Question about HP LaserJet 1020 Printer
HP1020 PRINTER COPY AT TOP OF SHHET GETS CUT-OFF ON LEGAL SIZE
WHEN PRINTING A DOCUMENT FROM ADOBE PAGEMAKER FILE
THAT IS 8 1/2 X 14, THE TOP OF THE COPY WILL NOT PRINT OU COMPLETELY. THE TOP PORTION OF THE COPY GETS CUT-OFF.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
How to convert a Page maker file into PDF formate. I am using Page Maker 7.0 and Adobe Acrobat Distiller 6.0. And I am using Samsung Printer drivers to convert page maker to post script.
Go to print, select the printer as ADOBE PDF on my document\*.pdf, then the PPD as ACROBAT DISTILLER ****.***, and set the paper size, etc final go to print, then give file name for the pdf.
Mar 30, 2015 | Adobe PageMaker 7.0 for PC
I am giving the margine in Adobe Pagemaker in legal size paper left 2", Right 1", top2" & bottom 2" but printer is print on paper from top only half inch margin
Did you remember to change the paper type in the printer settings to legal, before printing? If not it will use the default, usually letter size.
Feb 27, 2015 | HP LaserJet M1005 MFP Printer
How can I print proper legal size documents in pagemaker 7. my printer is LJM1005. can anyone pls. help me on how to print documents in legal...
I don't know about pagemaker 7, the HP LJ M1005 should allow you to select (US) 'legal' paper size.
I would this is done by (having first installed your printer) from within pagemaker, or at least Windows (if you are not using a Mac) selecting 'File' from the menu bar at the top of your screen, and from the drop down menu select 'page set up' and then choosing 'legal' from the drop down menu (box) which is for paper size.
See p58 of this document (software reference guide for M1005) for illustration -
http://www.hp.com/ctg/Manual/c00742663.pdf
You might also consult your user guide (available by [free] download from HP LaserJet M1005 Multifunction Printer series
11.February.2015
Feb 10, 2015 | HP ljM1005-HB-pnp-win2kxp-en.exe
Adobe acrobat .pdf
you have to export that file to .pdf
and only the acrobat reader 5.0 is not sufficient for write the file to pdf
you need acrobat reader for doing so.
Jan 03, 2010 | Adobe PageMaker 7.0 for PC
My hp laserjet 2420 printer won't print out my bottom text of my legal size document. when i preview my print it cuts off all text at 9.5'' . what's wrong? my margin's are all set to 1'' and i customized...
Do NOT use customized paper. Set your paper tray to LEGAL paper. Set the tray as LEGAL in the printers setup-menu. Make sure you choose LEGAL in the printout-dialog-properties. Then it should work. Good Luck.
Aug 14, 2009 | HP Hewlett Packard LaserJet 2420 Printer
Translate a pagemaker file into indesign
This is from Adobe InDesign (CS3) Help module:
Convert PageMaker documents InDesign can convert document and template files from Adobe PageMaker 6.0 and later. When you open a PageMaker file, InDesign converts the original file information to native InDesign information. InDesign files are saved with an .indd filename extension.
For more information, see the PageMaker Conversion Guide (PDF) at www.adobe.com/go/learn_pmconv. Before opening the document in InDesign, you may want to do the following:
  • If the PageMaker file or its linked graphics are located on a network server, floppy disk, or removable drive, it may not open as expected if an interruption in data transfer occurs. To prevent data transfer problems, copy documents and their links to the hard disk, preferably in the same folder where the PageMaker publication is stored, before opening them in InDesign.
  • You may want to use Save As in PageMaker to clear unnecessary hidden data.
  • To ensure that all links are maintained, copy all linked files to the same folder where the PageMaker publication is stored.
  • Make sure that all necessary fonts are available in InDesign.
  • Repair broken graphics links in the PageMaker publication.
  • If you have a problem converting a large PageMaker document, convert portions of the PageMaker file separately to isolate the problem.
If you cannot open a corrupt PageMaker document in PageMaker, try opening it in InDesign. InDesign can recover most documents that PageMaker cannot open.
Oct 29, 2008 | Adobe InDesign CS2 for PC
Printing error on legal size paper
Make sure you are selecting "legal" for the paper size in the program you are printing from
thanks for rating
Jan 10, 2008 | HP LaserJet 3055 All-In-One Printer
Paper margin problem in pagemaker application
Do you mean the left margin is too large so all the content is shifted to the right and off the page? If this is the case, it is probably a setting in Pagemaker. In the file menu, choose "page setup" or "print setup". Check the paper size. Check the margins.
Jun 24, 2006 | HP Color LaserJet 2600n Printer
HP LaserJet 1020 Printer Logo
128 people viewed this question
Ben Johnson
