Question about Zenith IQB27B44W 27" TV
Bad picture on tv
The picture on my tv is too black and red. Sometimes the picture is pretty good but it always ends up with too much black and red that won't adjust out. Someone told me it's the picture tube and to trash it, but it has an okay picture sometimes, so I don't want to do that right away.
    President:
  • 3,130 Answers
You should have the Picture tube checked by a professional, as thats the first thig most peeps think that goes bad when a picture is gone or bad. It could also be the crt driver circuit.
Posted on Sep 06, 2006
The dark areas of a picture is red
the screen itself is going bad and wearing out . there is no repair except replacement of the tv .
the screens are so expensive to buy there would be no point
sorry i could not bring you better news
Feb 02, 2016 | Sony BRAVIA KDL-40EX400 40" LCD TV
TV shuts down with Red Light blinking
it must be your tv was heated on long usage.
sir, try to go to your nearest expert technician. they have tools to use on fixing your tv's hardware. or see if your tv has a warranty to send it back to the place what youve bought it. hope that helps!
CHARCOIS
Aug 09, 2008 | Toshiba 50HPX95 50 in. Plasma HDTV
Why does plasma TV have no picture?
What brand and model # is the tv? This is very important as far as researching your problem. You probably aren't the first or the only person with this problem. There are typically four to 5 boards including an x main, a y main, power board and others. Sometimes easy stuff like capacitors or fet's go bad and you can fix it yourself pending your soldering abilities. Sometimes whole processors go bad or entire boards and these need to be replaced. Sometimes people want to fix sometimes they want brand new
Jul 07, 2015 | Televison & Video
The picture is blurred and ghostly. Sometimes it's fine but then it reverts to blurred again. The picture is very red as well.
Good day!!! That problem is usually cauase of bad t-con board please try replace it to end this problem.. Thanks for using fixya..
Sep 13, 2011 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
The TV turns on, has picture, then after about 15 seconds goes black but still has sound
The two most probable failures is the backlight for the display or the inverter that powers it, If the ends of the fluorescent backlight tube are exposed, check if the ends are black. If not, then the inverter is probably bad.
These are mounted on separate smaller boards that are pretty obviously connected to the backlight tubes.
Aug 17, 2010 | Westinghouse Electric SK-32H570D 32 in....
Lamp part number 915p061010
Most times it will be physically busted inside. Sometimes not and you will have to replace it to know. If the lamp light is flashing, chances are pretty good that is all that it is. Let me know if I can be of further assistance.
Dec 27, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Sony kv35s66: No picture, just sound and red blinking
This should be a quick fix. Try resoldering the vertical IC. This is a small flat IC attached to a heat sink with about 11 pins. It should be marked LA7837 or something similar. That should resolve the problem.
Keep us posted.
Dan
Sep 08, 2008 | Televison & Video
Many thin black horizontal lines on my Hitachi Ultravision 50" TV
Good Day, LDS also;
You may have a poor seated cable connector. Unplug TV from A/C, remove back look for a large black connector. It connects between the Main Digital Module and the Drive PWB. Re-insert both ends several times to make better contact, use contact cleaner if have but not always needed. Good Luck, big IRISH.
Jul 21, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Click click repeatedly faded then red blinking light
Go to the video menu and turn the color control to minimum. Determine if you have a black & white picture or is it green & white. If the picture is greenish, you have a problem in the screen circuit or possibly a bad picture tube. If the black & white is ok then I would suspect a problem in the chroma circuit such as a bad video jungle IC or a crystal. However, because your set had a red blinking issue prior to your existing condition I would lean towards the picture tube as the source or your troubles. You can try a simple test to determine if you have an intermittant short . Take the back off the set, and with the insulated end of your screw driver, very very lightly tap on the neck of the picture tube near the socket. If you see green flashes or hear loud snaps in conjunction with your taps or the green tint goes away, chances are the tube is the cause. If so, you might try installing an isolation transformer on the picture tube. Good luck
Nov 29, 2007 | Toshiba 36A61 36" TV
The most common problem (I have fixed lots) is the Vertical amplifier has developed a loose connection. It probably just needs resoldering. As things expand it makes and looses connection you picture goes in and out. The vertical chip is a large black chip that gets hot, over time it degrades the solder until a connection is damaged. Most newer sets have a protection circuit that senses the lack of height, and shuts down the picture tube to save it. When the picture dropped to a line on older TVs and left that way too long it would burn a line into the face of the picture tube. You then had to have the picture tube replaced along with the vertical amp. it's kinda like a screensaver for your TV.
Nov 21, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Zenith IQB27B44W 27" TV Logo
134 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
