Question about Dewalt DW715 Heavy Duty 12" Single - Bevel Compound Miter Saw
Dw705 12" mitersaw
I have a saw that my dad gave me.it has not been used in a couple of years,I got a couple blades off of ebay 12" 60t brand new,I put them on(tried both)but they seem to wobble,I tightened them down good ,but when cutting they both wobble a good bit,and let a slight bevel in the wood,now the blades say 5000rpm,the saw says 4000rpm,is that my problem?or could something be wrong with the motor?
  • David Ford
    David Ford May 11, 2010
    If they are new blades, I would look at the inner and outer flanges for wear. Also make sure that the spacers are on correctly. Usually there is one for the blade and one behind the inner flange.
  • 35 Answers
I do not know your machine but from previous experience I know that a sircular saw blade wobbles when it was over heated during use.
Posted on Nov 01, 2008
  • Ivan
    Ivan Feb 14, 2009
    To add: A circular saw or similar blade is one of those things which I would not buy 2nd hand. You just don't know how the previous person used it.
My brand new Ryobi Reciprocating Saw blade clamp will not open enough to insert a blade. Rick
You are probably trying to use old-style blades in a new saw. Go back to the store where you bought the saw and ask for the correct blades.
Nov 28, 2017 | Ryobi Saws
Witch way to turn the blade bolt on a 10" table saw
I'd be surprised if it were anything but a normal, right handed thread.
So, put on some leather gloves, block the blade from turning with a piece of scrap lumber. Use the appropriate size blade wrench and, I assume you're removing the blade, pull the wrench toward you to loosen it. Always remember, lefty loosy, righty tighty and you'll never wonder which way to turn it again. Obviously if this method tightens the nut rather than loosening it, it's a left handed thread and needs to go the opposite direction. Should loosen/tighten rather easily, so don't force it one way or the other.
Aug 31, 2014 | Skil 10" 60T Skilsaw Circular Saw Blade -...
Dewalt miter saw
The bearing may be getting ready to fail. The blade should not be difficult to turn.
Dec 18, 2013 | Saws
Part that guides the blade is broken need a new replacement
Search online for black and decker parts using the model number (on the label on the jigsaw). But Black and Decker are manufactured to bot be very durable, its better and probably cheaper to replace it, with almost any other brand. If cost is an issue but a used high quality item on ebay, made by Makita, Hitachi, Bosch or Metabo. Even and old one of these is better than a black and decker.
Nov 01, 2013 | Black & Decker Scroll Jig Saw Blade
The chain keeps falling off my brand new Poulan sixteen inch blade chain saw
It is possible they gave you the wrong chain for the saw. I would take check the manufacture to see which chain you need then check the numbers on your chain. Other thing it could be is the washer on the clutch may be missing. Either way, it is a new saw, I would take it back.
Apr 01, 2013 | Poulan Garden
Hi I have a Black and Decker Jig Saw 7588 Type One that works fine but I can not find replacement blades for it here in San Diego, California. Where can I find the blades?
I have the blades and the 7588 jigsaw. thinking about selling on ebay. search for black & decker jigsaw w/ blades in next couple days if interested in buying saw with 6 blades. thankyou, makthriftsales
Jan 14, 2013 | Black & Decker Single Speed Jig Saw
I have an old Sears Craftsman 7" Electric Handsaw model #315.27782. The blade I use for fine sawing has begun to wobble. I've taken it off, put it back on and tightened it several times. Same wobble. ...
It could be that the bearings that support the shaft that holds the blade are worn, allowing the shaft to move slightly and make the blade wobble. As the machine is an older model, I would try replacing the bearings.
Sep 16, 2010 | Craftsman Saws
My handle broke off on my hitachi table saw c10ra3 need to replace it . It is for the rip fence to lock in place. most places i look you had to buy the hole assembley i just need a new handle
go to garage sales and try your luck. ive had the same problem with differant brands and had to replace the whole thing. check manufacturers web site or your owners manual and see if its a replacable part with a part#
Apr 22, 2009 | Hitachi C10RA3 10" Table Saw With Stand:...
Brand new miter saw/ran for 10 hours power was not consistent, then nothing
What part of the motor has blown? There is the armature and field coil and they won't always need replacing at the same time. There are brushes as-well, but as they are quite cheap I'm guessing you have been quoted on one or both of the motor parts to be replaced. Have you asked the repair guys for a report. They should be able to suggest a reason for what has blown and why by looking at the faulty parts. Although most manufacturers and service agents have discretion over warranty claims, if your machine is more than a few months over htere is almost definately noting you can do on the warranty side of things.
Oct 16, 2008 | Makita 10" Dual Slide Compound Miter Saw...
Dewalt DW715 Heavy Duty 12"  Single - Bevel Compound Miter Saw Logo
413 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
