Question about Lenovo 3000 N100 Notebook
Frozen Screen I have a 20 month old Lenovo 3000 T100 laptop. Right now, once I login to windows, the screen is frozen. I can see the desktop and move the cursor, etc, but if I double click on any icon, nothing happens. The Start menu or quick launch icons do not work either. If I try to rapidly double click, there is this loud beep (similar to the one I head if the battery is low). But.. everything works fine on Safe mode though. Any solutions anyone? Thanks
  • sreecaps Oct 30, 2008
    Aruis, thanks. But that was not the problem. Also, I made a mistake in giving you the mode. its actually Lenovo 3000 C200.
    Anyway, I still have the problem... It goes into the booting process to different levels at different times, and at some of the times it even throws a 'Server Busy' window, but does not let me click on the 'Switch to' or the 'Retry' button... I can click, but nothing happens. Does not even open the Task Manager to see if there is any application running, which possibly is taking up the CPU space...
  • D. Tinsman
    D. Tinsman May 11, 2010
    Did you ever get this fixed? I have some ideas.
  • 446 Answers
One ofthe keys on your keybord is stucked up try to check pls
cheers
Posted on Oct 29, 2008
Time day clock stopped
run an anti virus and if that does not work go to the right of your screen and put in the search box your question, a solution should pop up .if not call the maker of your computer to see if they can help and since its under warranty they should help you for free. I called mine and since it was still under warranty they helped me!
Jan 29, 2014 | Acer Aspire Computers & Internet
My screen is flickering. The laptop is only a month and a half old. Originally only happened temporarily when it came out of sleep. Now happens consistently. Also happens now when I move the computer...
hi
your inverter card may have come loose from the connection -- or this could also be a result of bad connection with the LCD itself -- anoither possibility is bad video card
have you tried updating the Windows OS as well a sthe Lenovo drivers for video ?
go to this Lenovo site , update the video graphics drivers
http://consumersupport.lenovo.com/us/en/DriversDownloads/drivers_list.aspx?CategoryID=288288
Aug 15, 2011 | Lenovo IdeaPad Y460p Laptop Computer -...
Black blank screen Lenovo 3000 N100
You say the laptop all of a sudden flashed off.
How old is the laptop? You may have suffered one of two things? First of all, if the hard drive will not boot back up, even after using the recovery discs, then that would explain it powering off. I have seen this happen on old desktop hard drives.
Next, try to get the transformer or adapter tested. It may not be putting out enough amperage to run the laptop.
Sep 01, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
MY Acre Aspire 3680 is Frozen! Need some Heat- appreciated :)
Dear pdtuladhar,
Just put your Installer CD on your optic drive (Windows XP?) and restart it. The CD should takes over the priority list of boot>>>
after you succeed, press esc and log in, save your file from C: drive and run the installation once again..
GoodLuck!
Aug 15, 2009 | IBM (250410U) Docking Station for ThinkPad
Help....
there is a problem of new hardware you installed, check it memory, graphic card and go to the safe mode and take you data from c: drive, and format your c drive and check it check that your drivers you are installed its supported for your windows, its a good solution that you have to format it and check it
Oct 01, 2008 | Intel Lenovo Core 2 Duo T7100 1G RAM 100GB...
Laptop switches of after 5 minutes when on ac power irrespective of power up mode
You may try to uncheck the box under my computer>right click> properties> advanced> startup and recovery.
uncheck the box for automatic restart.
try to blow a can of compressed air into your fan and heat sink channel.
then try to run windows update or go to update.microsoft.com to do so..
regards,
Ronald.
Aug 19, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Display problem
Your display driver is the windows generic driver. You need the video driver from IBM for your model machine. Installing the correct driver will give you the higher resolution you seek.
Jun 16, 2008 | IBM ThinkPad 600E 2645 Notebook
Frozen screen
All you reaaly have to do is let the battery run out. Then once the mp3 is dead, charge it. The screen should be unfrozen.
Jan 06, 2008 | SanDisk Sansa e250 MP3 Player
Lenovo 3000 N100 Notebook Logo
235 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
