Question about Extended Systems JetEye Net Infrared Adapter
Re: Jet Eye ESI-9900 networking problems
I bought a Hammerhead tablet PC from eBay that is running windows 95. It came with a docking cradle and an ESI-9900 Jet Eye IR adapter that has an ethernet port and a token ring connection. I am having a problem with creating a small network with my laptop that is running XP home (sp2). I have tried several different ways to set up the network and I cant get my XP laptop to find the tablet pc and vice versa. How do I set up a network for this? Thanks!
I was one of the original developers on the 9900. You need ESI's IrLAN layer. From what I understand, Microsoft did not implement IrLAN for the IrDA stack in XP. It will not work.
Posted on Jul 23, 2008
    Novelist:
  • 114 Answers
Start with the cabling. Check to make sure the Adapter LAN port is properly connected to your switch port and that you are getting a link light on both ends. It appears that this device can only run at 10mbps, so if the port is set to 100 or 1000, or even has the duplex set to full, you are not going to get a physical connection. Next, check to see if there is any diagnostic utility to confirm that the IR port on the table is infact communicating with the docking cradle. Since this product is 10 years old and the company has since been bounght by a software company, documentation has been very hard to find. I did mange to find a FAQ re: setup here: http://resolution.extendedsystems.com/ESI/Service+Support/XTNDAccess+Infrared+Connections/Troubleshooting/XtndAccess_TS_Net_1.htm And two Microsoft articles mentioning that the IR driver has to be up-to-date in order to work: http://support.microsoft.com/kb/149449/EN-US/ http://support.microsoft.com/kb/149450/EN-US/ Next, check that you have IP and IP address and IP connectivity. This can be done via the command prompt by typing the following command: ipconfig /all If you do have an IP address, then try to ping the Windows XP laptop with the following command in the command prompt: ping 192.168.1.100 NOTE: Replace the 192.168.1.100 with the IP address of the laptop. This info can be obtained with the same ipconfig /all command listed above. If you get a response from the ping, thats good and means you have end-to-end connectivity. Then you will just have to check to make sure the microsoft client and file and print sharing services on installed and enabled on both the tablet and laptop. If you have folders shares on them, you should be able to go to Start -> Run and type the following and hit OK: \\192.168.1.100\ NOTE: Replace the 192.168.1.100 with the IP address of the other machine. If you did not get a response from the ping command, then you have an IP connectivity issue and will need to trouble shoot that further. That could be anything from bad drivers to misconfigured IP settings or DHCP settings. I know this seems like a lot, but there really could be any number of reasons why this is not working. To close, I will try to summarize. 1) Check the physical network connections on both computers 2) Check the TCP/IP network settings on both computers 3) Check the Microsoft Client & File and Print Sharing settings on both computers.
Posted on Sep 06, 2006
I am attempting to run full reload of this system using an exterior hard drive with usb connection. The reload will not start using thid device. I did not buy the docking station for this system when I...
Most laptops cannot boot up from a USB device/hard drive. Check the BIOS configuration to see if the USB is available in the boot order devices. In this case the USB driver is not available for use until Windows is installed.
If the USB is not available in the BIOS Boot order then you need to reinstall Windows using the installation CD in the CD drive..
Nov 24, 2010 | Compaq Refurbished TC1000 1GHZ...
I bought a fujitsu stylistic st 4121 off of a friend but it gad a bad virus and it had to be wiped clean and im clueless on how to get it up and running again...plz lead me in the right direction thx
Your either going to have to buy fujitsu's over priced external drive or buy fujitsu's over priced dock, which comes with a DVDrom/CDRW drive built in.
Or What I do is Bought WinImage or any other software that allows writing a ISO image to USB flash drive, this should almost always work.
I had to install Windows 7 on my tablet this way.
Choose your poison.
Good Luck.
Oct 13, 2009 | Fujitsu Stylistic ST4121 Tablet PC
I just found my HP Pocket PC 2003 Pro, it has been MIA since we moved in 05. Unfortunatly I only found the unit itself and the docking station. It was my first and when it was lost I just went back to...
If it has been hiding for 4 years the battery is probably broken. Your should still be able to find a new battery on ebay for it. Or maybe from HP but it will cost a bit more.
Sep 17, 2009 | Microsoft Windows Mobile 2003 for Pocket...
Inspiron 1525 power light is on but computer wont work
Some details please? Does the system show any video on the LCD? Do you hear any Windows Startup Sounds? Are the Lock lights (Caps Lock, NumLock and Scroll Lock on/flashing? If you have none of the above, then remove the HDD, Optical Drive, RAM, Modem, external devices/docks and wireless cards and see if anything changes. If nothing changes, thenmost likely a motheboard issue. Replace ment motherboards run $150 to $250 on Ebay
Jun 12, 2009 | Dell Inspiron 1525 Laptop Jet Black
PDA hardware
You can usually get these at most any computer store, if there are none in your location I suggest searching ebay for "palm pilot PC interface cable" or "palm pilot docking cradle"
Feb 11, 2008 | Tablets & eReaders
Considerations for Windows 2000 - WorkPad c500/505
The WorkPad c500 and c505 can be used only with PCs running Microsoft Windows 98 or Microsoft Windows 2000 operating systems. NOTE: Microsoft Windows 95 and Microsoft NT 4.0, or serial connectivity, require a serial HotSync cradle or cable, available separately from Palm, Inc. The WorkPad HotSync utility will not sync via IR when the host PC is running Windows 2000.
Sep 14, 2005 | IBM WorkPad c505
Sep 14, 2005 | IBM WorkPad c500
HotSync fails using PalmConnect/Palm V on XP-Pro Tablet PC
This one is simple - Tablet edition is not supported. Sorry to break the news to you but palmOne soes not support synchronization with Tablet editions of Windows. If you can get it to work, great but you cannot get direct support for it.
Sep 11, 2005 | Palm V
Extended Systems JetEye Net Infrared Adapter Logo
513 people viewed this question
Top Extended Systems Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an Extended Systems Computer and Internet Expert? Answer questions, earn points and help others
