoltage when it is hot and sensing it should be above 500mv. I would be willing to bet that you have some type of particulate in the gas valve that is causing this problem.
Jun 23, 2008 | Pitco Frialator SG14 Deep Fryer
Pitco Frialator SG14 Deep Fryer Logo
6,341 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Treefrog15
Treefrog15
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
