Question about GE WDSR2080D Top Load Washer
Washing machine has filled up with water, then everything shuts down
The washing machine is full of water. When I try to start the machine by turning it on...the electrical componets stay on for about 5 or 10 seconds and then everything shuts down. Please help! Sincerrly, M Harbour
SOURCE: My GE space saver stackable washing machine will
Im haveing the same exact problem on the same exact machine... I have taken all the pannels off, and drained the water. I was wondering if there may be a way that the pump lost it's prime and needs to be re-primed? (wishfull thinking on my part.) There was no indication that the pump burnt out, it just stopped working instantly with no symptoms. The other functions seem to work, it will agitate the laundry, and then will just stop when it comes to the pump cycle. Any help is appreciated. Thank You.
Posted on Aug 05, 2010
0 characters
1 Points
Will not shut off when plugge in...will still drain fine when I do plug in
How to Fix a Washing Machine Where the Water Won't Stop ... > Foreclosures > Other Foreclosures
1. Turn on the washing machine, and allow it to fill half full of water. ... Turn theshutoff valves on the cold and hot water supply lines clockwise to run off the water running to the machine. ... Remove it and all wiring connected to the terminals.
Washing Machine Fault Diagnosis - How to repair > Home > Washing machines
Nov 11, 2014 - When trying to find the the fault Please bear in. ... So begin at the plugand make sure that there is power to the socket and that the fuse is okay before looking any further. ... Washing machine will not drain or is noisy on drain. Generally .... As the appliance goes into to rinse it starts filling, then does not stop.
Jan 26, 2016 | Washing Machines
I have a maytag LSE7806AEE that stopped after filling the washing machine with water. I have tried everything to get it started but it will not respond.
since you can get water going, power is ok. Once water is filled, it should start automatically. Sine the drum is not moving to wash the load, it is down to drum mechanism. BTW if you manually move the knob to spin what happens?
Aug 06, 2013 | Washing Machines
Washer just shuts down
If the washer is turning off mid cycle then the problem most likely has something to do with the draining or the filling.
First check the drain hose is not to far down the standpipe. If it is to far down then the water might siphon out during fill. The water would fill and drain at the same time. One cycle I would like you to try is the "Rinse Only" cycle. This is a simple, short cycle that should just fill once, drain and spin. If the washer will do this then the major components are most likely okay.
Make sure the water drains out and let me know if the drain pump is the source of the noise you hear.
Oct 19, 2012 | Washing Machines
ERROR CODE E 60 washing machine zanussi ZWG1100M
This can be due to error in the control board. Shut down and remove plug and when switched on press down the start/stop button. If the error does not clear this can be a fault in the motor drive within the control panel board.
Remove the panel and check the connections to the motor, check the motor and the capacitor to the motor or if the motor is jammed.
Jul 03, 2012 | Zanussi Washing Machines
Washer overflowed while filling for wash cycle.
A quick test to split up your possible trouble makers:
Let the washing machine fill with water and when the washer is about 1/2 full of water unplug the washers power cord from the wall outlet. If the water keeps flowing into the washing machine with the power cord pulled the fill valve ( where the hot and cold hoses are attached to your washer ) has mechanically stuck open and will have to be replaced. If the water shuts off when you remove it's power cord from the wall outlet, try plugging the washer in and out a couple more times and if the water stops each time the fill valve indicates as being good = on to the next trouble makers.
The water level control is responsible for shutting off the power to the fill valve and redirects the power to the timer to start the washing machine running once the correct water level has occurred. The WLC itself could be bad. The WLC uses a hose that the water level pushes air into to tell the WLC what the water level is inside the washing machine...the hose could be pinched, fallen off of the tub spout, has a pin hole, clogged up with calcium or soap curd and the WLC cannot "sense" or "tell" what is happening inside the washer.
Nov 27, 2009 | GE Washing Machines
Washing machine overflowed
Try filling it again and stay with it, when it starts to get near the top, unplug it, if water continues coming out you need a new valve, if it stops, then the level switch inside the control panel is bad
Jun 17, 2009 | Washing Machines
Must repeatedly slam top loading door shut for machine to start
on the inside of the lid there is a lid switch hole that a plastic tab goes down through the switch could be bad or the screws holding the switch in could be lose or broken
Mar 28, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
GE washing machine does not run, gives humming noise
A washing machine is a simple product.
When trouble shooting anything you have to know what is supposed to do and what is it not doing.
At the begining of a washing machine cycle the machine fills with water until a switch is made telling the machine it is full and ready to agitate. Since it never fills it will stick in that part of the cycle.
When you start a cycle and no water enters the drum you have one of three problems:
1. The water supply is shut off.
2. The solenoid valve that supplies the water is not opening.
3. No power to the washing machine.
Since you are hearing a hum, the machine seems to be trying to activate that valve,
The humming noise comes from the electromagnetic field that activates the valve,
Dec 04, 2008 | Washing Machines
Washing machine it shuts down water filling cycle
First thing to check is the filter,
open the bottom pane (3 screws on bottom front lip)
in the cent is a large removable filter ,
set a pan or rags under it ,there will be water.
clean out any debris an be sure the pump impellers move freely.
let me know if that fixes it.
Jan 29, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Keeps filling up even when full for over 4 hours (never changed cycles)
The timer sends a signal to the water level control valve. This valve serves two primary purposes. 1. Activate the water valve to fill the machine. 2. Shut the water flow down and allow the machine to operate. Try running the machine again. If the water continues to enter the machine after it begins aggitating then shut the water off at the spigot. Now watch and see if the timer moves or not.
If the timer does not move at all then I would replace the timer. If it DOES move then another problem exists and will need to be addressed.
Jan 13, 2008 | Maytag Performa PAV2200
GE WDSR2080D Top Load Washer Logo
18 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
