Question about Pioneer Audio Players & Recorders
Pioneer DEH-p700BT error 80 keeps coming up when a phone is attached. The manual tells me to turn off the ignition but i keeps coming back. What should i do to fix the problem?
SOURCE: I have a Pioneer DEH-P70BT
I Have exact the same problem. I heard you have to delete the phone from your car device and also the device out of your phone memory as wel. then let your car device search for your phone thus not vice versa. I did not test thi procedure yet , but I will today and let you know.
Posted on May 16, 2008
Benimur
  • 6966 Answers
SOURCE: Pioneer DEH-P700BT Problem with FM Channels
This is a firmware restriction. US version would tune from 87.5 to 107.9MHz at 0.20MHz interval (steps) while European versions would tune from 87.5 to 108MHz at 0.05MHz interval (steps).
In some versions, there is a resistor/diode matrix on the logic circuitry that selects the region of usage. But of course this would require opening the unit up and somebody who is very very familiar with digital and analog circuitry and components as well as surface mounted component soldering.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 18, 2008
easyq
  • 144 Answers
SOURCE: turning loud on in pioneer deh-p505 cd player attached with kds-p505 cassette player
Normally by pressing the button which give you the menu for balance etc also loudness comes by and you will be able to swicth it on or off.
Posted on Aug 08, 2008
SOURCE: Pioneer DEH-P700BT and Nokia N95
I managed to fix this issue with the auto disconnect using a Nokia N81 and Pioneer DEH-P7050BT.
I originally had the same issues that everyone else was facing, after trying several different things I successfully auto connect my phone when i turn on the ignition switch. It still disconnects when trying to download contacts, but i transferred these instead so not a big problem there.
OK so that steps i performed in order were.
1. Download and update the head unit software update from the Pioneer website, there is a link attached in another post. Follow the steps in the instruction manual.
2. Delete the pairing from the phone
3. Update the firmware of the phone via the Nokia Software Updater.
4. Turn off the PC Suit Sync in the phone, this can be found under settings.
5. Repaired the phone and the head unit, use the NOKIA-A option not NOKIA.
6. Authorise the phone to auto connect to this BT device without prompting.
This is all the steps I tried, some may or may not be usefull but after trying different combination's, I get a successful connection each and every time. A little icon of a car will appear on the phone stating it is connected.
I hope it works for you.
Posted on Nov 27, 2008
SOURCE: Lost Faceplate for Car Stereo Pioneer Premier DEH-P700BT
e-bay
Posted on Feb 02, 2009
I have purchased Carozzeria Pioneer DEH-P700 from a Vendor. I want too install the system in Car. Can you guide me for Yellow , Orange and Red Wire purpose? Thanks
Yellow
Connect to the constant 12 V supply terminal.
Red
Connect to terminal controlled by
ignition switch (12 V DC).
Orange
Power antanna
Nov 22, 2010 | Pioneer DEH-P700BT Car CD Player
I have a pioneer car radio and i am receving and error 12 message
I found the following information on Page 28 of the Pioneer manual for your DEH-P2900MP through the pioneer website:
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/370967683DEHP2900MPOperationManual1027.pdf
ERROR-11, 12,
17, 30
Dirty disc Clean disc.
ERROR-11, 12,
17, 30
Scratched disc Replace disc.
ERROR-10, 11,
12, 15, 17, 30,
A0
Electrical or me-
chanical
Turn the ignition
ON and OFF, or
switch to a differ-
ent source, then
back to the CD
player.
I hope that helps
Jun 22, 2010 | Pioneer DEH-P2900MP CD Receiver...
I bought a used pioneer deh-p7900bt, i cant use the bluetooth because of a code error, my phone recognises it but i cant connect. is there a universal code or a reset?
As an owner of the 7900 i'm assuming your talking about Error-80
If this is the one, turn the ignition on, using a pencil or similar item press the button just to the left of the eject button. this will completely reset the internal flash memory. Once it turns back on hold the dial in until you get into a setup screen. rotate the dial counterclockwise to "BT Memory"
press the dial to the right and it should come up with "reset?" now press the dial. 99% of the time it will say error but it still completes. Now turn the stereo back on and press the phone button. pair your phone to the stereo and viola you're all set.
Apr 22, 2010 | Car Audio & Video
Cd keeps ejecting on pioneer 1500 error code 10
The manual says a code 10 is Electrical or mechanical. The say the solution is to turn the ignition on and off, or switch to a different source, then back to cd player.
Dec 10, 2009 | Pioneer DEH-1500 CD Player
Turning loud on in pioneer deh-p505 cd player attached with kds-p505 cassette player
Aug 05, 2008 | Car Audio & Video
May 18, 2008 | Pioneer Car Audio & Video
Yay! I got it working!
I can
Looks like pioneer recently released an update even though its not on the pioneer australia website. You can get it from:
http://www.pioneer.eu/eur/content/support/support/update/deh_bt_update.html
This works for the DEH-P7050BT as well, even though it doesn’t say it.
Basically it adds another “group” called Nokia-A… This let’s both the headset and the car kit connect at the same time.
The contacts sync too… this worked for me before all this madness btw.
You have to click yes to transfer contacts, then the phone “disconnects”. On the phone you then go to your contacts menu, and select the contacts you want across. Then send these via bluetooth to the head unit.
Once done it didn’t really have an obvious way out of the menu, so I just turned the car off, but you can probably just press source or something.
When I turned it back on after syncing, it didn’t sync up automatically, so obviously on the phone I just told it the head unit was an authorised device.
Bingo I am happy.
I hope this helps someone else who was about to throw both the deck and the E51 out the friggen window… FYI this apparently fixes all the latest Nokia N and E series phones too.
May 16, 2008 | Nokia N95 Cellular Phone
Pioneer DEH-1900MP error AO
I have the same problem CD will not eject and getting error :S
Oct 19, 2007 | Pioneer DEH-1900MP CD Player
223 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
